Summer of Green Tech Design Challenge
  • Summer of Green Tech Design Challenge
Blog Recycled e-Scooter #3 Use arduino IDE with simpleFOC
Join Summer of Green Tech Design Challenge to participate - click to join for free!
  • Author Author: fyaocn
  • Date Created: 20 Sep 2023 2:08 AM Date Created
  • Views 1019 views
  • Likes 9 likes
fyaocn
fyaocn
20 Sep 2023
Table of Contents
  • 1 Use Arduino IDE
  • 2 Run Hall sensor example
  • 3 Simple FOC library and BLDC control
  • 4 Run the simpleFOC example
  • 5 Summary
1 Use Arduino IDE
With Seeed Xiao, Arduino IDE , MicroPython with Thonny IDE and CircuitPython can be used for development. Arduino is stil my first choice
Version: 2.2.1
Date: 2023-08-31T14:35:44.802Z
CLI Version: 0.34.0
Copyright © 2023 Arduino SA
Connect the  analogue Pin A0 in Xiao ,
Read the sensor value is output with serial ports
Install the simpleFOC library from library manager
The simpleFOC is open sourced library for BLDC motor control, this is key part in driving scooter.
Prepare the voltage control example and run it,
But the error pop out, some Parameter is not well defined. The reason is simple, Seed Xiao is not enlisted in the acceptable board, although the architecture of sam21 and sam51 is OK.
Find the keyword in board definition
and add the key word in the list.
Then the example passed.
5 Summary
The Seeed Xiao is easy to use and simple FOC provide ful feature in BLDC control algorithm. That is very good start for this project.
    dougw over 3 years ago
    Where is the Hall sensor mounted?
  • fyaocn
    fyaocn over 3 years ago in reply to dougw
    Hall sensor is used  for Positon detection for speed control.
