Safe and Sound
  • Safe and Sound
Safe and Sound
Blog Safe and Sound : Winter/Cold Weather Survival Suit Blog#9
  • Author Author: dwinhold
  • Date Created: 29 Apr 2017 5:42 PM Date Created
  • Views 1478 views
  • Comments 7 comments
  • water_proof
  • safe & sound projects
  • safe & sound
  • dwinhold
  • winter survival suit
  • cold
dwinhold
dwinhold
29 Apr 2017
This update is about water proofing my project. Everything done here is the first time I ever worked with this product and it was done live, so if it fails we will all see it go wrong. There are 3 videos attached, the first is showing the product, second is applying it to the board and third is putting the powered board under running water.
I use an Arduino Uno as a test so if this doesn't work I don't wreck the MSP432.
So, what do you think? Will it work? Fail? Here is the challenge, post below before you watch the last video and say weather you think it worked or if I ruined my Arduino Uno. Don't give it away (at least for a couple of days) after you watch.
Video #1 (The Acrylic Conformal Coating)
Video #2 (Spraying it on the board) **As a note - Take every safety precaution when using this, it is poisonous**
Video #3 (Water testing)
Hope you enjoyed watching.
Dale Winhold
    DAB over 9 years ago +3
    Nice update. I would try a salt water mixture to test the boards. I worry about human sweat soaking through the clothing to the boards. DAB
    mcb1 over 9 years ago +1
    Water and electronics are an interesting mix. From my observations over the years, it is not immersion in clean water that causes a problem. High frequency circuits my have some changes due to the capacitance…
  • dwinhold
    dwinhold over 9 years ago in reply to mcb1 +1
    Hi Mark, Thank you for the reply. I definitely agree that water and electronics aren't a good mixture. Clean water is what was the closest for this experiment, I will have to try it out in salt water as…
  • Workshopshed
    Workshopshed over 9 years ago
    A far from ideal candidate for this kind of spray, glad to see it survived so far.
    dougw over 9 years ago in reply to Workshopshed
    Yes, interesting to see that the chip in a socket was protected ....
