Ultimate RoadTest
  • Ultimate RoadTest
Ultimate RoadTest
Blog Project "code name" PostScript 004
  • Author Author: COMPACT
  • Date Created: 5 Jul 2012 10:50 AM Date Created
  • Views 854 views
  • ultimate_roadtest
COMPACT
COMPACT
5 Jul 2012
July 5th
Text to Speech Conversion Details
Attached are some test samples.
The Text to Speech conversion is currently done using a PC to create the an 8 bit 8kHz PCM required by the DAC.
The sample data is extracted from the .WAV file and will be loaded into the FRAM buffer for play back.
Play this audio clip
