Smarter Life
  • Smarter Life
Smarter Life
Blog FRAM Works!
  • Date Created: 21 Nov 2013 4:25 AM Date Created
  • Views 794 views
  • sleep_sensor
  • psoc4
  • smarter_life_challenge
  • smarter_life
FRAM Works!
e14 Contributor
e14 Contributor
21 Nov 2013
Hello All,
I hit a little stumbling block with the FRAM. I added a small delay ( CyDelay(10) ) to my UART printing code, and things worked better after that.
I ran a simple unit test in which I wrote the entire contents of the FRAM with an increasing counter, and then read the data back. As you can see in this plot, the data that was returned matched the expected up slope of the counter pattern. This is great news for my project, as it means that I can start logging real temperature data soon!
  • vsluiter
    vsluiter over 12 years ago
    Hi Alex,
    Congratulations! Most of the times those plots are easier to interpret correctly if you deduct the expected slope from them; you should see a constant value. If you've missed a sample or two, you wouldn't be able to spot it on this scale, where a jump in difference between expected / measured is very clear.
    On a side note, how do we go about developing our PCB prototypes? Is that part of the Newark funding?
