Imagine a World Without Cords
  • Imagine a World Without Cords
Blog AAA To AA Qi Battery Holders
  • Author Author: johnsocm
  • Date Created: 7 Nov 2012 10:42 PM Date Created
  • Views 1601 views
  • wireless_power
  • wireless_power_home
  • wireless_power_challenge
  • power_system
  • wireless_power_charging
  • qi_standard
  • wp_challenge_one
johnsocm
johnsocm
7 Nov 2012
Hello World,
I have a short post about what COMPACT has made! It was very impressive that he made the AA and AAA holders with the 3D printer. I wanted to share with you a cheap alternative for those of us that do not have access to a 3D printer.
I bought a set of these BlueCell simulated battery holders a while back and now I finally have a chance to use them! Now you can get these pretty much everywhere online, just look up AAA to AA Converters. They are used to convert a AAA to a AA size of battery. You can get pretty much any type of Conversion you would like.
Starting from the left is a AAA Battery, AA Battery, AAA inside AA Holder, Empty AA Holder, AAA inside AA Holder, Tips of the AA holder.
They are very inexpensive and now whether a 3D model or these holders, everyone will be able to transform anything battery powered to a Qi Powered Device with ease.
Problem:
I have made a simple way to add a buck boost chip inside one of the batteries. This uses all of the voltages combined and boosts the voltage to a battery voltage. There are different versions of this device, since the Qi Receiver outputs 5.0V, we need to be able to access the different voltages for different devices. Example 1:
     A TV Remote usually has 2 AA or AAA batteries = 1.5V x 2 = 3V
     A TI-89 or other simular calculator has 4 AAA batteries = 1.5V x 4 = 6V
Therefore, a battery holder can have a built in step up/step down or buck boost to solve these voltages. A small Qi receiver will be built in between the two AAA batteries and a coil is easily mounted on the door of the TI-89.
I will post a solution to this problem later.
Thank you,
Chad
