Twist, Turn and Move Design Challenge with TE Robotics
  • Twist, Turn and Move Design Challenge with TE Robotics
Blog Twist, Turn, & Move Design Challenge - Unlimited CNC Robot - Blog #2
  • Author Author: dwinhold
  • Date Created: 13 Aug 2022 2:53 PM Date Created
  • Views 849 views
  • Likes 9 likes
  • robots
  • Line Following
  • cnc
  • dwinhold
  • Twist Turn and Move Robotics Design Challenge
dwinhold
dwinhold
13 Aug 2022
Unlimited CNC Robot Blog #2 - The making of the line following robot.
For the first part of my project, I created the line follower. I felt it would be best to make a working line following robot first, the 2nd part is to add the CNC.
I did have to change one part of my robot and that was switching from a spindle CNC to a laser CNC. I found with the spindle that the torque of when it starts turns the robot almost 180 degrees. The chassis and wheel motors aren't strong enough to handle the spindle. I can't afford upgrading to more appropriate hardware at this time. Using a laser still accomplishes what I envisioned.
Below is the code and pictures of my project so far:
/**Unlimited CNC Robot**/
/**set control port - DFRobot L298P**/
const int E1Pin = 10;
const int M1Pin = 12;
const int E2Pin = 11;
const int M2Pin = 13;
/**inner definition**/
typedef struct {
  byte enPin;
  byte directionPin;
} MotorContrl;
const int M1 = 0;
const int M2 = 1;
const int MotorNum = 2;
const MotorContrl MotorPin[] = { {E1Pin, M1Pin}, {E2Pin, M2Pin} } ;
const int Forward = LOW;
const int Backward = HIGH;
//Sensor Connection
const int left_sensor_pin =A0;
const int right_sensor_pin =A1;
const int laser_on_sensor_pin =A2;
const int laser_off_sensor_pin =A3;
int left_sensor_state;
int right_sensor_state;
int laser_on_sensor_state;
int laser_off_sensor_state;
int turn_delay = 10;
/**program**/
void setup() {
  initMotor();
void loop() {
  int value;
  left_sensor_state = analogRead(left_sensor_pin);
  right_sensor_state = analogRead(right_sensor_pin);
  laser_on_sensor_state = analogRead(left_sensor_pin);
  laser_off_sensor_state = analogRead(right_sensor_pin);
    if(laser_on_sensor_state  < 500)
  Serial.println("Laser On");
    setMotorSpeed( M1, 0 );
    setMotorSpeed( M2, 0 );
    /**Code to turn laser on**/
    delay(200);
    setMotorDirection( M1, Forward );
    setMotorSpeed( M1, 100 );
    setMotorDirection( M2, Forward );
    setMotorSpeed( M2, 100 );
    delay(500);
if(laser_off_sensor_state  < 500)
  Serial.println("Laser Off");
    /**Code ot turn laser off**/
    delay(200);
    delay(500);
   if(right_sensor_state > 500 && left_sensor_state < 500)
  Serial.println("turning right");
  delay(turn_delay);
if(right_sensor_state < 500 && left_sensor_state > 500)
  Serial.println("turning left");
  delay(turn_delay);
if(right_sensor_state > 500 && left_sensor_state > 500)
  Serial.println("going forward");
  delay(turn_delay);
if(right_sensor_state < 500 && left_sensor_state < 500)
  Serial.println("stop");
/**functions**/
void initMotor( ) {
  int i;
  for ( i = 0; i < MotorNum; i++ ) {
    digitalWrite(MotorPin[i].enPin, LOW);
    pinMode(MotorPin[i].enPin, OUTPUT);
    pinMode(MotorPin[i].directionPin, OUTPUT);
/**  motorNumber: M1, M2
direction:          Forward, Backward **/
void setMotorDirection( int motorNumber, int direction ) {
  digitalWrite( MotorPin[motorNumber].directionPin, direction);
/** speed:  0-100   * */
inline void setMotorSpeed( int motorNumber, int speed ) {
  analogWrite(MotorPin[motorNumber].enPin, 255.0 * (speed / 100.0) ); //PWM
Thank you for reading my blog!! Any comments or suggestions are welcome.
As a note, the kit supplied is very generous!! Thank you very much to our sponsor TE Connectivity and Element14!!
Dale Winhold
  • robogary
    robogary over 4 years ago
    Nice progress. How do you like the yellow gearmotors ?  Are they sturdy enough ?  Are the white wheels on the motor shaft meant for LED encoders ?
  • dwinhold
    dwinhold over 4 years ago in reply to robogary
    I’m hoping to get better motors before the project is due, but they work ok. The white wheels are for LED encoders.
    dougw over 4 years ago in reply to dwinhold
    I have some similar yellow gearmotors but they don't have an encoder wheel - did these come with the encoder wheel?
  • dwinhold
    dwinhold over 4 years ago in reply to dougw
    They did come with the encoder wheel. I had these for a few years now.
  • dwinhold
