Imagine a World Without Cords
  • Imagine a World Without Cords
Blog It's Alive! Part 014
  • Author Author: COMPACT
  • Date Created: 8 Nov 2012 8:08 AM Date Created
  • Views 941 views
  • wireless_power
  • wireless_power_home
  • wireless_power_challenge
  • power_system
  • wireless_power_charging
  • qi_standard
  • BeagleBone
  • wp_challenge_one
COMPACT
COMPACT
8 Nov 2012
beaglebone day
I got the beaglebone working successfully with my current rig.
Since I need 5V to boot up the beaglebone I swapped out the Simple Switcher with an LMR62014XMFE/NOPBLMR62014XMFE/NOPB Step Up regulator.
It came out of the box with a 11.8V output so I piggy backed one of the feedback resistors with a 200k trim pot and adjusted it to output 5.0V
I configured the bq24075T Battery Charger with DPPM to my needs;
  • EN1 = Vss, EN2 = Vdd to use Rlim setting
  • 1A peak current input by adjusting Rlim to 1.6k
  • 500mA peak fast charging current by adjusting 1.8k (Allowing 500mA always for beaglebone)
  • Configured SYSOFF to Vss for Automatic battery Switchover active
Testing was conducted to see if the beaglebone booted up
  • from Li-Ion Battery - Worked!
  • from Qi Wirless Power - Worked!
If the beaglebone remained operating when changing power source
  • Qi Power removed with Li-Ion Battery remained connected (i.e. Battery Only)- Worked!
  • Li-Ion Battery Power with Qi Power restored - Worked!
  • Qi Power with Li-Ion Battery removed (i.e. Qi Power only) - Worked!
  • Qi Power with Li-Ion battery reconnected - Worked!
To check the power being drawn I observed the transmitter's power supply ammeter.
It read a peak of .240A (x 19V) = 4.56W - Not too bad for a first attempt.
It shows that the input current limiting feature is working as planned.
These settings can be further tuned as required.
    DAB over 13 years ago
    Good job Monte.
    I like how you solve problems with simple solutions.  You demonstrate numerous ways in which the technologies can be integrated together with off the shelf components.
    Keep up the good work,
  • johnsocm
    johnsocm over 13 years ago
    Very Nice COMPACT! The bq24075T is definitely a way to go for efficient compact easy design! I will be using this or the BQ24079 in the Qi Lime Pi Slice. (A Qi powered/battery charging Cape with minimal components)
    I love the video!
