Smarter Life
  • Smarter Life
Smarter Life
Blog Some progress smarter plants challange
  • Author Author: wireb
  • Date Created: 7 Dec 2013 8:12 AM Date Created
  • Views 757 views
  • psoc4
  • smarter_life_challenge
  • soil_moisture_sensor
  • smarter_life
wireb
wireb
7 Dec 2013
Well the Thanksgiving plan was a bust. Parts arrived as I was packing up the car to leave so did not get the cards built and running before I left. Back now and have all the parts and raw cards so should be able to build them up this week. Got a bonus present from cypress of some PsoC 4 and 5s in the mail today. Unfortunately they are lead-less quad flats with a thermal pad so not the most user friendly package.
Spent 3 hours beating my head against why my simple "hello world" uart code did not work. Finally realized the default name in the gui was UART_1 where my C code was using just UART. So patched that up and fired up PUTTY and it worked.  Starter code attached more or less just a serial port echo with a little chunk of code added to convert carriage returns into line feed carriage returns.
Now working on a hardware frequency counter. Once I get that and a bit of code done should be ready to strap on some hardware and start recording values.
Plant_water_6dec13.zip
    DAB over 12 years ago
    Hi Peter,
    Yes, being overtaken by other events is a makers bad day.  Even if it is an enjoyable event.
    Learning to debug code is a very useful skill to learn.  You have to learn how to be a perfectionist.  Computers have no sense of close enough.  The code is either right or it is wrong.
    Makes you miss all of the grading curves you had back at school, but if you have patience and learn to start thinking like a computer, you will get the hang of it.
    Hi Peter,
