Twist, Turn and Move Design Challenge with TE Robotics
  • Twist, Turn and Move Design Challenge with TE Robotics
Blog Twist, Turn and Move Challenge - Unlimited CNC Robot Blog #6
  • Author Author: dwinhold
  • Date Created: 12 Sep 2022 11:23 AM Date Created
  • Views 615 views
  • Line Following
  • dwinhold
  • Unlimited CNC
  • designchallenge
  • Turn and Move Design Challenge with TE Robotics
dwinhold
dwinhold
12 Sep 2022
I wanted to post this blog before I post my final blog tonight. I found a big error in my code and wanted to update it now.
The error I made was I had my line sensors reversed to what they needed to be for the right reading. I had a "<" instead of ">" and reverse of that.
I added new code as well, thanks to DAB for the suggestion!! Excellent idea and it works great!!
Below is the corrected code as well as the newly added code:
/**Unlimited CNC Robot**/
#include <IRremote.h>  //including infrared remote header file - This is used to start the robot and emergency stop
#include <pitches.h> //include sound
int RECV_PIN = 7; // the pin where you connect the output pin of IR sensor
IRrecv irrecv(RECV_PIN);
decode_results results;
/**set control port - DFRobot L298P**/
const int E1Pin = 10;
const int M1Pin = 12;
const int E2Pin = 11;
const int M2Pin = 13;
/**inner definition**/
typedef struct {
  byte enPin;
  byte directionPin;
} MotorContrl;
const int M1 = 0;
const int M2 = 1;
const int MotorNum = 2;
const MotorContrl MotorPin[] = { {E1Pin, M1Pin}, {E2Pin, M2Pin} } ;
const int Forward = LOW;
const int Backward = HIGH;
//Sensor Connection
const int left_sensor_pin =A0;
const int right_sensor_pin =A1;
const int laser_on_sensor_pin =A2; /**Right**/
const int laser_off_sensor_pin =A3; /**Left**/
int left_sensor_state;
int right_sensor_state;
int laser_on_sensor_state;
int laser_off_sensor_state;
int turn_delay = 10;
int laser_status = 0; /**0 = Laser status is off, 1 = Laser status is On**/
int ircontrol = 0;
int speakernote = NOTE_F4;
int speakernote2 = NOTE_G4;
int speakernote3 = NOTE_A5;
/**program**/
void setup() {
  Serial.begin(9600);
  irrecv.enableIRIn();
  ircontrol = 0;
  initMotor();
  pinMode(9, OUTPUT); /**Power to Laser & Fan**/
  pinMode(4, OUTPUT); //LED Green
  pinMode(5, OUTPUT); //LED Yellow
  pinMode(6, OUTPUT); //LED Red
  pinMode(8, OUTPUT); //LED Speakernote
void loop() {
  digitalWrite(5, LOW); //LED Yellow - Power off
  digitalWrite(6, LOW); //LED Green - Power off
  Serial.println("Waiting for IR Signal to start");
  digitalWrite(4, HIGH); //LED Green - Power On
  if(irrecv.decode()){  // IR receive results
    ircontrol = 1;
    delay(500);
    digitalWrite(5, HIGH); //LED Yellow - 1st warning
    delay(1000);
    tone(8, speakernote, 600); //Sound warning 1
    delay(1000);
    noTone(8);
    tone(8, speakernote, 600); //Sound warning 2
    delay(1000);
    noTone(8);
    tone(8, speakernote, 600); //Sound warning 3
    delay(1000);
    noTone(8);
    tone(8, speakernote, 600); //Sound warning 4
    delay(1000);
    noTone(8);
    tone(8, speakernote3, 600); //Sound warning 5
    delay(1000);
    noTone(8);
    digitalWrite(6, HIGH); //LED Red - Robot Running
    delay(2000);
  if(ircontrol != 0){
  do{
    Serial.println("Robot in Running Mode");
    int value;
    irrecv.resume();
    left_sensor_state = analogRead(left_sensor_pin);
    right_sensor_state = analogRead(right_sensor_pin);
    laser_on_sensor_state = analogRead(left_sensor_pin);
    laser_off_sensor_state = analogRead(right_sensor_pin);
  if(laser_status = 0)
    if(laser_on_sensor_state  < 500)
      Serial.println("Laser On/Fan On");
      setMotorSpeed( M1, 0 );
      setMotorSpeed( M2, 0 );
      digitalWrite(9, HIGH); //Laser & Fan on
      tone(8, speakernote2, 600); //Laser On signal
      delay(250);
      tone(8, speakernote3, 600); //Laser On signal
      delay(250);
      noTone(8);
      laser_status = 1; /**Laser status is now on**/
  if(laser_status = 1)
    if(laser_off_sensor_state  < 500)
      Serial.println("Laser Off/Fan Off");
      digitalWrite(9, LOW); //Laser & Fan off
      delay(200);
      tone(8, speakernote3, 600); //Laser Off signal
      delay(250);
      tone(8, speakernote2, 600); //Laser Off signal
      delay(250);
      noTone(8);
      laser_status = 0; //Laser status is now off
  if(right_sensor_state > 500 && left_sensor_state < 500)
    Serial.println("turning right");
    setMotorDirection( M2, Forward );
    setMotorSpeed( M2, 100 );
    delay(turn_delay);
   if(right_sensor_state < 500 && left_sensor_state > 500)
    Serial.println("turning left");
    setMotorDirection( M1, Forward );
    setMotorSpeed( M1, 100 );
    delay(turn_delay);
  if(right_sensor_state > 500 && left_sensor_state > 500)
    Serial.println("going forward");
    delay(turn_delay);
 if(right_sensor_state < 500 && left_sensor_state < 500)
    Serial.println("stop");
    laser_status = 0; //Laser status is off
    ircontrol = 0;
    delay(250);
    delay(2000);
    noTone(8);
    ircontrol = 0;
    Serial.println("Emergency Stop Pressed");
    delay(2000);
    delay(250);
    delay(250);
    tone(8, speakernote, 600); //Shutdown signal
    delay(200);
    delay(200);
    delay(200);
    noTone(8);
}while(ircontrol != 0);
  digitalWrite(5, HIGH); //LED Yellow - Off
  digitalWrite(6, HIGH); //LED Red - Off
  ircontrol = 0;
  irrecv.resume();
/**functions**/
void initMotor() {
  int i;
  for ( i = 0; i < MotorNum; i++ ) {
    digitalWrite(MotorPin[i].enPin, LOW);
    pinMode(MotorPin[i].enPin, OUTPUT);
    pinMode(MotorPin[i].directionPin, OUTPUT);
/**  motorNumber: M1, M2
direction:          Forward, Backward **/
void setMotorDirection( int motorNumber, int direction ) {
  digitalWrite( MotorPin[motorNumber].directionPin, direction);
/** speed:  0-100   * */
inline void setMotorSpeed( int motorNumber, int speed ) {
  analogWrite(MotorPin[motorNumber].enPin, 255.0 * (speed / 100.0) ); //PWM
The final blog coming tonight!!
Dale Winhold
