Twist, Turn and Move Design Challenge with TE Robotics
  • Twist, Turn and Move Design Challenge with TE Robotics
Blog Pool Butler Blog #11 Twist Turn & Move - The TE connectors used
  • Author Author: robogary
  • Date Created: 7 Sep 2022 9:42 PM Date Created
  • Views 552 views
  • ardunino
  • pool butler
  • Twist Turn and Move Robotics Design Challenge
  • terobotics
  • designchallenge
  • Turn and Move Design Challenge with TE Robotics
robogary
robogary
7 Sep 2022
Another blog - you kidding me ?
Ohhhh so lucky readers - here is a video showing the Pool Butler's TE connectors and where thewires/signals go to and from.
Its only 4 minutes long, so save your trip to the bathroom until its done.
https://youtu.be/Bi0jRd8uLH4
The TE kit parts highlighted in red are the ones I did NOT use.
Randall also provided 20 more pairs of D-1000 contacts (yellow) and these are all used too.
Dynamic Connectors Parts:
1-2366515-4 Connector Housing
2367817-2 Contact
2-2366515-4 Connector Housing
1-2366600-4 Connector Housing
2367819-2 Contact
2-2366600-4 Connector Housing
1891526-1 Extraction Tool
1-2366515-8 Connector Housing
2-2366515-8 Connector Housing
1-2366600-8 Connector Housing
2-2366600-8 Connector Housing
More Items:
AXICOM IM Signal Relay
M4473 SL005 Multipair Cable
Circular Plastic Connector Series 1
Circular Connector Size 11
M8 Series Connector Male
M8 Series Connector Female
D-Sub Connector
D-Sub Connector
201328-1 Multimate Contact Type II
201330-1 Contact
Wired-Board Connector
Receptacle FFC/FPC Connector
Pin Header
For those obsessive and compulsive readers, here are some drawings and such to complement the video.
I dont have VISIO access anymore to update the schematics with the final connector designators & pin numbers, I beg your understanding & forgiveness.
and REMEMBER the Duck will be with you........always
