Ultimate RoadTest
  • Ultimate RoadTest
Ultimate RoadTest
Blog The Bread & Butter : 10
  • Author Author: HNTE
  • Date Created: 12 Jun 2012 9:40 AM Date Created
  • Views 1305 views
  • ads1131
  • cc3000
  • colour
  • led
  • rgb
  • eagle_pcb
  • bread_&_butter
  • ultimate_roadtest
  • tlc59025
HNTE
HNTE
12 Jun 2012
June 12th : Light it Up
Here is a quick video of my little display showing of its true colours. Unfortunately the quality is pretty shocking, I can never seem to get a good video of my light displays (anyone who knows some tricks for filming bright LEDs let me know).
I use Bit Angle Modulation (BAM) for the colour fading, 8 bit modulation allows me to generate 16 million or so colours. I am sure there are plenty of different ways to implement BAM but this is my way and it works, I store the current animation frame in a 9x3 matrix and the interrupt does the rest.
//BIT ANGLE MODULATION IN AN INTERRUPT
unsigned char bitpos = 0x00;
unsigned char bitcount = 0x00;
unsigned int bitlength = 0x01;
void Timer0_A3_ISR(void){
      if(bitcount == 0){
           HIGH(OE);
           load_matrix(); //LOAD THE ARRAY ONTO THE MATRIX
           LOW(OE);
      bitcount += 0x01;
      if(bitcount >= bitlength){
           bitpos += 0x01;
           bitlength = bitlength<<0x01;
           bitcount = 0x00;
      if(bitpos >= 8){
           bitpos = 0x00;
           bitcount = 0x00;
           bitlength = 0x01;
           state |= update;
//LOAD THE DATA ONTO THE LED DRIVER BOARD
void load_matrix(void){
      int x, y;
      for(x = 0; x < 9; x++){
           for(y = 0; y < 3; y++){
                if((matrix[x][y].red)&(0x01<<bitpos)){
                     HIGH(SDIR);
                if((matrix[x][y].green)&(0x01<<bitpos)){
                     HIGH(SDIG);
                if((matrix[x][y].blue)&(0x01<<bitpos)){
                     HIGH(SDIB);
                PULSE(CLK);
                LOW(SDI_ALL);
      PULSE(LE);
Because the launchpad is pretty strapped for memory and it is a bit sluggish when it comes to playing with floating point numbers, I needed a new way to generate a colour wheel. Usually I create a large array in memory, or use sine functions to generate the colours, this time I decided to go with a clever little conditional function.
My getColour function can generate 768 different colours, you hand the function an integer between 0 and 768 and it will spit out a colour from the colour wheel. I painted a picture below to try and explain myself a little better, the numbers in the image are the integer you hand to the getColour function... Obviously the function fades the colours a little better than I did in paint.
typedef struct{
      unsigned char red;
      unsigned char green;
      unsigned char blue;
}colour;
colour getColour(int c){
      colour result;
      while(c >= 768){
           c-=768;
      if(c >= 0 && c < 256){
           result.red = c;
           result.green = 0;
           result.blue = 255-c;
      }else if(c >= 256 && c < 512){
           c-=256;
           result.red = 255-c;
           result.green = c;
           result.blue = 0;
      }else if(c >= 512 && c < 768){
           c-=512;
           result.red = 0;
           result.green = 255-c;
           result.blue = c;
      return result;
The Bread & Butter : 11
    DAB over 14 years ago
    It looks like you have a good start at a full color output device.
    Have you decided how you are going to use it yet?
    Anyway, good demo and code post.
