Twist, Turn and Move Design Challenge with TE Robotics
  • Twist, Turn and Move Design Challenge with TE Robotics
Blog Pool Butler Blog #6 Twist & Turn - crimping CPC and D-1000 pins with a generic pin crimper
  • Author Author: robogary
  • Date Created: 18 Aug 2022 12:52 AM Date Created
  • Views 1499 views
  • ardunino
  • te connectivity
  • Twist Turn and Move Robotics Design Challenge
  • terobotics
  • Turn and Move Design Challenge with TE Robotics
robogary
robogary
18 Aug 2022
The Pool Butler (airboat) has 2 plastic covered sandwich enclosures to protect the electronics from water.
Some of the interconnections are in between the boxes, and some wires are to devices outside the boxes.
A wire schedule is used in buildings, control systems, etc to plan the wiring, cabling, signals in those cables, signal levels, etc...etc...etc. define all the wire and cable properties and materials needed.
Worried about having enough D-1000 pins for the Pool Butler, this first pass wire schedule was created.
The prop motor runs @ ~ 1 amp now, but could be upgraded in the future so decided to use the CPC connector for that ckt.
The build is ongoing and the wiring is getting messy. Time to make some of these harnesses and clean up the prototype Pool Butler.
This is a pin crimper I got about 45 years ago, and used it to crimp the CPC and D-1000 pins fairly successfully.
If you have an old pin crimper on hand, follow the photos to see which groove was used for the different pins and how the pins were inserted into it.
Its not perfect, but got the job done.
First photos of the CPC pins being crimped.
These photos are of crimping the D-1000 connectors
Next are the before and after harness photos
  • robogary
    robogary over 4 years ago
    astonishing photography , are you a professional ?
  • robogary
  • amgalbu
    amgalbu over 4 years ago in reply to robogary
    pictures are incredibly clear. which kind of lenses did you use?
  • robogary
    robogary over 4 years ago in reply to amgalbu
    thanks  The camera is a Canon SD1300  12 megapixel pocket camera. I use it because it is alot easier than my cell phone to take a photo while juggling hand tools and puts a date stamp in the photo itself.
    The interesting twist is each photo is 2-3 Mbytes each. Before loading to E14 , the photos are resized using PAINT from 2-3Mb to 2-3kbytes. Sometimes they even get resized to 200-300 bytes to put on E14.
