Twist, Turn and Move Design Challenge with TE Robotics
  • Twist, Turn and Move Design Challenge with TE Robotics
Documents Twist and Turn Design Challenge - Meet the Challengers
  • Author Author: e14phil
  • Date Created: 7 Jul 2022 2:36 PM Date Created
  • Last Updated Last Updated: 11 Jul 2022 3:27 PM
  • Views 6299 views
  • Likes 9 likes
  • Comments 38 comments
design challenge profile
The Twist, Turn, and Move Robotics Challenge
The Challengers | About This Challenge | Dates | The Judges | The Kit | The Prizes | Example Application | Terms & Conditions
Join us in Congratulating the Official Challengers of the Twist, Turn, & Move Design Challenge:
Internet Controlled Teleoperation Robot
nilutpol_kashyap
Unlimited CNC Robot
dwinhold
The Robo Cat
jwr50
Pool Butler
robogary
ARDUMOBO: Arduino mobile robot
a33333
PV Cleaning System
amgalbu
Robotic Yoga Instructor
hitesh.boghani
Sammy Semaphore - Semaphore Robot
dougw
R-Arm
GustavoMorales
Autonomous Navigation Robot
ajayvishaal
The Dates
To make sure challengers get their kit on time we have pushed back the end dates of this challenge and will be updating the site copy and terms to correspond with this.
Project Phases Dates
Challengers Announced 6th July 2022
Build Period 7th July - 12th September 2022
Projects Due 12nd September 2022
Winners Announced September 2022
Prizes Shipped September 2022
The Challenge
Each participant will receive a Challenger’s Kit, with which they are challenged to design and build a robotic arm or mobile robot that performs a specific task.
These 10 successful applicants will get a Selection of TE Connectors, an Arduino Uno, and Robotics Shields, free of charge, to build and blog their project with.
For the chance to win one of the prizes below, participants must blog their build process, as well as the final outcome of their Robotic Movement Project.
Included in the Challenger's Kit are a Selection of TE-provided components, as well as an Arduino Uno; use these to create your Robotic Movement Project.
Good integration of the TE components and interesting uses of movement will be graded more favorably.
Example tasks that can be performed include, but are not limited to:
  • Building a robot arm that can pick up and set down an object
  • Building a robot arm that moves in all degrees of freedom
  • Building a mobile robot that follows a line
  • Building a mobile robot that can avoid an object in its path
Challenger's Kit The Kit Product Name
connectors kit
TE Connectors Kit
(Product Image may differ)
Dynamic Connectors Parts:
1-2366515-4 Connector Housing
2367817-2 Contact
2-2366515-4 Connector Housing
1-2366600-4 Connector Housing
2367819-2 Contact
2-2366600-4 Connector Housing
1891526-1 Extraction Tool
1-2366515-8 Connector Housing
2-2366515-8 Connector Housing
1-2366600-8 Connector Housing
2-2366600-8 Connector Housing
More Items:
AXICOM IM Signal Relay
M4473 SL005 Multipair Cable
Circular Plastic Connector Series 1
Circular Connector Size 11
M8 Series Connector Male
M8 Series Connector Female
D-Sub Connector
D-Sub Connector
201328-1 Multimate Contact Type II
201330-1 Contact
Wired-Board Connector
Receptacle FFC/FPC Connector
Pin Header
connectors kit
Arduino Uno
Buy Now
connectors kit
DRI0017 2x2A Motor Shield for Arduino Twin (Product Image may differ)
connectors kit
DFR0502 Gravity: IO Expansion & Motor Driver Shield (Product Image may differ)
The Prizes
Prize Prize Category
Grand Prize
Approximate Value $2100 USD*
  • Flash Forge Guider II 3D Printer
  • iRobot Roomba Self Emptying Robot Vacuum Clearer
Runner Up
Approximate Value $500 USD*
  • iRobot Bravaa Jet Robot Mop
  • Ender 3 V2 3D Printer
Finisher Prize**
To be a finisher you must complete 5 blogs and show us your testing the resilience of the project.
Approximate Value $30 USD*
  • Multicomp Pro Multimeter
*Or local equivalent
**Grand Prize and Runner Up winners also earn the finisher prize.
  • cstanton
    cstanton over 4 years ago in reply to dwinhold
    For visibility some conversations and questions may be better had in the forums
    /challenges-projects/design-challenges/twist-turn-and-move-design-challenge-with-te-robotics/f/forum
  • dwinhold
    dwinhold over 4 years ago in reply to dougw
    I’m in the same boat, I’ll be completed as well. It is just noted above the dates.
    dougw over 4 years ago in reply to dwinhold
    I just got a shipment of connector pins from Randall yesterday. (Thanks rscasny) Still waiting for a bunch of material and some PCBs, but stuff is starting to trickle in. Lots of work left to complete...I'm not actually pushing for an extension, but it is going to be tight.
  • dwinhold
    Will there be an extension on the completion date?
  • cstanton
    cstanton over 4 years ago in reply to Jan Cumps
    "I PM'd the Twitter account with what was going wrong."
    This's often a good fall-back, unfortunately we don't have any members of the team that work weekends, but they'd have seen it today.
    I also have access to https://www.twitter.com/e14cm if anyone wanted to reach out directly.
  • dwinhold
    dwinhold over 4 years ago in reply to cstanton
    Thank you for your reply. Before I posted in Feedback and Support I wanted to see if anyone else was having issues. Next time I will send it to them first. Thanks again!!
    Dale
    Jan Cumps over 4 years ago in reply to cstanton
    If you're having site problems, please make sure to post them in Feedback and Support so that the development teams see them.
    Feedback and Support didn't work this week-end. There was no submit button once you wrote a report. I PM'd the Twitter account with what was going wrong.
  • cstanton
    Hi dwinhold,
    If you're having site problems, please make sure to post them in Feedback and Support so that the development teams see them. While I may see comments on posts such as this, it's better to make sure it's in a place that's visible for everyone to see.
    I'm aware of a site problem that happened over the weekend, unfortunately we had no server admin staff available to address the issue.
    Hopefully today should be better.
    I'm having the same problem, no luck this weekend.
  • dwinhold
    I'm not sure about anyone else, but I have been having issues posting my blogs for the past 3 weeks. Attaching photos or adding code always kicked me out of the site. I managed to get a blog uploaded today after 6 tries. I keep getting this message:
    An error occurred. Please try
    again or contact your
    administrator.
    and
    You've gone offline.
    Attempting to reconnect....
