Twist, Turn and Move Design Challenge with TE Robotics
  • Twist, Turn and Move Design Challenge with TE Robotics
Blog ARDUMOBO blog 5: Ardumobo - testing the system
  • Author Author: a33333
  • Date Created: 9 Sep 2022 3:09 AM Date Created
  • Views 574 views
a33333
a33333
9 Sep 2022
Testing Ardumobo
In order to test Ardumobo, I wrote a small Arduino sketch that changes the direction of the robot when the distance to the obstacle is less than 10cm. Here is the code:
#include "HCSR04.h"
#include "DRI0017.h"
void setup() {
  // put your setup code here, to run once:
void loop() {
  // put your main code here, to run repeatedly:
  setupHCSR04();
  setupDRI0017();
  int frontDistance = 0;
  int rearDistance = 0;
  int moveDirection = Forward;
  while (1) {
    frontDistance = readFrontSensor();
    rearDistance = readRearSensor();
    if (frontDistance < 10){
      moveDirection = Backward;
    if (rearDistance < 10) {
    if (moveDirection == Forward){
        setMotorDirection(M1, Forward);
        setMotorSpeed(M1, 100);
        delay(10);
        setMotorSpeed(M1, 70);
    } else {
        setMotorDirection(M1, Backward);
        delay(10);
    delay(100);
Here is a short movie of Ardumobo detecting obstacles in front and rear and then changing moving direction after obstacle detection. The front wheels are a bit wobbly, I will try to tighten them up and adjust the wheel alignment. (There is a plastic screw labeled "wheel adjustment" under the front wheel assembly of the truck: I will see if it works.)
Next blog: obstacle detection outdoors.
    DAB over 4 years ago
    Nice update.
    The video shows it moving quite smoothly.
