Blog Summer of Sensors Design Challenge - In The Air Tonight – Blog #8
  • DesignChallenge
  • Author Author: abhayrjoshi
  • Date Created: 13 Nov 2022 9:09 PM Date Created
  • Views 413 views
  • zmod4510
  • renesas
  • In the Air Tonight
abhayrjoshi
abhayrjoshi
13 Nov 2022
Challenger - ZMOD4510 - Outdoor Air Quality Sensor
Hello element14 Family,
Please find the code for the device constructed as a part of the Summer of Sensors Design Challenge.
Since the Renesas code was proprietary and was downloaded through a request on their portal, the license agreements will not allow me post it publicly on the forum.
However, I have indicated the sections where the downloaded library code can be directly included for reconstructing the results of this exercise.
Hardware:
  • Renesas ZMOD4510 EVK Outdoor Air Quality Sensor
  • Adafruit Feather M0 WiFi - ATSAMD21 + ATWINC1500
  • Adafruit FeatherWing OLED - 128x32 OLED Add-on For Feather
  • Adafruit Si7021 Temperature & Humidity Sensor Breakout Board
  • Adafruit Electret Microphone Amplifier - MAX4466 with Adjustable Gain
Software:
  • Arduino IDE
  • ZMOD4510 - OAQ 2nd Gen Firmware - Selective Ozone and Ultra-Low Power (request for secure access)
  • Library: Arduino SAMD Boards
  • Library: Adafruit SAMD Boards
  • Library: Adafruit SSD1306 (and associated dependencies)
  • Library: Adafruit Si7021 Library
  • Library: Blynk
Arduino Code:
/* Peronalized Air Quality & Sound Measurement Device
 * This file is part of the element14 Summer of Sensors Challenge
 * Category   : In The Air Tonight
 * Hardware   : Renesas ZMOD4510 Outdoor Air Quality Sensor
 * Due Date   : 17th of November, 2022
 * Authors    : Renesas Electronics Corporation, Ladyada, Abhay Joshi
 * Usage      : Search For Fields Labelled {USER INPUT:} & Input Relevant Data
 * This program is free software: you can redistribute it and/or modify
 * it under the terms of the GNU General Public License as published by
 * the Free Software Foundation, version 3.
 * This program is distributed in the hope that it will be useful, but
 * WITHOUT ANY WARRANTY; without even the implied warranty of
 * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU
 * General Public License for more details.
 * You should have received a copy of the GNU General Public License
 * along with this program. If not, see <http://www.gnu.org/licenses/>.
/* USER INPUT: Template ID, Device Name, Auth Token Provided By Blynk.Cloud */
#define BLYNK_TEMPLATE_ID  ""
#define BLYNK_DEVICE_NAME  ""
#define BLYNK_AUTH_TOKEN   ""
/* Comment This To Save Space */
#define BLYNK_PRINT        Serial
/*                            INCLUDES                             */
/* Includes For Adafruit OLED Featherwing */
#include <SPI.h>
#include <Wire.h>
#include <Adafruit_GFX.h>
#include <Adafruit_SSD1306.h>
/* Includes For Si7021 Temperature & Humidity Sensor */
#include "Adafruit_Si7021.h"
/* USER INPUT: Includes For ZMOD4510 Gas Sensor */
/* Includes For Blynk IoT Cloud Reporting */
#include <WiFi101.h>
#include <BlynkSimpleWiFiShield101.h>
/*                            MACROS                               */
/* OLED Display Width (Pixels) */
#define SCREEN_WIDTH        128
/* OLED Display Heighth (Pixels) */
#define SCREEN_HEIGHT       32
/* OLED Reset Pin (-1 If Sharing Arduino Reset Pin) */
#define OLED_RESET          -1
/* OLED I2C Address (Datasheet: 0x3C for 128x32) */
#define SCREEN_ADDRESS      0x3C
/* Read Battery Level */
/* Ref: https://learn.adafruit.com/adafruit-feather-m0-adalogger/power-management */
#define VBATPIN             A7
/* Read Microphone Level */
/* Ref: https://learn.adafruit.com/adafruit-microphone-amplifier-breakout/measuring-sound-levels */
#define MICROPHONE_PIN      A5
/*                           HANDLERS                              */
/* OLED Display */
Adafruit_SSD1306 display(SCREEN_WIDTH, SCREEN_HEIGHT, &Wire, OLED_RESET);
void error_handle();
/* Temperature & Humidity Sensor */
Adafruit_Si7021 sensor = Adafruit_Si7021();
/*                         GLOBAL VARIABLES                        */
/* USER INPUT: Variables Specific To ZMOD4510 Gas Sensor*/
/* Variables Specific To Environmental Sensor */
bool enableHeater = false;
/* Variables Specific To Electret Microphone */
const int sampleWindow = 50;   // Sample window width in mS (50 mS = 20Hz)
unsigned int sample;
/* Blynk.Cloud Authorization Token */
char auth[] = BLYNK_AUTH_TOKEN;
/* USER INPUT: WiFi Credentials */
char ssid[] = "";
char pass[] = "";
/*                            FUNCTIONS                            */
/*                              SETUP                              */
void setup()
    /* Initialize The Serial Port */
    Serial.begin(115200);
    /* Setup WiFi & Blynk.Cloud Interface */
    /* Ref: https://github.com/blynkkk/blynk-library/blob/master/examples/Boards_WiFi/Adafruit_Feather_M0_WiFi/Adafruit_Feather_M0_WiFi.ino */
    WiFi.setPins(8, 7, 4, 2);
    Blynk.begin(auth, ssid, pass);
    /* Delay For System Stability */
    delay(2000);
    /* Initialize The Temperature & Humidity Sensor */
    if (!sensor.begin())
      Serial.println("Si7021 Sensor Error!");
      for(;;); // Don't Proceed, Loop Forever
    /* Initialize The OLED Display */
    /* SSD1306_SWITCHCAPVCC - Generate Display Voltage From 3.3V Internally */
    if(!display.begin(SSD1306_SWITCHCAPVCC, SCREEN_ADDRESS))
        Serial.println(F("SSD1306 OLED Display Error"));
    display.clearDisplay();
    display.setTextSize(1);      // Normal 1:1 Pixel Scale
    display.setTextColor(SSD1306_WHITE); // Draw White Text
    display.setCursor(0, 0);     // Start At Top-left Corner
    display.cp437(true);         // Use Full 256 Char 'Code Page 437' Font
    /* Print A Welcome Message */
    display.println(F("Welcome To"));
    display.println(F("element14"));
    display.println(F("Summer of Sensors"));
    display.println(F("Design Challenge!\n"));
    display.display();
    delay(5000);
    display.setCursor(0, 10);
    display.println(F("In The Air Tonight..."));
    display.display();
    delay(100);
    /* Additional Delay For System Stability */
    delay(2000);
    Serial.println(F("Starting The ZMOD4510 Gas Sensor!"));
    /* USER INPUT: Enter The Setup Section Code Obtained From The Renesas Library */
/*                                LOOP                             */
void loop()
    Blynk.run();
    /* USER INPUT: Enter The Loop Section Code Obtained From The Renesas Library Download */
    /* Use sensor.readHumidity() & sensor.readTemperature() for algo_input */
    /* Report Battery Level */
    float measuredvbat = analogRead(VBATPIN);
    measuredvbat *= 2;    // we divided by 2, so multiply back
    measuredvbat *= 3.3;  // Multiply by 3.3V, our reference voltage
    measuredvbat /= 1024; // convert to voltage
    Serial.print(F("VBat = "));
    Serial.print(measuredvbat);
    unsigned long startMillis = millis();  // Start of sample window
    unsigned int peakToPeak = 0;           // peak-to-peak level
    unsigned int signalMax = 0;
    unsigned int signalMin = 1024;
    /* Collect Data For 50 Milliseconds */
    while (millis() - startMillis < sampleWindow) {
        sample = analogRead(MICROPHONE_PIN);
        if (sample < 1024) {
              if (sample > signalMax)  {
                  signalMax = sample;  // save just the max levels
              else if (sample < signalMin) {
                  signalMin = sample;  // save just the min levels
    /* Ref: https://forums.adafruit.com/viewtopic.php?f=8&t=100462&p=503661 */
    peakToPeak = signalMax - signalMin;  // max - min = peak-peak amplitude
    double volts = ((peakToPeak * 3.3) / 1024) * 0.707;  // convert to RMS voltage
    double first = log10(volts/0.00631)*20;
    double decibels = first + 94 - 44 - 25;
    display.println(F("In The Air Tonight"));
    /* Display & Report Temperature */
    display.print(F("T:"));
    display.print(sensor.readTemperature(), 2);
    Blynk.virtualWrite(V5, sensor.readTemperature());
    display.print(F("C "));
    /* Display & Report Relative Humidity */
    display.print(F("RH:"));
    display.print(sensor.readHumidity(), 2);
    Blynk.virtualWrite(V6, sensor.readHumidity());
    display.print(F("% "));
    /* Display & Report AQI */
    display.print(F("  AQI:"));
    if (lib_ret == OAQ_2ND_GEN_STABILIZATION) {
        display.print(F("Warming Up... "));
        /* Convey That The Sensor Is In Warm Up State */
        Blynk.virtualWrite(V7, -1);
    else {
        display.print(algo_results.EPA_AQI);
        Blynk.virtualWrite(V7, algo_results.EPA_AQI);
    display.println();
    /* Display & Report Noise Level (dB) */
    display.print(F("Noise:"));
    display.print(decibels);
    Blynk.virtualWrite(V8, decibels);
    display.print(F("dB "));
    /* Call The Drawing Function */
    display.display();
    delay(100);
    /* Issue A Low Battery Warning (400 mAh LiPo) */
    if(measuredvbat < 3.7) {
        display.setCursor(10, 10);
        display.println(F("CHARGE BATTERY NOW!"));
        display.display();
        /* Hold The Message On The Display For Some Time */
        delay(2000);
void error_handle()
    /* Implement Specific Error Handling Routines */
    while(1);
Next Blog Series: Summer of Sensors Design Challenge - In The Air Tonight – Blog #Final (Real-Time Solution Upgrades)
