Imagine a World Without Cords
  • Imagine a World Without Cords
Blog Final Reverse Engineering - Powermat...Non Qi Enabled Version
  • Author Author: johnsocm
  • Date Created: 30 Oct 2012 1:50 PM Date Created
  • Views 855 views
  • wireless_power
  • wireless_power_home
  • wireless_power_challenge
  • wireless_designs
  • wireless_power_charging
  • qi_standard
  • qi
  • wp_challenge_one
  • wireless_power_consortium
johnsocm
johnsocm
30 Oct 2012
Hello World,
I wanted to explore one final design before I create my final PCB for the BeagleBone BeagleBone Qi Cape and Raspberry Pi - Qi Pi.
I was very fascinated to see that out of all the designs we explored, the Powermat for some strange reason used a coil implemented on a PCB. This design works really well but for distance wise, I am only able to charge a device that is sitting directly on the Powermat. I am not able to charge anything that is raised up even a milimeter. The Wurth Coil is very powerful and definitely the coil I will be using in my design. I am not quite certain if this PCB coil would work better in a Qi environment rather than a inductive standard charger environment. I could test this PCB to see how well it performs with the eval kit, but I am assuming it will not be as good as the coil from Wurth as the Wurth Coil has two layers of coil and thicker diameter wire.
Here are pictures of the transmitter side of the iPhone 3GS Powermat.
Transmitter:
Circuit Board Coil:
Does not power Qi Devices:
Very slim design!
Thank you,
Chad
  • lfa555
    lfa555 over 13 years ago
    Hey Chad that is quit interesting! I didn't expect there to be such a big difference in the Energizer and the Powermat. It seems that Powermat is already on that market since quit some time...i would even say sine before QI.
    There you can clearly see that it is nice to have this QI standard now! Great work Chad!
  • lfa555
