Blog IP:08 The Smart container explained.
  • Author Author: ipv1
  • Date Created: 24 Apr 2014 8:35 AM Date Created
  • Views 903 views
  • beyond_the_phone
ipv1
ipv1
24 Apr 2014
This is a short video explaining the project proposal submitted for the beyond the phone challenge.
https://www.youtube.com/watch?v=jZMiB0LujxE
Smart Container Project explaination
  • ipv1
    ipv1 over 12 years ago in reply to kevjose +1
    Hi kevin, Well I will be connecting an SD card but I have a solution... kinda... I have an ethernet shield which is possibly something I might use as a last resort. I could hack together you recommendation…
  • kevjose
    kevjose over 12 years ago
    Hey!
    Good job!
    If you are looking for a way to interface the SD cards, there is no need for level shifters unless you are using a really high end card, you could simply interface it with the arduino with resistor voltage dividers. Some people recommend against using a resistor based circuit but I ran the bench-marking test for the one I built and it runs as good as the SD slot of the official Ethernet shield. A quick hack would be to solder directly onto a microSD adapter to break out the pins.
    Let me know if I can be of any help with the SD card interface.
    Kevin
  • kevjose
    Hey!
    Good job!
    Kevin
  • ipv1
    Hi kevin,
    Well I will be connecting an SD card but I have a solution... kinda... I have an ethernet shield which is possibly something I might use as a last resort. I could hack together you recommendation, but only as a last resort.
    Thanks,
    IP
  • kevjose
    kevjose over 12 years ago in reply to ipv1
    Alright! Well, best of luck with your build.
    Kevin Jose
