Smarter Life
  • Smarter Life
Smarter Life
Blog A Very Compact Christmas Display - Part 019
  • Author Author: COMPACT
  • Date Created: 20 Nov 2013 9:14 PM Date Created
  • Views 564 views
  • psoc4
  • psoc_4
  • smarter_life_challenge
  • psoc_4200
  • compact_xmas_display
  • smarter_life
  • psoc
COMPACT
COMPACT
20 Nov 2013
Sensational!
Why have I focussed so much upon standard Timer component? Well it is a extremely useful component and is a great introduction for the PSoC 4 native TCPWM (Timer Counter PWM) mechanism.
Above are screenshots of the signal captures of an AMS TCS3200 colour sensor with various light sources.
The sensor is a 4 channel light intensity to frequency converter. The channels are Red, Blue, Intensity, Green.
The more intense the light, the higher the output frequency thus the shorter its pulse duration.
I have used the PSoC 4 to select the desired channel and record the pulse length.
I configured it to measure a half-period. To convert it back to a frequency the measured value needs to be doubled and then reciprocated.
For this demonstration I used the handy capture counter feature to skip the first two pulses and measure the third.
Doing this enables initial poorly formed pulses to be ignored.
I used the design for the Old timer article but added 3 Output pins for the colour sensor's 2 address inputs and output enable input.
If you look closely at the screen shots you will notice that my measurement of the green LED has a small red component.
Similarly for the (pale) blue LED where there is a tinge of green.
No such observation from the RED LED.
  • COMPACT
    COMPACT over 12 years ago in reply to DAB
    Hi Don,
    A closer examination of the datasheet explains everything.
    The response curves of the green and blue sensors have double peaks across the visible spectrum.
    The secondary peak is substantial and needs to be factored into the interpretation of the raw data.
    Very Compact
    DAB over 12 years ago
    Hi Monte,
    An interesting discovery.
    I wonder if the material used to make the Green and Blue tint might also emit the red tint.
    Given the level of output, I suspect that it will not cause you any problem unless you want to do some very specific colour output.
