Blog Shaky hands and precision soldering do not mix
  • Author Author: aemarconnet
  • Date Created: 14 Apr 2014 2:21 PM Date Created
  • Views 3321 views
  • Comments 13 comments
  • wireless_power_challenge
  • beyond_the_phone
aemarconnet
aemarconnet
14 Apr 2014
For prototyping purposes i was hoping to try my hand at soldering some leads to a super-cap charger from TI. Unfortunately the package is a 16VQFN and my feeble attempt at tacking leads onto these 0.2MM pitch pads did not end well. I think the photo below gives a good indication of of the size of the package. (keep in mind my hands are not HUGE)
After a little over an hour of effort trying to solder leads to this package i gave up. I will have to build a breakout PCB for this, but it seems my solder paste is expired and i will need some more single-sided, copper-plated, PC board. The order is placed on amazon and i should have them soon this week.
Anybody have recommendations for soldering these small packages? The only re-flow i have done is repair to electronics like the XBox 360 GPU (Red Ring of Death).
Wish me luck!
Alex
    DAB over 12 years ago +2
    Just wait until your eyesight fails and you get arthritis in your hands. That's when you know its time to let others do these kinds of things. DAB
    mcb1 over 12 years ago in reply to DAB +1
    The eyesight is enough .. let alone adding shaky hands or arthritis. I had to replace a smd chip the other day, and despite having the appropriate hot air smd tool, it was still strange to rely on heating…
  • michaelwylie
    michaelwylie over 12 years ago +1
    I solder almost exclusively under a microscope because of stuff like this. Advice for soldering leads to that? It's really ambitious and it makes me anxious just to think about it. I can just imagine getting…
  • michaelwylie
    That's a nice setup, I like it. You've got enough there to be dangerous (it's a North American expression).
  • aemarconnet
    aemarconnet over 12 years ago in reply to michaelwylie
    It works well, i was actually quite surprised with the quality of my X-Tronic solder station/re-flow station, i bought it a few years back and it has been good to me. i think i only spent ~70 USD on the unit and it came with that lamp as well as spare heating elements and a variety of solder and reflow tips.
    Unfortunately, the rest of my setup is missing right now. I'm still living out of boxes (when it comes to my basement office). If you look in the background you can see some of the units i need to sort through. i have a veritable wall of boxes (not shown) 30 feet long and 2-3 deep. But i did manage to find my multimeter and soldering iron. So I've got the bare essentials.
  • michaelwylie
    michaelwylie over 12 years ago in reply to aemarconnet
    Hahaha, is that a coffee maker? Love it! All the essentials.
  • michaelwylie
  • aemarconnet
    Why yes indeed you are correct, it is a "Tassimo" and it is one of my most important tools. Something has to keep me going when projects are on a roll. On the flip side, If you were to look in the top right drawer of that desk you would find a bottle of scotch for when projects just aren't working.
    mcb1 over 12 years ago in reply to aemarconnet
    maybe a few swigs would help steady the hand.
    I was wondering if this might work.
    • Find a piece of plain pcb or protoboard.
    • Stick the chip upside down to the pcb using a bit of bluetac or similar.
    • Solder wires onto plain pcb around the chip or pins you want to connect to.
    • Once soldered, mechanically arrange the wire to touch the pin on the chip.
    • Solder the wire at the chip.
    • Remove the pcb end of the wire (or connect to it).
    Looks like my sample pieces are the same.
  • aemarconnet
    aemarconnet over 12 years ago in reply to mcb1
    Mark, that is a really good idea...it would take at least one of my shaky hands out of the equation....i should have some copper board here soon and should be able to just surface mount and make my own break-out board; but i think your idea is worth a shot.
    I usually find a few swigs takes out both shaky hands ...
    well at least until you have shaky hands pouring it ....
    DAB over 12 years ago in reply to mcb1
    I like your solution, especially with a good 12 year old scotch with just a touch of water to bring out the aroma.
    Ah the pleasant bouquet combined with rosin smoke makes for a pleasant work place.
