Smart Spaces Design Challenge
  • Smart Spaces Design Challenge
Forum Forum Post #5: Adaptive Environmental Monitoring and Smart Access Control
  • Projects
  • Info
Join Smart Spaces Design Challenge to participate - click to join for free!
  • Subscribers 38 subscribers
  • Views 914 views
  • llm
  • NXP FRDM MCX A & MCX N development kit.
  • Smart Spaces Building
  • nxp
  • perplexity
skruglewicz
skruglewicz over 1 year ago
An Outline -Testing & Running the Smart Spaces Project
This project presents an outline, designed to serve as a practical tool for organizing and documenting my work on adaptive environmental monitoring and smart access control using NXP development kits. The structured workflow supports my process in drafting a comprehensive project document for the challenge, ensuring systematic coverage from hardware setup to final deployment.
I want to mention that I actively use LLMs (Large Language Models) for my daily activities in both professional and hobbyist settings. Prompt engineering and working with LLMs is something I’m greatly interested in—I’m constantly crafting prompts to support my job, technical writing, and brainstorming ideas for projects. For me, LLMs are invaluable tools that help spark creativity and refine ideas as I work through project challenges.
For this forum discussion, I did some brainstorming with Perplexity one of my LLM tools that I use quite often. after much prompting about what I was thinking we came up with this outline. The outline lays out suggested steps for testing and bringing the distributed building automation system online using the NXP FRDM MCX A153 (hub) and MCX N236 (edge node) development kits.
1. Hardware Preparation and Safety
Check boards & workspace: Lay out the MCX A and at least one MCX N board on an ESD-safe surface. Inspect for bent pins or loose components.
Review manuals: Double-check quick start guides for both boards. Confirm required sensor modules are present and supported.
2. Initial Power-Up and Verification
  • Connect boards to PC: Use the included USB cables; MCX A to a Type-C port, MCX N to microUSB.
  • Power LED check: Make sure each board's green power LED lights up.
  • IDE detection: Open MCUXpresso IDE. Check 'Debug Probe' list for both boards — confirm CMSIS-DAP/J-Link is recognized.
3. Flash Test Firmware
  • Select demo apps: In MCUXpresso, locate and build 'Hello World' (UART printout) or 'LED blink' demo for each board (from NXP SDK).
  • Flash to boards: Follow IDE prompts to program the boards via MCU-Link interface.
  • Confirm execution: Watch for LED blinking or serial output in MCUXpresso’s terminal window.
4. Sensor Integration and Verification
  • Attach sensors: Plug temperature, humidity, light, and motion sensors into MCX N board’s sensor headers as described in the manual.
  • Sensor demo: Flash sample code that prints sensor data to serial terminal. Adjust sensors physically (e.g., shine light, apply heat) and verify real-time values update in MCUXpresso.
  • Troubleshoot: If sensor values are off, check wiring, supported voltages, and code initialization routines.
5. System Communication Test
  • Wired test: Connect MCX N node to MCX A hub via UART or SPI, as planned. Flash demo code where sensor data is forwarded from N to A and printed via A’s UART.
  • Node recognition: Confirm that MCX A parses distinct node IDs and logs received values to terminal or onboard LCD.
  • Network expansion (optional): Attach additional MCX N boards to simulate multi-zone coverage. Confirm unique data from each node.
6. Adaptive Control Logic
  • Write simple logic: Program MCX A to trigger an output (e.g., toggle relay or onboard LED) if a sensor value exceeds threshold (e.g., temperature > 28°C).
  • Run system: Verify outputs activate as environmental conditions change. Adjust sensor inputs and watch system response.
  • Log and document: Copy terminal logs and take timestamped photos/videos for project documentation.
7. Cloud Connectivity (Advanced)
  • Attach WiFi module: Connect ESP32 or similar module per board’s documentation.
  • Flash networking demo: Use NXP or third-party examples to send sensor data to a test cloud endpoint (e.g., MQTT or HTTP).
  • Remote monitoring: View sent data in cloud dashboard or receive via web/mobile app.
8. Project Documentation & Forum Sharing
  • Save code samples: Archive MCUXpresso projects and demo code.
  • Capture photos/videos: Document wiring, boards, and screen outputs.
  • Prepare rich project posts: Write up test results in forum entries, including hardware, code, and troubleshooting tips. Ensure at least 5 media-rich posts before the challenge’s closing date.
Quick Recap:
  1. Inspect hardware and safely connect.
  2. Confirm board detection and flash demos.
  3. Integrate and test sensors, verify system responses.
  4. Link nodes, develop control logic, and validate outputs.
  5. Add cloud connectivity for full-scale smart building automation.
  • JoRatcliffe
    JoRatcliffe over 1 year ago +1
    Well done on making your fifth forum post
  • cstanton
    cstanton over 1 year ago +1
    skruglewicz said: Testing & Running the Smart Spaces NXP Project Below is a detailed, step-by-step story for testing and bringing the distributed building automation system online using the NXP FRDM…
  • skruglewicz
    skruglewicz over 1 year ago in reply to JoRatcliffe +1
    Still not done yet. I using the forum post as outlines to section for my final post implementation for the challenge.
  • JoRatcliffe
    Well done on making your fifth forum post Slight smile
  • cstanton
    Below is a detailed, step-by-step story for testing and bringing the distributed building automation system online using the NXP FRDM MCX A153 (hub) and MCX N236 (edge node) development kits. This guide follows the engineering workflow from initial hardware checks to live system operation.
    You have a lot of checklists in these forum posts, but where's your personal experience and opinions? Please also remember:  Regulation of Content Created and Submitted to the Site using LLM tools and ChatGPT
  • skruglewicz
  • skruglewicz
    skruglewicz over 1 year ago in reply to cstanton
    I use LLMs mainly for brainstorming and creating outlines for my project. The structured outlines really help give me direction for developing ideas, implementation steps, and testing strategies. They are not a replacement for hands-on experience, but they help me organize my thoughts so the process is less overwhelming and more focused.
  • cstanton
    cstanton over 1 year ago in reply to skruglewicz
    Me too, it certainly helps to be used as a tool, and personally, sometimes a crutch when needed Slight smile and we love seeing what that leads onto you producing. Looking forward to your work.
  • skruglewicz
    thanks for the positive reply.
    I'm Currently into LLM engineering and my day never goes by without using LLMs for my work and hobbies. It's amazing what a well written LLM Prompt will produce.
    To your comments on it using LLMs,I will be sure to include the footnote links on where the information came from.
