Smarter Life
  • Smarter Life
Smarter Life
Blog Oven Control with PSOC 4: Post 2 for Smarter Life Challenge
  • Author Author: malamitra
  • Date Created: 3 Nov 2013 3:01 PM Date Created
  • Views 737 views
  • smarter_life_challenge
  • oven_control
  • smarter_life
  • cypress_psoc_4
malamitra
malamitra
3 Nov 2013
    DAB over 12 years ago in reply to malamitra
    True,
    I look forward to seeing how accuate and responsive you can get with that combination.
    Cool idea.
  • malamitra
    malamitra over 12 years ago in reply to DAB
    Hi DAB, Thanks a lot for your comments. First of all I want to clarify that, this is not an on-off controller. The control is by actuator variation. In case of temperature control if the temperature falls for a certain cause, a voltage variable resistor will allow more current to flow in the coil and more heating. In the block diagram I did not close the loop with VVR and thats why confusion took place. But I am happy that you have gone through the document. In fuzzy controller the mathematical foundation is quite inadequate to choose the fuzzy function and the parameters.( I am familiar with the research done till 1994.)  PID stands on a firm mathematical basis. Here integrator takes care of hysteresis.
    How accurate are you trying to make your temperature control?
    I always find that simple state machines work very well with MCU implementations and they let you use a little fuzzy logic to set up a nice hysteresis zone to keep the system from toggleing from on to off due to noise in the signal.
    Look forward to following your posts.
