Safe and Sound
  • Safe and Sound
Safe and Sound
Blog Safe and Sound Wearables- Hearing Guard System #3: User and Technical Stories
  • Author Author: jomoenginer
  • Date Created: 27 Feb 2017 8:44 AM Date Created
  • Views 783 views
  • Comments 5 comments
  • safe and sound design challenge
  • msp432
jomoenginer
jomoenginer
27 Feb 2017
In an attempt to keep this project organized and on track, I am going to implement some Agile Methodologies where it makes sense.
My first attempt it to create User and Technical Stories for the Requirements that I have at this time.  The reason I decided to go this route is that since this is a short project cycle, the Requirements have a good possibility of changing. So, rather than have a hard coded set of Requirements that may not get completed, I am looking to have a more flexible Implementation. Time will tell if this was the right direction or not.
Hearing Guard System User Stories
Base Unit Back Log
Backlog: Base Unit
Theme: Menu
Title: Set dB Threshold
Description: As a user, I want to set the dB Threshold, so I can adjust the level for a particular room.
Success Criteria:
     User is provided with a Set dB Threshold Menu option
     User selects Set dB Threshold option
     The system displays the appropriate data.
Backlog: Base Unit
Theme: Menu
Title: View Noise Data
Description: As a user, I want to View Noise Data, so I can document any excessive noise trends.
Success Criteria:
    User is provided with a View Noise Data Menu options
    User selects View Noise Data option
Backlog: Base Unit
Theme: Menu
Title: View Alerts
Description: As a User, I want to View Alerts that were triggered, so I can track the noise level of the room
Success Criteria:
    User is provided with a View Alerts Menu options
    User selects View Alerts option
Backlog: Base Unit
Theme: Menu
Title: View User Data
Description: As a user, I want to View User Data, so I can identify the users on the system
Success Criteria:
    User is provided with a View User Data Menu option
Technical Stories for the Base Unit
Backlog: Base Unit
Theme: Connectivity
Title: Bluetooth connectivity
Description: Connect to the Personal Noise Sensor and Room Monitor using the Bluetooth LE protocol for transferring data to the Base unit and setting the dB Thresholds
Success Criteria:
      Successfully Identify the Bluetooth device handle
      Successfully connect to the bluetooth device
      Data is transferred to the Base Unit
      Connection successfully closes
Backlog: Base Unit
Theme: Connectivity
Title: NFC/RFID connectivity
Description: Connect to the Personal Noise Sensor and Room Monitor using NFC/RFID for transferring data to the Base unit and setting the dB Thresholds
Success Criteria:
      Successfully Identify NFC/RFID device
      Successfully connect to NFC/RFID device
Backlog: Base Unit
Theme: Connectivity
Title: WiFi connectivity
Description: Remote Connection via WiFi so the data from the unit can be viewed
Success Criteria:
      Successfully connect to a WiFi connection
      Successfully send MQTT data
      Successfully receive MQTT requests
      Successfully receive REST requests
Backlog: Base Unit
Theme: Display
Title: Kentec QVGA LCD
Description: Connection to Kentec QVGA LCD for menu and status display
Success Criteria:
      Successfully connect to SPI connection
      Display Data to LCD screen
      Receive user input via touch screen
Personal Noise Sensor Back Log
Backlog: Personal Noise Sensor
Theme: Menu
Success Criteria:
Theme: Menu
Title: View dB Threshold
Description: As a user, I want to view the dB Threshold, so I can verify the current setting.
Success Criteria:
     User is provided with a View dB Threshold Menu option
     User selects View dB Threshold option
Theme: Menu
Title: View Alerts
Description: As a user, I want to view the Alerts, so I can see the current status.
Success Criteria:
Theme: Menu
Title: Send Data
Description: As a user, I want to connect to the base unit, so I can transfer data.
Success Criteria:
     User is provided with a Connect to Base Unit Menu option
     User selects connect
     Connection succeeds is received
     User selects Send Data Menu option
     User selects Ok when prompted to send data
     Data transfer complete is received
     Connection is closed.
Theme: Menu
Description: As a user, I want to view the dB Threshold, so I can adjust the level for a particular room.
Success Criteria:
Technical Stories for the Personal Noise Sensor
Theme: Alert
Title: Alert Indicator
Description: The Alert status will be displayed with the appropriate LED color.
Success Criteria:
     If noise level is safe, LED lights Green
     If noise level is elevated to within 25% of dB threshold, LED lights Yellow.
     If noise level is elevated to within 50% of dB threshold, LED lights Orange
     If noise level is elevated to within 75% of dB threshold, LED lights RED
     If noise level is above threshold, the LED flashes RED
Theme: Input
Title: Touchpad Input
Description: The Touchpads on the Sharp LCD Booster Pack will be used for user input.
Success Criteria:
     User swipes the touchpad to activate the user input
     The user selects an option from the menu screen
     The function the user selects is performed.
     The menu is displayed again
      After 20 sec of no activity, the display turns off
Theme: Audio
Title: Audio Input
Description: The Noise Level input will be from an off board audio circuit and a microphone.
Success Criteria:
     Audio circuit detects sound pressure
     The dB setting determines the level of the sound pressure
     The audio circuit turns off when noise level is below 25% of threshold.
Theme: Display
Title: Sharp LCD
Description: Connection to Sharp LCD for menu and status display
Success Criteria:
Theme: Connectivity
Description: Connect to the Base Unit using NFC/RFID for transferring data
Success Criteria:
      Successfully Identify NFC/RFID Base Unit
      Successfully connect to NFC/RFID Base Unit
Theme: Connectivity
Description: Connect to the Base Unit using the Bluetooth LE protocol for transferring data.
Success Criteria:
Room Monitor Back Log
Backlog: Room Monitor
Theme: Menu
Success Criteria:
Theme: Menu
Success Criteria:
Theme: Menu
Title: View Alerts
Success Criteria:
Theme: Menu
Title: Send Data
Success Criteria:
Theme: Menu
Success Criteria:
Technical Stories for the Room Monitor
Theme: Alert
Success Criteria:
     If noise level is above threshold, the LED flashes RED,
Theme: Input
Success Criteria:
Theme: Audio
Title: Audio Input
Success Criteria:
Theme: Display
Title: Sharp LCD
Success Criteria:
Theme: Connectivity
Success Criteria:
Theme: Connectivity
Description: Remote Connection via WiFi to the data the Base Unit
Success Criteria:
      Successfully sends REST requests
  • jomoenginer
    jomoenginer over 9 years ago in reply to mcb1 +2
    The concept behind the Backlog, if I understand it correctly, is to collect the initial requirements and the whole process is iterative so these requirements could change along the way. I still have some…
    DAB over 9 years ago in reply to jomoenginer
    Hi Jon,
    I was referring to your efforts to determine the thresholds for the various inputs.
    The adaptive algorithm lets your input thresholds adjust for noisy environments and still maintain maximum sensitivity of detection.
  • jomoenginer
    The concept behind the Backlog, if I understand it correctly, is to collect the initial requirements and the whole process is iterative so these requirements could change along the way.  I still have some architecture documentation to complete so the plan is not finished and this is only to get things started.
    Thanks,
    Jon
  • jomoenginer
    jomoenginer over 9 years ago in reply to DAB
    DAB,
        You are referring to the Touch Screen on the Display, correct?  For this project, I'm not sure how deep I'll get into that aspect of the user input but it is good to know.
    Thanks,
    Jon
    mcb1 over 9 years ago
    It is a good idea to have a plan.
    Looking at it initially it seems a lot of words, but in many cases there are three parts to it, so it does help break down each item.
    I wonder if your plan has enough detail to help you with the coding and deciding on what to display.
    From experience this can take almost as long as the actual code, but it is necessary to save time in the long run.
    You do have the display working so at least you're not fighting the hardware issues.
    Hi Jon,
    You might want to look into some of the adaptive algorithm work done by Dr. Peter Raeth using Radial Basis functions.
    We showed that you could set up a device to "learn" a local signal background environment and rapidly pick up on coherent signals out of low signal to noise ratios.
