Smarter Life
  • Smarter Life
Smarter Life
Blog A Very Compact Christmas Display - Part 003
  • Author Author: COMPACT
  • Date Created: 1 Nov 2013 10:35 AM Date Created
  • Views 526 views
  • psoc4
  • smarter_life_challenge
  • psoc_4200
  • compact_xmas_display
  • smarter_life
  • psoc_creator
  • psoc
COMPACT
COMPACT
1 Nov 2013
PSoC - The Electronic Duct Tape
Literally, within seconds I had my first SPI project up and working.
  1. Just plop a SPI Master onto the Schematic Diagram.
  2. Hook up the input and output pins (internally).
  3. Reconfigure the input pin to use a resistive pull up.
  4. Hook up a source clock. I chose 1kHz.
  5. Hook up the SPI Master's reset line to Digital Logic '0'.
  6. Map the input and output pins.
  7. Insert a SPIM_Start() function into the initialisation code area.
  8. Insert a SPIM_WriteTxData(0x55) into the main program body.
  9. Insert a CyDelay(250) just after it.
  10. Build and Debug.
  11. Press F5 to launch and... voila!  Working first go!
It actually took me longer to scribe this down than to make it.
  • vsluiter
    vsluiter over 12 years ago
    Bravo for Cypress! It's this kind of features that gets you glued to a manufacturer.... Especially if you have the power to change the internals too; set up something standard, and then go deeper...
  • vsluiter
