Smarter Life
  • Smarter Life
Smarter Life
Blog Smart solder reflow oven keyboard
  • Author Author: Kilohercas
  • Date Created: 31 Jan 2014 4:29 PM Date Created
  • Views 1154 views
  • smarter_life
  • reflow_oven
Kilohercas
Kilohercas
31 Jan 2014
Android keyboard emulation on my hardware
This is quite good learning process. I mean, it is simple, but at the same time it is quite complex. Like i can't use coma more than one time, and if i delete it, i can use it again. Simple, but need additional code to make it work. Also cursor jumping, if i push cursor to front, first i have to shift numbers to left, and only when i can write new number, also have to make sure that number size is less than 4 digits, if i try to shift 3 digit number to right, i can end-up it other variable memory inside CCRAM, and stuff like that. So it is simple program, but it gets larger and larger. Good that i have huge amount of SRAM on my STM32F429, and not doing this on PSoC5LP or even worse, on PSoC4 image
  • Kilohercas
    Kilohercas over 12 years ago in reply to DAB
    it's not good update, it's just update. Right now working how to send setpoint to PSoC5 from keyboard. when i do that, PSoC5LP program would be final (+-)
    DAB over 12 years ago
    Hi Linus,
    Good update.
    It looks like you are making good progress on your user interface.
