Sustain The World - Design Challenge
  • Sustain The World - Design Challenge
Blog Sustain The World - Smart Portable Freezer #7 Porting XMC4200go into Arduino
  • Author Author: fyaocn
  • Date Created: 25 Sep 2020 5:21 AM Date Created
  • Views 643 views
fyaocn
fyaocn
25 Sep 2020
        • 1. What to do
        • 2. How to do
        • 3. Demo
        • 4. Next to do
1. What to do
It is fairly easy to use XMC4700Relax kit in arduino, but with XMC4200 Platform2GO. One can not help trying to use it in arduino as well. The official board packages skip XMC4200 Platform2GO, only XMC4400 Platform2GO is available. That is what I am going to do .
It takes 3 weeks to go with slow progress , it works and not so difficult.
2. How to do
2.1 First, check the datasheet of XMC4400 and XMC4200, only two different. More PWM function and Ethernet Porting added. The SRAM2 is included. The memory map shall be revised.
2.2 Then change the board.txt with added XMC4200 platform2Go
menu.UART=Serial Output Selection
menu.LIB=Additional Libraries
XMC1100_Boot_Kit.name=XMC1100 Boot Kit
XMC1100_Boot_Kit.upload.tool=xmcprog
XMC1100_Boot_Kit.upload.speed=115200
XMC1100_Boot_Kit.upload.resetmethod=ck
XMC1100_Boot_Kit.upload.maximum_size=65536
XMC1100_Boot_Kit.upload.wait_for_upload_port=true
XMC1100_Boot_Kit.communication=usb
XMC1100_Boot_Kit.protocol=dragon_isp
XMC1100_Boot_Kit.program.protocol=dragon_isp
XMC1100_Boot_Kit.program.tool=xmcprog
XMC1100_Boot_Kit.program.extra_params=-Pusb
XMC1100_Boot_Kit.serial.disableDTR=true
XMC1100_Boot_Kit.serial.disableRTS=true
XMC1100_Boot_Kit.build.mcu=cortex-m0
XMC1100_Boot_Kit.build.f_cpu=32000000L
XMC1100_Boot_Kit.build.board=ARM_XMC
XMC1100_Boot_Kit.build.board.version=1100
XMC1100_Boot_Kit.build.board.type=T038x0064
XMC1100_Boot_Kit.build.board.v=0064
XMC1100_Boot_Kit.build.core=./
XMC1100_Boot_Kit.build.variant=XMC1100
XMC1100_Boot_Kit.build.board_variant=XMC1100_Boot_Kit
XMC1100_Boot_Kit.build.flash_size=64K
XMC1100_Boot_Kit.build.flash_ld=linker_script.ld
XMC1100_Boot_Kit.build.extra_flags=-DARM_MATH_CM0 -DXMC1_SERIES
XMC1100_Boot_Kit.menu.UART.debug=PC
XMC1100_Boot_Kit.menu.UART.debug.uart.selected=-DSERIAL_HOSTPC
XMC1100_Boot_Kit.menu.UART.onBoard=On Board
XMC1100_Boot_Kit.menu.UART.onBoard.uart.selected=-DSERIAL_ONBOARD
XMC1100_Boot_Kit.menu.LIB.NONE=None
XMC1100_Boot_Kit.menu.LIB.NONE.library.selected=
XMC1100_Boot_Kit.menu.LIB.NN=ARM NN Framework
XMC1100_Boot_Kit.menu.LIB.NN.library.selected=-DARM_LIB_CMSIS_NN
XMC1100_Boot_Kit.menu.LIB.DSP=ARM DSP
XMC1100_Boot_Kit.menu.LIB.DSP.library.selected=-DARM_LIB_CMSIS_DSP
XMC1100_Boot_Kit.menu.LIB.DSPNN=ARM DSP / ARM NN Framework
XMC1100_Boot_Kit.menu.LIB.DSPNN.library.selected=-DARM_LIB_CMSIS_DSP -DARM_LIB_CMSIS_NN
XMC1100_XMC2GO.name=XMC1100 XMC2Go
XMC1100_XMC2GO.upload.tool=xmcprog
XMC1100_XMC2GO.upload.speed=115200
XMC1100_XMC2GO.upload.resetmethod=ck
XMC1100_XMC2GO.upload.maximum_size=65536
XMC1100_XMC2GO.upload.wait_for_upload_port=true
XMC1100_XMC2GO.communication=usb
XMC1100_XMC2GO.protocol=dragon_isp
XMC1100_XMC2GO.program.protocol=dragon_isp
XMC1100_XMC2GO.program.tool=xmcprog
XMC1100_XMC2GO.program.extra_params=-Pusb
XMC1100_XMC2GO.serial.disableDTR=true
XMC1100_XMC2GO.serial.disableRTS=true
XMC1100_XMC2GO.build.mcu=cortex-m0
XMC1100_XMC2GO.build.f_cpu=32000000L
XMC1100_XMC2GO.build.board=ARM_XMC
XMC1100_XMC2GO.build.board.version=1100
XMC1100_XMC2GO.build.board.type=T038x0064
XMC1100_XMC2GO.build.board.v=0064
XMC1100_XMC2GO.build.core=./
XMC1100_XMC2GO.build.variant=XMC1100
XMC1100_XMC2GO.build.board_variant=XMC1100_XMC2GO
XMC1100_XMC2GO.build.flash_size=64K
XMC1100_XMC2GO.build.flash_ld=linker_script.ld
XMC1100_XMC2GO.build.extra_flags=-DARM_MATH_CM0 -DXMC1_SERIES
XMC1100_XMC2GO.menu.UART.debug=PC
XMC1100_XMC2GO.menu.UART.debug.uart.selected=-DSERIAL_HOSTPC
XMC1100_XMC2GO.menu.UART.onBoard=On Board
XMC1100_XMC2GO.menu.UART.onBoard.uart.selected=-DSERIAL_ONBOARD
XMC1100_XMC2GO.menu.LIB.NONE=None
XMC1100_XMC2GO.menu.LIB.NONE.library.selected=
XMC1100_XMC2GO.menu.LIB.NN=ARM NN Framework
XMC1100_XMC2GO.menu.LIB.NN.library.selected=-DARM_LIB_CMSIS_NN
XMC1100_XMC2GO.menu.LIB.DSP=ARM DSP
XMC1100_XMC2GO.menu.LIB.DSP.library.selected=-DARM_LIB_CMSIS_DSP
XMC1100_XMC2GO.menu.LIB.DSPNN=ARM DSP / ARM NN Framework
XMC1100_XMC2GO.menu.LIB.DSPNN.library.selected=-DARM_LIB_CMSIS_DSP -DARM_LIB_CMSIS_NN
XMC1100_H_BRIDGE2GO.name=XMC1100 H-Bridge 2Go
XMC1100_H_BRIDGE2GO.upload.tool=xmcprog
XMC1100_H_BRIDGE2GO.upload.speed=115200
XMC1100_H_BRIDGE2GO.upload.resetmethod=ck
XMC1100_H_BRIDGE2GO.upload.maximum_size=65536
XMC1100_H_BRIDGE2GO.upload.wait_for_upload_port=true
XMC1100_H_BRIDGE2GO.communication=usb
XMC1100_H_BRIDGE2GO.protocol=dragon_isp
XMC1100_H_BRIDGE2GO.program.protocol=dragon_isp
XMC1100_H_BRIDGE2GO.program.tool=xmcprog
XMC1100_H_BRIDGE2GO.program.extra_params=-Pusb
XMC1100_H_BRIDGE2GO.serial.disableDTR=true
XMC1100_H_BRIDGE2GO.serial.disableRTS=true
XMC1100_H_BRIDGE2GO.build.mcu=cortex-m0
XMC1100_H_BRIDGE2GO.build.f_cpu=32000000L
XMC1100_H_BRIDGE2GO.build.board=ARM_XMC
XMC1100_H_BRIDGE2GO.build.board.version=1100
XMC1100_H_BRIDGE2GO.build.board.type=T038x0064
XMC1100_H_BRIDGE2GO.build.board.v=0064
XMC1100_H_BRIDGE2GO.build.core=./
XMC1100_H_BRIDGE2GO.build.variant=XMC1100
XMC1100_H_BRIDGE2GO.build.board_variant=XMC1100_H_BRIDGE2GO
XMC1100_H_BRIDGE2GO.build.flash_size=64K
XMC1100_H_BRIDGE2GO.build.flash_ld=linker_script.ld
XMC1100_H_BRIDGE2GO.build.extra_flags=-DARM_MATH_CM0 -DXMC1_SERIES
XMC1100_H_BRIDGE2GO.menu.UART.debug=PC
XMC1100_H_BRIDGE2GO.menu.UART.debug.uart.selected=-DSERIAL_ONBOARD
XMC1100_H_BRIDGE2GO.menu.UART.onBoard=On Board
XMC1100_H_BRIDGE2GO.menu.UART.onBoard.uart.selected=-DSERIAL_ONBOARD
XMC1100_H_BRIDGE2GO.menu.LIB.NONE=None
XMC1100_H_BRIDGE2GO.menu.LIB.NONE.library.selected=
XMC1100_H_BRIDGE2GO.menu.LIB.NN=ARM NN Framework
XMC1100_H_BRIDGE2GO.menu.LIB.NN.library.selected=-DARM_LIB_CMSIS_NN
XMC1100_H_BRIDGE2GO.menu.LIB.DSP=ARM DSP
XMC1100_H_BRIDGE2GO.menu.LIB.DSP.library.selected=-DARM_LIB_CMSIS_DSP
XMC1100_H_BRIDGE2GO.menu.LIB.DSPNN=ARM DSP / ARM NN Framework
XMC1100_H_BRIDGE2GO.menu.LIB.DSPNN.library.selected=-DARM_LIB_CMSIS_DSP -DARM_LIB_CMSIS_NN
XMC1300_Boot_Kit.name=XMC1300 Boot Kit
XMC1300_Boot_Kit.upload.tool=xmcprog
XMC1300_Boot_Kit.upload.speed=115200
XMC1300_Boot_Kit.upload.resetmethod=ck
XMC1300_Boot_Kit.upload.maximum_size=65536
XMC1300_Boot_Kit.upload.wait_for_upload_port=true
XMC1300_Boot_Kit.communication=usb
XMC1300_Boot_Kit.protocol=dragon_isp
XMC1300_Boot_Kit.program.protocol=dragon_isp
XMC1300_Boot_Kit.program.tool=xmcprog
XMC1300_Boot_Kit.program.extra_params=-Pusb
XMC1300_Boot_Kit.serial.disableDTR=true
XMC1300_Boot_Kit.serial.disableRTS=true
XMC1300_Boot_Kit.build.mcu=cortex-m0
XMC1300_Boot_Kit.build.f_cpu=32000000L
XMC1300_Boot_Kit.build.board=ARM_XMC
XMC1300_Boot_Kit.build.board.version=1302
XMC1300_Boot_Kit.build.board.type=T038x0200
XMC1300_Boot_Kit.build.board.v=0200
XMC1300_Boot_Kit.build.core=./
XMC1300_Boot_Kit.build.variant=XMC1300
XMC1300_Boot_Kit.build.board_variant=XMC1300_Boot_Kit
XMC1300_Boot_Kit.build.flash_size=64K
XMC1300_Boot_Kit.build.flash_ld=linker_script.ld
XMC1300_Boot_Kit.build.extra_flags=-DARM_MATH_CM0 -DXMC1_SERIES
XMC1300_Boot_Kit.menu.UART.debug=PC
XMC1300_Boot_Kit.menu.UART.debug.uart.selected=-DSERIAL_HOSTPC
XMC1300_Boot_Kit.menu.UART.onBoard=On Board
XMC1300_Boot_Kit.menu.UART.onBoard.uart.selected=-DSERIAL_ONBOARD
XMC1300_Boot_Kit.menu.LIB.NONE=None
XMC1300_Boot_Kit.menu.LIB.NONE.library.selected=
XMC1300_Boot_Kit.menu.LIB.NN=ARM NN Framework
XMC1300_Boot_Kit.menu.LIB.NN.library.selected=-DARM_LIB_CMSIS_NN
XMC1300_Boot_Kit.menu.LIB.DSP=ARM DSP
XMC1300_Boot_Kit.menu.LIB.DSP.library.selected=-DARM_LIB_CMSIS_DSP
XMC1300_Boot_Kit.menu.LIB.DSPNN=ARM DSP / ARM NN Framework
XMC1300_Boot_Kit.menu.LIB.DSPNN.library.selected=-DARM_LIB_CMSIS_DSP -DARM_LIB_CMSIS_NN
XMC1300_Sense2GoL.name=XMC1300 Sense2GoL
XMC1300_Sense2GoL.upload.tool=xmcprog
XMC1300_Sense2GoL.upload.speed=115200
XMC1300_Sense2GoL.upload.resetmethod=ck
XMC1300_Sense2GoL.upload.maximum_size=125160
XMC1300_Sense2GoL.upload.wait_for_upload_port=true
XMC1300_Sense2GoL.communication=usb
XMC1300_Sense2GoL.protocol=dragon_isp
XMC1300_Sense2GoL.program.protocol=dragon_isp
XMC1300_Sense2GoL.program.tool=xmcprog
XMC1300_Sense2GoL.program.extra_params=-Pusb
XMC1300_Sense2GoL.serial.disableDTR=true
XMC1300_Sense2GoL.serial.disableRTS=true
XMC1300_Sense2GoL.build.mcu=cortex-m0
XMC1300_Sense2GoL.build.f_cpu=32000000L
XMC1300_Sense2GoL.build.board=ARM_XMC
XMC1300_Sense2GoL.build.board.version=1302
XMC1300_Sense2GoL.build.board.type=T038x0064
XMC1300_Sense2GoL.build.board.v=0032
XMC1300_Sense2GoL.build.core=./
XMC1300_Sense2GoL.build.variant=XMC1300
XMC1300_Sense2GoL.build.board_variant=XMC1300_Sense2GoL
XMC1300_Sense2GoL.build.flash_size=64K
XMC1300_Sense2GoL.build.flash_ld=linker_script.ld
XMC1300_Sense2GoL.build.extra_flags=-DARM_MATH_CM0 -DXMC1_SERIES
XMC1300_Sense2GoL.menu.LIB.DSPNN=ARM DSP / ARM NN Framework
XMC1300_Sense2GoL.menu.LIB.DSPNN.library.selected=-DARM_LIB_CMSIS_DSP -DARM_LIB_CMSIS_NN
XMC1300_Sense2GoL.menu.LIB.NONE=None
XMC1300_Sense2GoL.menu.LIB.NONE.library.selected=
XMC1300_Sense2GoL.menu.LIB.NN=ARM NN Framework
XMC1300_Sense2GoL.menu.LIB.NN.library.selected=-DARM_LIB_CMSIS_NN
XMC1300_Sense2GoL.menu.LIB.DSP=ARM DSP
XMC1300_Sense2GoL.menu.LIB.DSP.library.selected=-DARM_LIB_CMSIS_DSP
#XMC1400_Boot_Kit.name=XMC1400 Boot Kit
#XMC1400_Boot_Kit.upload.tool=xmcprog
#XMC1400_Boot_Kit.upload.speed=115200
#XMC1400_Boot_Kit.upload.resetmethod=ck
#XMC1400_Boot_Kit.upload.maximum_size=2048000
#XMC1400_Boot_Kit.upload.wait_for_upload_port=true
#XMC1400_Boot_Kit.communication=usb
#XMC1400_Boot_Kit.protocol=dragon_isp
#XMC1400_Boot_Kit.program.protocol=dragon_isp
#XMC1400_Boot_Kit.program.tool=xmcprog
#XMC1400_Boot_Kit.program.extra_params=-Pusb
#XMC1400_Boot_Kit.serial.disableDTR=true
#XMC1400_Boot_Kit.serial.disableRTS=true
#XMC1400_Boot_Kit.build.mcu=cortex-m0
#XMC1400_Boot_Kit.build.f_cpu=48000000L
#XMC1400_Boot_Kit.build.board=ARM_XMC
#XMC1400_Boot_Kit.build.board.version=1404
#XMC1400_Boot_Kit.build.board.type=Q064x0200
#XMC1400_Boot_Kit.build.board.v=0200
#XMC1400_Boot_Kit.build.core=./
#XMC1400_Boot_Kit.build.variant=XMC1400
#XMC1400_Boot_Kit.build.board_variant=XMC1400_Boot_Kit
#XMC1400_Boot_Kit.build.flash_size=200K
#XMC1400_Boot_Kit.build.flash_ld=linker_script.ld
#XMC1400_Boot_Kit.build.extra_flags=-DARM_MATH_CM0 -DXMC1_SERIES
#XMC1400_Boot_Kit.menu.UART.debug=PC
#XMC1400_Boot_Kit.menu.UART.debug.uart.selected=-DSERIAL_HOSTPC
#XMC1400_Boot_Kit.menu.UART.onBoard=On Board
#XMC1400_Boot_Kit.menu.UART.onBoard.uart.selected=-DSERIAL_ONBOARD
#XMC1400_Boot_Kit.menu.LIB.NONE=None
#XMC1400_Boot_Kit.menu.LIB.NONE.library.selected=
#XMC1400_Boot_Kit.menu.LIB.NN=ARM NN Framework
#XMC1400_Boot_Kit.menu.LIB.NN.library.selected=-DARM_LIB_CMSIS_NN
#XMC1400_Boot_Kit.menu.LIB.DSP=ARM DSP
#XMC1400_Boot_Kit.menu.LIB.DSP.library.selected=-DARM_LIB_CMSIS_DSP
#XMC1400_Boot_Kit.menu.LIB.DSPNN=ARM DSP / ARM NN Framework
#XMC1400_Boot_Kit.menu.LIB.DSPNN.library.selected=-DARM_LIB_CMSIS_DSP -DARM_LIB_CMSIS_NN
XMC4200_Platform2GO.name=XMC4200 Platform 2GO
XMC4200_Platform2GO.upload.tool=xmcprog
XMC4200_Platform2GO.upload.speed=115200
XMC4200_Platform2GO.upload.resetmethod=ck
XMC4200_Platform2GO.upload.maximum_size=256000
XMC4200_Platform2GO.upload.wait_for_upload_port=true
XMC4200_Platform2GO.communication=usb
XMC4200_Platform2GO.protocol=dragon_isp
XMC4200_Platform2GO.program.protocol=dragon_isp
XMC4200_Platform2GO.program.tool=xmcprog
XMC4200_Platform2GO.program.extra_params=-Pusb
XMC4200_Platform2GO.serial.disableDTR=true
XMC4200_Platform2GO.serial.disableRTS=true
XMC4200_Platform2GO.build.mcu=cortex-m4
XMC4200_Platform2GO.build.f_cpu=80000000L
XMC4200_Platform2GO.build.board=ARM_XMC
XMC4200_Platform2GO.build.board.version=4200
XMC4200_Platform2GO.build.board.type=F64x256
XMC4200_Platform2GO.build.board.v=256
XMC4200_Platform2GO.build.core=./
XMC4200_Platform2GO.build.variant=XMC4200
XMC4200_Platform2GO.build.board_variant=XMC4200_Platform2GO
XMC4200_Platform2GO.build.flash_size=250K
XMC4200_Platform2GO.build.flash_ld=linker_script.ld
XMC4200_Platform2GO.build.extra_flags=-DARM_MATH_CM4 -DARM_MATH_DSP
#-DUSB0
XMC4200_Platform2GO.menu.UART.debug=PC
XMC4200_Platform2GO.menu.UART.debug.uart.selected=-DSERIAL_HOSTPC
XMC4200_Platform2GO.menu.UART.onBoard=On Board
XMC4200_Platform2GO.menu.UART.onBoard.uart.selected=-DSERIAL_ONBOARD
XMC4200_Platform2GO.menu.LIB.NONE=None
XMC4200_Platform2GO.menu.LIB.NONE.library.selected=
XMC4200_Platform2GO.menu.LIB.DSPNN=ARM DSP / ARM NN Framework
XMC4200_Platform2GO.menu.LIB.DSPNN.library.selected=-DARM_LIB_CMSIS_DSP -DARM_LIB_CMSIS_NN
XMC4200_Platform2GO.menu.LIB.NN=ARM NN Framework
XMC4200_Platform2GO.menu.LIB.NN.library.selected=-DARM_LIB_CMSIS_NN
XMC4200_Platform2GO.menu.LIB.DSP=ARM DSP
XMC4200_Platform2GO.menu.LIB.DSP.library.selected=-DARM_LIB_CMSIS_DSP
XMC4400_Platform2GO.name=XMC4400 Platform 2GO
XMC4400_Platform2GO.upload.tool=xmcprog
XMC4400_Platform2GO.upload.speed=115200
XMC4400_Platform2GO.upload.resetmethod=ck
XMC4400_Platform2GO.upload.maximum_size=512000
XMC4400_Platform2GO.upload.wait_for_upload_port=true
XMC4400_Platform2GO.communication=usb
XMC4400_Platform2GO.protocol=dragon_isp
XMC4400_Platform2GO.program.protocol=dragon_isp
XMC4400_Platform2GO.program.tool=xmcprog
XMC4400_Platform2GO.program.extra_params=-Pusb
XMC4400_Platform2GO.serial.disableDTR=true
XMC4400_Platform2GO.serial.disableRTS=true
XMC4400_Platform2GO.build.mcu=cortex-m4
XMC4400_Platform2GO.build.f_cpu=144000000L
XMC4400_Platform2GO.build.board=ARM_XMC
XMC4400_Platform2GO.build.board.version=4400
XMC4400_Platform2GO.build.board.type=F100x512
XMC4400_Platform2GO.build.board.v=512
XMC4400_Platform2GO.build.core=./
XMC4400_Platform2GO.build.variant=XMC4400
XMC4400_Platform2GO.build.board_variant=XMC4400_Platform2GO
XMC4400_Platform2GO.build.flash_size=500K
XMC4400_Platform2GO.build.flash_ld=linker_script.ld
XMC4400_Platform2GO.build.extra_flags=-DARM_MATH_CM4 -DARM_MATH_DSP
#-DUSB0
XMC4400_Platform2GO.menu.UART.debug=PC
XMC4400_Platform2GO.menu.UART.debug.uart.selected=-DSERIAL_HOSTPC
XMC4400_Platform2GO.menu.UART.onBoard=On Board
XMC4400_Platform2GO.menu.UART.onBoard.uart.selected=-DSERIAL_ONBOARD
XMC4400_Platform2GO.menu.LIB.NONE=None
XMC4400_Platform2GO.menu.LIB.NONE.library.selected=
XMC4400_Platform2GO.menu.LIB.DSPNN=ARM DSP / ARM NN Framework
XMC4400_Platform2GO.menu.LIB.DSPNN.library.selected=-DARM_LIB_CMSIS_DSP -DARM_LIB_CMSIS_NN
XMC4400_Platform2GO.menu.LIB.NN=ARM NN Framework
XMC4400_Platform2GO.menu.LIB.NN.library.selected=-DARM_LIB_CMSIS_NN
XMC4400_Platform2GO.menu.LIB.DSP=ARM DSP
XMC4400_Platform2GO.menu.LIB.DSP.library.selected=-DARM_LIB_CMSIS_DSP
XMC4700_Radar_Baseboard.name=DEMO Radar BB XMC4700
XMC4700_Radar_Baseboard.upload.tool=xmcprog
XMC4700_Radar_Baseboard.upload.speed=115200
XMC4700_Radar_Baseboard.upload.resetmethod=ck
XMC4700_Radar_Baseboard.upload.maximum_size=2048000
XMC4700_Radar_Baseboard.upload.wait_for_upload_port=true
XMC4700_Radar_Baseboard.communication=usb
XMC4700_Radar_Baseboard.protocol=dragon_isp
XMC4700_Radar_Baseboard.program.protocol=dragon_isp
XMC4700_Radar_Baseboard.program.tool=xmcprog
XMC4700_Radar_Baseboard.program.extra_params=-Pusb
XMC4700_Radar_Baseboard.serial.disableDTR=true
XMC4700_Radar_Baseboard.serial.disableRTS=true
XMC4700_Radar_Baseboard.build.mcu=cortex-m4
XMC4700_Radar_Baseboard.build.f_cpu=144000000L
XMC4700_Radar_Baseboard.build.board=ARM_XMC
XMC4700_Radar_Baseboard.build.board.version=4700
XMC4700_Radar_Baseboard.build.board.type=E196x2048
XMC4700_Radar_Baseboard.build.board.v=2048
XMC4700_Radar_Baseboard.build.core=./
XMC4700_Radar_Baseboard.build.variant=XMC4700
XMC4700_Radar_Baseboard.build.board_variant=XMC4700_Radar_Baseboard
XMC4700_Radar_Baseboard.build.flash_size=2000K
XMC4700_Radar_Baseboard.build.flash_ld=linker_script.ld
XMC4700_Radar_Baseboard.build.extra_flags=-DARM_MATH_CM4 -DINTERRUPT_USE_ERU -DSERIAL_USE_U1C1 -DXMC4_SERIES
XMC4700_Radar_Baseboard.menu.LIB.DSPNN=ARM DSP / ARM NN Framework
XMC4700_Radar_Baseboard.menu.LIB.DSPNN.library.selected=-DARM_LIB_CMSIS_DSP -DARM_LIB_CMSIS_NN
XMC4700_Radar_Baseboard.menu.LIB.NONE=None
XMC4700_Radar_Baseboard.menu.LIB.NONE.library.selected=
XMC4700_Radar_Baseboard.menu.LIB.NN=ARM NN Framework
XMC4700_Radar_Baseboard.menu.LIB.NN.library.selected=-DARM_LIB_CMSIS_NN
XMC4700_Radar_Baseboard.menu.LIB.DSP=ARM DSP
XMC4700_Radar_Baseboard.menu.LIB.DSP.library.selected=-DARM_LIB_CMSIS_DSP
XMC4700_Relax_Kit.name=XMC4700 Relax Kit
XMC4700_Relax_Kit.upload.tool=xmcprog
XMC4700_Relax_Kit.upload.speed=115200
XMC4700_Relax_Kit.upload.resetmethod=ck
XMC4700_Relax_Kit.upload.maximum_size=2048000
XMC4700_Relax_Kit.upload.wait_for_upload_port=true
XMC4700_Relax_Kit.communication=usb
XMC4700_Relax_Kit.protocol=dragon_isp
XMC4700_Relax_Kit.program.protocol=dragon_isp
XMC4700_Relax_Kit.program.tool=xmcprog
XMC4700_Relax_Kit.program.extra_params=-Pusb
XMC4700_Relax_Kit.serial.disableDTR=true
XMC4700_Relax_Kit.serial.disableRTS=true
XMC4700_Relax_Kit.build.mcu=cortex-m4
XMC4700_Relax_Kit.build.f_cpu=144000000L
XMC4700_Relax_Kit.build.board=ARM_XMC
XMC4700_Relax_Kit.build.board.version=4700
XMC4700_Relax_Kit.build.board.type=F144x2048
XMC4700_Relax_Kit.build.board.v=2048
XMC4700_Relax_Kit.build.core=./
XMC4700_Relax_Kit.build.variant=XMC4700
XMC4700_Relax_Kit.build.board_variant=XMC4700_Relax_Kit
XMC4700_Relax_Kit.build.flash_size=2000K
XMC4700_Relax_Kit.build.flash_ld=linker_script.ld
XMC4700_Relax_Kit.build.extra_flags=-DARM_MATH_CM4 -DXMC4_SERIES
XMC4700_Relax_Kit.menu.LIB.DSPNN=ARM DSP / ARM NN Framework
XMC4700_Relax_Kit.menu.LIB.DSPNN.library.selected=-DARM_LIB_CMSIS_DSP -DARM_LIB_CMSIS_NN
XMC4700_Relax_Kit.menu.LIB.NONE=None
XMC4700_Relax_Kit.menu.LIB.NONE.library.selected=
XMC4700_Relax_Kit.menu.LIB.NN=ARM NN Framework
XMC4700_Relax_Kit.menu.LIB.NN.library.selected=-DARM_LIB_CMSIS_NN
XMC4700_Relax_Kit.menu.LIB.DSP=ARM DSP
XMC4700_Relax_Kit.menu.LIB.DSP.library.selected=-DARM_LIB_CMSIS_DSP
# Not up to date
#XMC4800_Relax_Kit.name=XMC4800 Relax Kit
#XMC4800_Relax_Kit.upload.tool=xmcprog
#XMC4800_Relax_Kit.upload.speed=115200
#XMC4800_Relax_Kit.upload.resetmethod=ck
#XMC4800_Relax_Kit.upload.maximum_size=2000000
#XMC4800_Relax_Kit.upload.maximum_data_size=352000
#XMC4800_Relax_Kit.upload.wait_for_upload_port=true
#XMC4800_Relax_Kit.communication=usb
#XMC4800_Relax_Kit.protocol=dragon_isp
#XMC4800_Relax_Kit.program.protocol=dragon_isp
#XMC4800_Relax_Kit.program.tool=xmcprog
#XMC4800_Relax_Kit.program.extra_params=-Pusb
#XMC4800_Relax_Kit.serial.disableDTR=true
#XMC4800_Relax_Kit.serial.disableRTS=true
#XMC4800_Relax_Kit.build.mcu=cortex-m4
#XMC4800_Relax_Kit.build.f_cpu=144000000L
#XMC4800_Relax_Kit.build.board=ARM_XMC
#XMC4800_Relax_Kit.build.board.version=4800
#XMC4800_Relax_Kit.build.board.type=F144x2048
#XMC4800_Relax_Kit.build.board.v=2048
#XMC4800_Relax_Kit.build.core=./
#XMC4800_Relax_Kit.build.variant=XMC4800
#XMC4800_Relax_Kit.build.board_variant=XMC4800_Relax_Kit
#XMC4800_Relax_Kit.build.flash_size=2000K
#XMC4800_Relax_Kit.build.flash_ld=linker_script.ld
#XMC4800_Relax_Kit.build.extra_flags=-DARM_MATH_CM4 -DXMC4_SERIES
#XMC4800_Relax_Kit.menu.LIB.DSPNN=ARM DSP / ARM NN Framework
#XMC4800_Relax_Kit.menu.LIB.DSPNN.library.selected=-DARM_LIB_CMSIS_DSP -DARM_LIB_CMSIS_NN
#XMC4800_Relax_Kit.menu.LIB.NONE=None
#XMC4800_Relax_Kit.menu.LIB.NONE.library.selected=
#XMC4800_Relax_Kit.menu.LIB.NN=ARM NN Framework
#XMC4800_Relax_Kit.menu.LIB.NN.library.selected=-DARM_LIB_CMSIS_NN
#XMC4800_Relax_Kit.menu.LIB.DSP=ARM DSP
#XMC4800_Relax_Kit.menu.LIB.DSP.library.selected=-DARM_LIB_CMSIS_DSP
Now , you have the board available.
2.2 Then copy the directory of \XMC4400 and rename into \XMC4200. Revise the file name and include code accordingly. Following the error report from arduino IDE when build one empty sketch file is enough.
2.3 Revise the file pins_arduino.h as follows,
  pins_arduino.h - Pin definition functions for Arduino
  Part of Arduino - http://www.arduino.cc/
  Copyright (c) 2007 David A. Mellis
  This library is free software; you can redistribute it and/or
  modify it under the terms of the GNU Lesser General Public
  License as published by the Free Software Foundation; either
  version 2.1 of the License, or (at your option) any later version.
  This library is distributed in the hope that it will be useful,
  but WITHOUT ANY WARRANTY; without even the implied warranty of
  MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the GNU
  Lesser General Public License for more details.
  You should have received a copy of the GNU Lesser General
  Public License along with this library; if not, write to the
  Free Software Foundation, Inc., 59 Temple Place, Suite 330,
  Boston, MA  02111-1307  USA
  Copyright (c) 2019 Infineon Technologies AG
  This file has been modified for the XMC microcontroller series.
#ifndef PINS_ARDUINO_H_
#define PINS_ARDUINO_H_
// @Project Includes
#include <XMC4200.h>
// @Defines
#define XMC_BOARD XMC 4200 Platform 2GO
/* On board LED is ON when digital output is 0, LOW, False, OFF */
#define XMC_LED_ON   0
#define NUM_ANALOG_INPUTS 6
#define NUM_PWM     6
#define NUM_INTERRUPT   2
#define NUM_SERIAL   1
#define NUM_TONE_PINS   16
#define NUM_TASKS_VARIANT 32
// Indicate unit has RTC/Alarm
#define HAS_RTC     1
//Serial ports
#define PWM4_TIMER_PERIOD (0x11EF) //Generate 490Hz @fCCU=144MHz
#define PWM8_TIMER_PERIOD (0x11EF)  // Generate 490Hz @fCCU=144MHz
#define PCLK 64000000u
#define PIN_SPI_SS 10
#define PIN_SPI_MOSI 11
#define PIN_SPI_MISO  12
#define PIN_SPI_SCK 13
extern uint8_t SS;
extern uint8_t MOSI;
extern uint8_t MISO;
extern uint8_t SCK;
#define A0 0 //ADC G0CH0 P14.0
#define A1 1 //ADC G0CH1 P14.1
#define A2 2 //ADC G0CH2 P14.2
#define A3 3 //ADC G0CH3 P14.3
#define A4 4 //ADC G0CH4 P14.4
#define A5 5 //ADC G0CH5 P14.5
//Additional ADC ports starting here
#define LED_BUILTIN 71 //Standard Arduino LED: Used LED1
#define LED1     71 //Additional LED1
#define BUTTON1   52 //Additional BUTTON1
#define GND     94 //GND
#define digitalPinToInterrupt(p)    ((p) == 2 ? 0 : ((p) == 3 ? 1 : NOT_AN_INTERRUPT))
#ifdef ARDUINO_MAIN
/* Mapping of Arduino Pins to PWM4 channels as pin and PWM4 channel
   last entry 255 for both parts.
   Putting both parts in array means if a PWM4 channel gets reassigned for
   another function later a gap in channel numbers will not mess things up */
const uint8_t mapping_pin_PWM4[][ 2 ] = {
                                        { 3, 0 },
                                        { 5, 1 },
                                        { 6, 2 },
                                        { 11, 3 },
                                        { 27, 4 },
                                        { 28, 5 },
                                        { 57, 6 },
                    { 58, 7 },
                                        { 255, 255 } };
const uint8_t mapping_pin_PWM8[][ 2 ] = {
                                        { 9,  0 },
                                        { 10, 1 },
                    { 26, 2 },
                                        { 29, 3 },
                    { 30, 4 },
                                        { 54, 5 },
                    { 55, 6 },
                    { 59, 7 },
                                        { 86, 8 },
                                        { 255, 255 } };
const uint8_t mapping_pin_DAC[][ 2 ] = {
                                        { 61, 0 },
                                        { 94, 1 },
                                        { 255, 255 } };
const XMC_PORT_PIN_t mapping_port_pin[]=
  /* 0  */   {XMC_GPIO_PORT2 , 15}, //RX                       P2.15
  /* 1  */   {XMC_GPIO_PORT2 , 14}, //TX                       P2.14
  /* 2  */    {XMC_GPIO_PORT1 , 0},   // GPIO / External INT 0        P1.0
    /* 3  */    {XMC_GPIO_PORT2 , 2},   // PWM42-0 / External INT 1     P3.6
    /* 4  */    {XMC_GPIO_PORT2 , 9},   // GPIO                         P1.6
    /* 5  */    {XMC_GPIO_PORT2 , 3},   // PWM42-3 output               P3.3
    /* 6  */    {XMC_GPIO_PORT2 , 4},   // PWM42-2 output               P3.4
    /* 7  */    {XMC_GPIO_PORT2 , 8},  // GPIO                         P1.14
    /* 8  */    {XMC_GPIO_PORT2 , 6},   // GPIO                         P4.1
    /* 9  */    {XMC_GPIO_PORT0 , 11},  // PWM80-31 output              P0.11
    /* 10 */    {XMC_GPIO_PORT1 , 7},   // SPI-SS / PWM80-01 output     P0.2
    /* 11 */    {XMC_GPIO_PORT1 , 9},   // SPI-MOSI / PWM41-2 output    P1.9
    /* 12 */    {XMC_GPIO_PORT0 , 0},   // SPI-MISO                     P0.0
    /* 13 */    {XMC_GPIO_PORT1 , 8},   // SPI-SCK                      P1.8
    /* 14 */    {XMC_GPIO_PORT2 , 3},   // AREF TODO:                   P2.3
    /* 15 */    {XMC_GPIO_PORT2 , 5},   // I2C Data / Address SDA       P2.5
    /* 16 */    {XMC_GPIO_PORT3 , 0},   // I2C Clock SCL          P3.0
  /* 17  */   {XMC_GPIO_PORT14 , 0},  // A0 / ADC Input               P14.0 (INPUT ONLY)
    /* 18  */   {XMC_GPIO_PORT14 , 1},  // A1 / ADC Input               P14.1 (INPUT ONLY)
    /* 19  */   {XMC_GPIO_PORT14 , 2},  // A2 / ADC Input               P14.2 (INPUT ONLY)
    /* 20  */   {XMC_GPIO_PORT14 , 3},  // A3 / ADC Input               P14.3 (INPUT ONLY)
    /* 21  */   {XMC_GPIO_PORT14 , 4},  // A4 / ADC Input               P14.4 (INPUT ONLY)
    /* 22  */   {XMC_GPIO_PORT14 , 5},  // A5 / ADC Input               P14.5 (INPUT ONLY)
    /* 23  */   {XMC_GPIO_PORT1 , 15},  // USB Debug RX                 P1.15
    /* 24  */   {XMC_GPIO_PORT0 , 5},   // USB Debug TX                 P0.5
//Additional pins for port X1 starting here
/* 25  */   {XMC_GPIO_PORT2 , 10},
/* 26  */   {XMC_GPIO_PORT2 , 8},
/* 27  */   {XMC_GPIO_PORT2 , 4},
/* 28  */   {XMC_GPIO_PORT2 , 2},
/* 29  */   {XMC_GPIO_PORT2 , 0},
/* 30  */   {XMC_GPIO_PORT2 , 6},
/* 31  */   {XMC_GPIO_PORT2 , 6},
/* 32  */   {XMC_GPIO_PORT2 , 6},
/* 33  */   {XMC_GPIO_PORT1 , 14},
/* 34  */   {XMC_GPIO_PORT1 , 12},
/* 35  */   {XMC_GPIO_PORT1 , 10},
/* 36  */   {XMC_GPIO_PORT1 , 4},
/* 37  */   {XMC_GPIO_PORT1 , 2},
/* 38  */   {XMC_GPIO_PORT1 , 0},
/* 39  */   {XMC_GPIO_PORT1 , 8},
/* 40  */   {XMC_GPIO_PORT1 , 6},
/* 41  */   {XMC_GPIO_PORT1 , 6},
/* 42  */   {XMC_GPIO_PORT2 , 14},
/* 43  */   {XMC_GPIO_PORT2 , 15},
/* 44  */    {XMC_GPIO_PORT2 , 15},
/* 45  */   {XMC_GPIO_PORT1 , 7},
/* 46  */   {XMC_GPIO_PORT1 , 9},
/* 47  */   {XMC_GPIO_PORT1 , 1},
/* 48  */   {XMC_GPIO_PORT1 , 3},
/* 49  */   {XMC_GPIO_PORT1 , 5},
/* 50  */   {XMC_GPIO_PORT1 , 11},
/* 51  */   {XMC_GPIO_PORT1 , 13},
/* 52  */   {XMC_GPIO_PORT1 , 15},
/* 53  */   {XMC_GPIO_PORT1 , 15},
/* 54  */   {XMC_GPIO_PORT1 , 15},
/* 55  */   {XMC_GPIO_PORT2 , 7},
/* 56  */   {XMC_GPIO_PORT2 , 1},
/* 57  */   {XMC_GPIO_PORT2 , 3},
/* 58  */   {XMC_GPIO_PORT2 , 5},
/* 59  */   {XMC_GPIO_PORT2 , 9},
/* 60  */   {XMC_GPIO_PORT2 , 8},
//Additional pins for port X2 starting here
/* 61  */   {XMC_GPIO_PORT14 , 8},
/* 62  */   {XMC_GPIO_PORT14 , 8},
/* 63  */   {XMC_GPIO_PORT14 , 15},
/* 64  */   {XMC_GPIO_PORT14 , 15},
/* 65  */   {XMC_GPIO_PORT14 , 6},
/* 66  */   {XMC_GPIO_PORT14 , 12},
/* 67  */   {XMC_GPIO_PORT14 , 14},
/* 68  */   {XMC_GPIO_PORT3 , 0},
/* 69  */   {XMC_GPIO_PORT3 , 2},
/* 70  */   {XMC_GPIO_PORT0 , 10},
/* 71  */   {XMC_GPIO_PORT0 , 1},
/* 72  */   {XMC_GPIO_PORT0 , 3},
/* 73  */   {XMC_GPIO_PORT0 , 5},
/* 74  */   {XMC_GPIO_PORT0 , 11},
/* 75  */   {XMC_GPIO_PORT3 , 3},
/* 76  */   {XMC_GPIO_PORT3 , 5},
/* 77  */   {XMC_GPIO_PORT0 , 7},
/* 78  */   {XMC_GPIO_PORT0 , 8},
/* 79  */   {XMC_GPIO_PORT3 , 6},
/* 80  */   {XMC_GPIO_PORT3 , 4},
/* 81  */   {XMC_GPIO_PORT0 , 12},
/* 82  */   {XMC_GPIO_PORT0 , 6},
/* 83  */   {XMC_GPIO_PORT0 , 4},
/* 84  */   {XMC_GPIO_PORT0 , 2},
/* 85  */   {XMC_GPIO_PORT0 , 0},
/* 86  */   {XMC_GPIO_PORT0 , 9},
/* 87  */   {XMC_GPIO_PORT3 , 1},
/* 88  */   {XMC_GPIO_PORT14 , 4},
/* 89  */   {XMC_GPIO_PORT14 , 13},
/* 90  */   {XMC_GPIO_PORT14 , 7},
/* 91  */   {XMC_GPIO_PORT14 , 5},
/* 92  */   {XMC_GPIO_PORT14 , 3},
/* 93  */   {XMC_GPIO_PORT14 , 3},
/* 94  */   {XMC_GPIO_PORT14 , 9}
//     //Define extra pins for Slot 1 & Slot 2 here
//    /* 95  */   {XMC_GPIO_PORT3 , 5},   // Chip Select - Slot 1           P3.5
//    /* 96  */   {XMC_GPIO_PORT1 , 7},   // Chip Select - Slot 2           P1.7
const XMC_PIN_INTERRUPT_t mapping_interrupt[] =
    /* 0  */    {CCU40, CCU40_CC43, 3, 0, CCU40_IN3_P1_0},
XMC_PWM4_t mapping_pwm4[] =
//additional pwm outputs starting here
{CCU41, CCU41_CC41, 1, mapping_port_pin[27] , P2_4_AF_CCU41_OUT1, XMC_CCU4_SLICE_PRESCALER_64, PWM4_TIMER_PERIOD, DISABLED}, // PWM disabled  27 P2.4
{CCU41, CCU41_CC43, 3, mapping_port_pin[28] , P2_2_AF_CCU41_OUT3, XMC_CCU4_SLICE_PRESCALER_64, PWM4_TIMER_PERIOD, DISABLED}, // PWM disabled  28 P2.2
{CCU41, CCU41_CC42, 2, mapping_port_pin[57] , P2_3_AF_CCU41_OUT2, XMC_CCU4_SLICE_PRESCALER_64, PWM4_TIMER_PERIOD, DISABLED}, // PWM disabled  57 P2.3
{CCU41, CCU41_CC41, 0, mapping_port_pin[58] , P2_5_AF_CCU41_OUT0 , XMC_CCU4_SLICE_PRESCALER_64, PWM4_TIMER_PERIOD, DISABLED}, // PWM disabled  58 P2.5
XMC_PWM8_t mapping_pwm8[] =
    {CCU80, CCU80_CC83, 3, XMC_CCU8_SLICE_COMPARE_CHANNEL_2, mapping_port_pin[9],  P0_11_AF_CCU80_OUT31, XMC_CCU8_SLICE_PRESCALER_64, PWM8_TIMER_PERIOD, DISABLED}, // PWM disabled  9 P0.11
    {CCU80, CCU80_CC80, 0, XMC_CCU8_SLICE_COMPARE_CHANNEL_2, mapping_port_pin[10],  P0_2_AF_CCU80_OUT01, XMC_CCU8_SLICE_PRESCALER_64, PWM8_TIMER_PERIOD, DISABLED}, // PWM disabled  10 P0.2
{CCU80, CCU80_CC80, 0, XMC_CCU8_SLICE_COMPARE_CHANNEL_1, mapping_port_pin[55], P2_7_AF_CCU80_OUT03, XMC_CCU8_SLICE_PRESCALER_64, PWM8_TIMER_PERIOD, DISABLED}, // PWM disabled  55 P2.7
{CCU80, CCU80_CC81, 1, XMC_CCU8_SLICE_COMPARE_CHANNEL_1, mapping_port_pin[86], P0_9_AF_CCU80_OUT12,  XMC_CCU8_SLICE_PRESCALER_64, PWM8_TIMER_PERIOD, DISABLED}, // PWM disabled  86 P0.9
{CCU80, CCU80_CC81, 1, XMC_CCU8_SLICE_COMPARE_CHANNEL_2, mapping_port_pin[30], P2_6_AF_CCU80_OUT13,  XMC_CCU8_SLICE_PRESCALER_64, PWM8_TIMER_PERIOD, DISABLED}, // PWM disabled  30 P2.6
{CCU80, CCU80_CC82, 2, XMC_CCU8_SLICE_COMPARE_CHANNEL_1, mapping_port_pin[59], P2_9_AF_CCU80_OUT22,  XMC_CCU8_SLICE_PRESCALER_64, PWM8_TIMER_PERIOD, DISABLED}, // PWM disabled  59 P2.9
{CCU80, CCU80_CC83, 3, XMC_CCU8_SLICE_COMPARE_CHANNEL_1, mapping_port_pin[26], P2_8_AF_CCU80_OUT32,  XMC_CCU8_SLICE_PRESCALER_64, PWM8_TIMER_PERIOD, DISABLED}, // PWM disabled  26 P2.8
/* {CCU81, CCU81_CC80, 0, XMC_CCU8_SLICE_COMPARE_CHANNEL_1, mapping_port_pin[54], P5_7_AF_CCU81_OUT02, XMC_CCU8_SLICE_PRESCALER_64, PWM8_TIMER_PERIOD, DISABLED}, // PWM disabled  54 P5.7
{CCU81, CCU81_CC82, 1, XMC_CCU8_SLICE_COMPARE_CHANNEL_2, mapping_port_pin[29], P2_0_AF_CCU81_OUT21,  XMC_CCU8_SLICE_PRESCALER_64, PWM8_TIMER_PERIOD, DISABLED} // PWM disabled  29 P2.0
{CCU81, CCU81_CC81, 1, XMC_CCU8_SLICE_COMPARE_CHANNEL_2, mapping_port_pin[82], P5_5_AF_CCU81_OUT12,  XMC_CCU8_SLICE_PRESCALER_64, PWM8_TIMER_PERIOD, DISABLED}, // PWM disabled  82 P5.5
{CCU81, CCU81_CC82, 2, XMC_CCU8_SLICE_COMPARE_CHANNEL_2, mapping_port_pin[81], P5_3_AF_CCU81_OUT22,  XMC_CCU8_SLICE_PRESCALER_64, PWM8_TIMER_PERIOD, DISABLED}  // PWM disabled  81 P5.3*/
XMC_ARD_DAC_t mapping_dac[] =
{XMC_DAC0, 1, 12},
{XMC_DAC0, 0, 12}
XMC_ADC_t mapping_adc[] =
//Result reg numbers are now equal to channel numbers
{VADC, 0, VADC_G0, 0, 0, DISABLED},
    {VADC, 1, VADC_G0, 0, 1, DISABLED},
    {VADC, 2, VADC_G1, 1, 2, DISABLED},
    {VADC, 3, VADC_G1, 1, 3, DISABLED},
//Additional ADC channels starting here
 * UART objects
 * Serial 0 is Debug port
 * Serial 1  is on-board port
RingBuffer rx_buffer_0;
RingBuffer tx_buffer_0;
RingBuffer rx_buffer_1;
RingBuffer tx_buffer_1;
#ifdef SERIAL_HOSTPC
XMC_UART_t XMC_UART_0 =
  .channel              = XMC_UART1_CH0,
  .rx                   = { .port = (XMC_GPIO_PORT_t*)PORT0_BASE,
                            .pin  = (uint8_t)5
  .rx_config            = { .mode = XMC_GPIO_MODE_INPUT_TRISTATE,
                            .output_level     = XMC_GPIO_OUTPUT_LEVEL_HIGH,
                            .output_strength  = XMC_GPIO_OUTPUT_STRENGTH_STRONG_SOFT_EDGE
  .tx                   = { .port = (XMC_GPIO_PORT_t*)PORT1_BASE,
                            .pin  = (uint8_t)15
  .tx_config            = { .mode = (XMC_GPIO_MODE_t) XMC_GPIO_MODE_OUTPUT_PUSH_PULL_ALT4,
  .input_source_dx0     = (XMC_USIC_INPUT_t)USIC1_C0_DX0_P0_5,
  .input_source_dx1     = XMC_INPUT_INVALID,
  .input_source_dx2     = XMC_INPUT_INVALID,
  .input_source_dx3     = XMC_INPUT_INVALID,
  .irq_num              = USIC1_0_IRQn,
  .irq_service_request  = 0
// Debug port
HardwareSerial Serial( &XMC_UART_0, &rx_buffer_0, &tx_buffer_0 );
#elif SERIAL_ONBOARD
  .rx                   = { .port = (XMC_GPIO_PORT_t*)PORT2_BASE,
                            .pin  = (uint8_t)15
  .tx                   = { .port = (XMC_GPIO_PORT_t*)PORT2_BASE,
                            .pin  = (uint8_t)14
  .tx_config            = { .mode = (XMC_GPIO_MODE_t) XMC_GPIO_MODE_OUTPUT_PUSH_PULL_ALT2,
  .input_source_dx0     = (XMC_USIC_INPUT_t)USIC1_C0_DX0_P2_15,
  .irq_num              = USIC0_5_IRQn,
// Debug port
#endif
// Debug port
//HardwareSerial Serial( &XMC_UART_0, &rx_buffer_0, &tx_buffer_0 );
// On-board port
//HardwareSerial Serial1( &XMC_UART_1, &rx_buffer_1, &tx_buffer_1 );
// Serial Interrupt and event handling
#ifdef __cplusplus
extern "C" {
#endif
void serialEventRun( );
void serialEvent( ) __attribute__((weak));
void serialEvent1( ) __attribute__((weak));
if( serialEvent )
  if( Serial.available( ) )
    serialEvent( );
#if (NUM_SERIAL > 1)
if( serialEvent1 )
  if( Serial1.available( ) )
    serialEvent1( );
#endif
void USIC1_0_IRQHandler( )
Serial.IrqHandler( );
//void USIC1_0_IRQHandler( )
//Serial1.IrqHandler( );
void USIC0_5_IRQHandler( void )
Serial1.IrqHandler();
#endif
#ifdef __cplusplus
#endif
#endif /* ARDUINO_MAIN*/
#ifdef __cplusplus
extern HardwareSerial Serial;
extern HardwareSerial Serial1;
#endif  /* cplusplus */
#endif
Then the frame is OK.
3. Demo
Build and download the sketch blink.ino,
  Blink
  Turns an LED on for one second, then off for one second, repeatedly.
  Most Arduinos have an on-board LED you can control. On the UNO, MEGA and ZERO
  it is attached to digital pin 13, on MKR1000 on pin 6. LED_BUILTIN is set to
  the correct LED pin independent of which board is used.
  If you want to know what pin the on-board LED is connected to on your Arduino
  model, check the Technical Specs of your board at:
  https://www.arduino.cc/en/Main/Products
  modified 8 May 2014
  by Scott Fitzgerald
  modified 2 Sep 2016
  by Arturo Guadalupi
  modified 8 Sep 2016
  by Colby Newman
  This example code is in the public domain.
  http://www.arduino.cc/en/Tutorial/Blink
// the setup function runs once when you press reset or power the board
void setup() {
  // initialize digital pin LED_BUILTIN as an output.
  pinMode(LED_BUILTIN, OUTPUT);
// the loop function runs over and over again forever
void loop() {
  digitalWrite(LED_BUILTIN, HIGH);   // turn the LED on (HIGH is the voltage level)
  delay(1000);                       // wait for a second
  digitalWrite(LED_BUILTIN, LOW);    // turn the LED off by making the voltage LOW
The normal blink runs well.
But the serial output for UART is not OK. That shall be next move.
4. Next to do
In general, the pin map shall be verified carefully. Some of the Pins is not set properly in above file. But it runs now. Revise step by step. That is fun.
