Sudden Impact Wearables Design Challenge
  • Sudden Impact Wearables Design Challenge
Forum Learning Single Board Computers
  • Replies 62 replies
  • Subscribers 6 subscribers
  • Views 8532 views
  • board
  • singleboardcomputer
  • raspberry
  • help
  • pi
  • computer
  • singleboard
  • single
  • raspberrypi
  • boardcomputer
Hello people of the element 14 community! My name is Nehemiah and I am 14 years old. Over the past two years I have been learning electronics such as arduino and a little bit of raspberry pi. I have made a few projects with my arduino (one being my science fair project) and want to do more advanced things. I watch this video by Ben Heck (https://www.youtube.com/watch?v=ZXllm5JWWAs&list=UUhturLXwYxwTOf_5krs0qvA) and wanted to do something similar to that. Could anyone give me a link to the explanation of single board computers and projects like that? That would be so helpful!
Thanks in advance,
Nehemiah
    dougw over 12 years ago +1
    If you want to try an ambitious retro build, the AIM 65 was a cool single board computer: The schematics are posted here: Rockwell AIM-65 and 6502 related devices Index of /aim65
    Index of /aim65
  • D_Hersey
    D_Hersey over 12 years ago in reply to dougw
    If you you are considering going w/ 6502, may I suggest 68HC09 or 68HC11?  Much more pleasant architecture in my humble opinion.  That said, I think the C64 was, and probably still is, one of the most truly utile computers ever.  They have firmware versions nowadays, I'm told.
    e14 Contributor over 12 years ago in reply to dougw
    Could you provide me with anymore information I have never done this before. Do I just wire it up and it works? Are these chips still available? Is there a simpler computer to start on? Thank you for your help because I would be very confused trying to look this up!
    Thanks in advance,
    Nehemiah Branson
    Maybe your next step should be a computer kit where the parts are supplied and there are instructions and support to help get it working.
    You could check out the Maximite Color Computer kit to see if it is about the right level.
    Note there are many variations of Maximite from several different suppliers so be sure to check which one looks most interesting to you.
  • Problemchild
    Problemchild over 12 years ago in reply to dougw
    I must agree with Douglas, a kit or a very well documented project would be the way to go.
  • Problemchild
    Problemchild over 12 years ago in reply to Problemchild
    I like the 68000  but that takes more wiring up and probably not a beginner project.
    What you will find is that many CPUs can be brought up and working with much less hardware than many projects use so may be look at minimum circuits to try first then build up.
    In the case of the 6502 here's a link to a whole page of projects that may wet your appetite
    http://www.6502.org/homebuilt/
  • Problemchild
    Just as some encouragement this was actually done in a week on some breadboard so even quite nice stuff can be made with simple tools no PCBs required
    http://www.bigmessowires.com/2014/11/04/breadboarding-the-68k/
    No need for yours to be this complex to work very well note that he's using static SRAM not dynamic ram as this makes life a lot easier and just works no memory controller required!
  • Problemchild
    And finally try NOS (New Old Stock ) or pulls there are lots of over priced stuff about but I found a reasonable price on a 6502 here
    http://www.ebay.co.uk/itm/Rockwell-R6502-CPU-/131330250274?pt=LH_DefaultDomain_0&hash=item1e93e49622
    Happy hunting, please put your beast up on the E14 site so we can all have a look...Cheers
    e14 Contributor over 12 years ago in reply to Problemchild
    From this page here (http://www.6502.org/homebuilt/) which one would be the best to start with? Also would I need an EPROM for anything? What does an EPROM do? How much would it cost approximately?
    Thanks for your help it is very much appreciated!
    Nehemiah
  • Problemchild
    Problemchild over 12 years ago in reply to e14 Contributor
    That might be the single most annoying thing as to use an EPROM  you'll need an EPROM programmer and eraser for all the mistakes you'll  make. Have a look at the projects listed and see what they are using and see if they offer the code already to put into an EPROM or FLASH etc.
    The EPROM programmer is about £30 and another £15ish for the eraser from say CPU Mall or EBAY
