Ultimate RoadTest
  • Ultimate RoadTest
Ultimate RoadTest
Blog The Bread & Butter : 09
  • Author Author: HNTE
  • Date Created: 11 Jun 2012 3:50 AM Date Created
  • Views 1262 views
  • bread
  • cc3000
  • grace
  • matrix
  • led
  • led_controller
  • home_automation
  • eagle_pcb
  • bread_&_butter
  • ultimate_roadtest
  • tlc59025
HNTE
HNTE
11 Jun 2012
June 11th : A Little Bit Of Colour
So I remember reading somewhere that we are meant to be including some of the TI lighting solutions in our projects. This sort of this is right down my alley, as it happened I had a bunch of RGB LEDs some of the TLC59025 Led sink driver ICs and a faulty LED driver PCB from my RGB cube that I could cut/hack to make into something new.
At the moment I still have no idea how I am going to include my colourful little addition into my project, but I am sure I will think of something.
I didn't feel like multiplexing with my array so I am using one output for each red, green and blue diode in my LEDs, so for the 3x9 array that is a total of 81 outputs to control each LED individually. The TLC59025 LED driver are really easy to drive, you clock the output data into the shift registers and then latch the output to move the data from the shift registers to the drive registers. You can chain these ICs up in a long cascade to drive as many LEDs as you wish, I am using three separate chains to drive the red, green, and blue channels. This way I can clock in the three data lines at the same time speeding up the process a bit.
Check out these pictures I prepared earlier to "hopefully" get an idea of how to drive these things.
The Bread & Butter : 10
  • ssilberhorn
    ssilberhorn over 14 years ago +1
    Learn more about TI LED solutions at www.ti.com/led or download the LED Reference Design Cookbook today... Also try the Reference Design Selection Tool and the Webench LED Architec t.
  • ssilberhorn
    Also try the Reference Design Selection Tool and the Webench LED Architect.
    http://www.ti.com/ww/en/lighting/bulb/images/ti_led_bulb_replacement_selector_banner.pngimageimage
  • ssilberhorn
    DAB over 14 years ago in reply to ssilberhorn
    Hi Shawn,
    I appreciate you adding the links to TI support documents and tools.  When I read these updates I get ideas and it is very easy for me to jump right to the TI site for more information.
    Thanks
