Sudden Impact Wearables Design Challenge
  • Sudden Impact Wearables Design Challenge
Forum Learning Single Board Computers
  • Replies 62 replies
  • Subscribers 6 subscribers
  • Views 8261 views
  • board
  • singleboardcomputer
  • raspberry
  • help
  • pi
  • computer
  • singleboard
  • single
  • raspberrypi
  • boardcomputer
Hello people of the element 14 community! My name is Nehemiah and I am 14 years old. Over the past two years I have been learning electronics such as arduino and a little bit of raspberry pi. I have made a few projects with my arduino (one being my science fair project) and want to do more advanced things. I watch this video by Ben Heck (https://www.youtube.com/watch?v=ZXllm5JWWAs&list=UUhturLXwYxwTOf_5krs0qvA) and wanted to do something similar to that. Could anyone give me a link to the explanation of single board computers and projects like that? That would be so helpful!
Thanks in advance,
Nehemiah
    dougw over 11 years ago +1
    If you want to try an ambitious retro build, the AIM 65 was a cool single board computer: The schematics are posted here: Rockwell AIM-65 and 6502 related devices Index of /aim65
  • Problemchild
    Problemchild over 11 years ago in reply to e14 Contributor
    Nehemiah Branson wrote:
    I also am getting these parts for Christmas from my parents. I may be able to make two SBC's with two different processors!
    Thanks!
    When we were looking at programmers/erasers etc etc don't consider them in the price of this one build. Please think of them as a piece of equipment like a soldering Iron or meter or scope. They will last as long you could be building things using this kit in 20 years no problem.  My point is that if you or your parents can drop the extra few bucks on them it will make a big difference to succeeding  in the project. If you succeed then you will want to learn more and so on....Good luck
  • hawkeyethehacker
    hawkeyethehacker over 11 years ago
    As someone around the same age as you, this is a very ambitious project and I wish you luck.
    As a suggestion, I would look into EEPROM programmers and erasers as mentioned above by John. I personally use them all the time. It's the basic kit that you will use often.
    From experience, get a decent one, not just the cheapest. If you want to do this again in the future it pays off big time to future-proof your toolset.
    michaelkellett over 11 years ago in reply to Problemchild
    I haven't used an Eprom programmer for years and years - so I just dug it out for old times sake
    Found it but the batteries are dead - I'll see if the NiCad (yes it's that old) will come back to life but I'll need to solder in a new coin cell (it's soldered directly to the board).
    If I get it working I'll post about it.
    I only ever really used it on one job - then micros with built in flash came along.
  • hawkeyethehacker
    hawkeyethehacker over 11 years ago in reply to michaelkellett
    It depends what you want to do - some projects require EEPROMs a lot more than others.
  • Problemchild
    Problemchild over 11 years ago in reply to michaelkellett
    might make more of a post on how you cleaned the battery chemistry off the PCB of the programmer.
    Quite likely if it's that old... should be fun
    No leaks - but no charge retention. It's a Dataman S4 programmer and it has  a crackpot scheme where it can't start if the battery is completely flat. I connected it to a power supply, current limited to 150mA and the voltage rose to 9.4V (the limit I set almost immediately and the charge current after a few minutes was down to 6mA. I'm waiting to see what happens next but I'm expecting to need a new battery - £23 from Dataman or I can buy cells. Actually it seems you get ripped off buying cells in singles with tags so the cheapest option is to buy an 8 cell pack from CPC and chop one cell off (BT05358 @£21.91). (Farnell might have something but the web site won't respond).
    So that's £23.48 this thread has cost me so far image
  • Problemchild
    The CPC one is normally easier to use for stuff like that anyway . Could you of used a NIMH battery  I know the chemistry would of been different  just wondering ow aggressive the charging system is anyway?
    dougw over 11 years ago in reply to michaelkellett
    You might try rejuvenating the NiCads with some high current pulses. 1.5 A may not be enough to break down the crystalline formations and dendritic growth. But be careful not to overheat the battery...
    BU-807: How to Restore Nickel-based Batteries – Battery University
  • Problemchild
    Problemchild over 11 years ago in reply to dougw
    good point especially if he's able to get to each cell individually to give only the failed ones a blast
    The battery is very old and has been dead for ages so I'm not going to spend any more time on it. The charger is pretty crude (I think it just uses a low current) so I'll put  a set of NimH batteries in and see how it gets on.
    @ Douglas, Thanks for the link.
