Summer of Green Tech Design Challenge
  • Summer of Green Tech Design Challenge
Blog Blog #4: Integration of the Materials
Join Summer of Green Tech Design Challenge to participate - click to join for free!
  • Author Author: paulcastor30
  • Date Created: 19 Oct 2023 6:14 AM Date Created
  • Views 1121 views
  • seeeduino xiao
  • Seeed Studio XIAO SAMD21
  • summer of green tech design challenge
  • air quality
  • samd21
paulcastor30
paulcastor30
19 Oct 2023
This blog will discuss the integration of the required materials stated in Blog #2 and Blog #3. Below are the steps for integrating all the materials to develop our Seeeduino SAMD21-based Indoor Caron Dioxide Monitoring Device.
  • Prepare the required materials discussed in Blog #2.
  • Connect your sensors to the SAMD21 Microcontroller pins. Kindly follow the wiring diagram below.
  • Connect your Seeeduino XIAO SAMD21 Microcontroller to your PC or Laptop via a USB Type-C Cable.
  • Create a new Arduino Sketch and paste the following program below.
#include "Wire.h"
#include <MQ135.h>
#include <DHT.h>
#include <RGBLed.h>
#include <LiquidCrystal_I2C.h>
#define PIN_MQ135 A1
#define DHTTYPE DHT20
#define BUZZER 3
#define REDLED 10
#define GREENLED 9
#define BLUELED 8
LiquidCrystal_I2C lcd(0x27, 20, 4);
MQ135 mq135_sensor(PIN_MQ135);
DHT dht(DHTTYPE);
RGBLed led(REDLED, GREENLED, BLUELED, RGBLed::COMMON_ANODE);
unsigned long readMillis;
unsigned long currentMillis;
const unsigned long readPeriod = 2000;
int redcolor = 0;
int greencolor = 0;
int bluecolor = 0;
void setup() {
  analogReadResolution(12);
  Serial.begin(115200);
  lcd.init();
  Wire.begin();
  dht.begin();
  lcd.backlight();
  lcd.setCursor(1, 0);
  lcd.print("Indoor Air Quality");
  lcd.setCursor(1, 1);
  lcd.print("Monitoring  Device");
  lcd.setCursor(0, 2);
  lcd.print("System  Initializing");
  lcd.setCursor(0, 3);
  for (int i = 0; i < 20; i++)
    lcd.print(".");
    delay(100);
    lcd.print(" ");
    delay(100);
  lcd.setCursor(8, 3);
  lcd.print("DONE");
  delay(100);
  //lcd.setCursor(0, 0);
  //lcd.print("Real-time Air Status");
  readMillis = millis();
void loop() {
  currentMillis = millis();
  if (currentMillis - readMillis >= readPeriod) {
    float temp_hum_val[2] = {0};
    if (!dht.readTempAndHumidity(temp_hum_val)) {
      // do nothing
    float rzero = mq135_sensor.getRZero();
    float correctedRZero = mq135_sensor.getCorrectedRZero(temp_hum_val[1], temp_hum_val[0]);
    float resistance = mq135_sensor.getResistance();
    float ppm = mq135_sensor.getPPM();
    float correctedPPM = mq135_sensor.getCorrectedPPM(temp_hum_val[1], temp_hum_val[0]);
        Serial.print("MQ135 RZero: ");
        Serial.print(rzero);
        Serial.print("\t Corrected RZero: ");
        Serial.print(correctedRZero);
        Serial.print("\t Resistance: ");
        Serial.print(resistance);
        Serial.print("\t PPM: ");
        Serial.print(ppm);
        Serial.print("\t Corrected PPM: ");
        Serial.print(correctedPPM);
        Serial.println("ppm");
    lcd.clear();
    //delay(100);
    lcd.setCursor(3, 1);
    lcd.print("PPM: ");
    lcd.print(correctedPPM);
    lcd.print(" ppm");
    lcd.print("Temperature: ");
    lcd.print(temp_hum_val[1]);
    lcd.print(" C");
    lcd.setCursor(2, 3);
    lcd.print("Humidity: ");
    lcd.print(temp_hum_val[0]);
    lcd.print("%");
    float pm_sensor_reading = correctedPPM;
    if (pm_sensor_reading >= 0.0 && pm_sensor_reading <= 50.0) {
      lcd.setCursor(7, 0);
      lcd.print("Good");
      //aqi_cat[] = s"Good";
      redcolor = 0;
      greencolor = 228;
      bluecolor = 0;
      led.setColor(redcolor, greencolor, bluecolor); //green
      digitalWrite(BUZZER, LOW);
      Serial.println(F("Good"));
    else if (pm_sensor_reading >= 51.0 && pm_sensor_reading <= 100.0) {
      lcd.setCursor(6, 0);
      lcd.print("Moderate");
      //aqi_cat = "Moderate";
      redcolor = 255;
      greencolor = 255;
      bluecolor = 0;
      led.setColor(redcolor, greencolor, bluecolor); //yellow
      Serial.println(F("Moderate"));
    else if (pm_sensor_reading >= 101.0 && pm_sensor_reading <= 150.0) {
      lcd.setCursor(3, 0);
      lcd.print("Unhealthy for");
      lcd.setCursor(2, 1);
      lcd.print("Sensitive Groups");
      //aqi_cat = "Unhealthy for Sensitive Groups";
      redcolor = 255;
      greencolor = 126;
      bluecolor = 0;
      led.setColor(redcolor, greencolor, bluecolor); //orange
      Serial.println(F("Unhealthy for Sensitive Group"));
    else if (pm_sensor_reading >= 251.0 && pm_sensor_reading <= 200.0) {
      lcd.setCursor(5, 0);
      lcd.print("Unhealthy");
      //aqi_cat = "Unhealthy";
      redcolor = 255;
      greencolor = 0;
      bluecolor = 0;
      led.setColor(redcolor, greencolor, bluecolor); //red
      digitalWrite(BUZZER, HIGH);
      Serial.println(F("Unhealthy"));
    else if (pm_sensor_reading >= 201.0 && pm_sensor_reading <= 300.0) {
      lcd.print("Very Unhealthy");
      //aqi_cat = "Very Unhealthy";
      redcolor = 143;
      greencolor = 63;
      bluecolor = 151;
      led.setColor(redcolor, greencolor, bluecolor); //purple
      Serial.println(F("Very Unhealthy"));
    else if (pm_sensor_reading >= 301.0 && pm_sensor_reading <= 500.0) {
      lcd.print("Hazardous");
      //aqi_cat = "Hazardous";
      redcolor = 126;
      greencolor = 0;
      bluecolor = 35;
      led.setColor(redcolor, greencolor, bluecolor); //maroon
      Serial.println(F("Hazardous"));
    else if (pm_sensor_reading >= 501.0) {
      redcolor = 126;
      greencolor = 0;
      bluecolor = 35;
    else {
      redcolor = 0;
      greencolor = 0;
      bluecolor = 0;
      lcd.setCursor(8, 0);
      lcd.print("None");
      //aqi_cat = "None";
  • Save the Arduino sketch.
  • Upload the demo. If you do not know how to upload the code, please check how to upload the code.
  • Open the Serial Monitor of Arduino IDE by clicking Tool-> Serial Monitor. Or tap the CTRL+SHIFT+M keyboard keys at the same time. if everything goes well, you will get the readings.
    shabaz over 3 years ago +1
    There's nothing here. What's the purpose of this empty blog?
  • paulcastor30
    paulcastor30 over 3 years ago in reply to shabaz
    Sorry for the late reply. I already updated the blog. It has now all the contents necessary. Thank you very much.
  • paulcastor30
