Blog Waterproofing marine equipment - 08 - Transmitter Design Considerations
  • Author Author: ForcisConnect
  • Date Created: 28 Apr 2014 8:29 PM Date Created
  • Views 2127 views
  • Comments 10 comments
  • waterproofing_marine_equipment
  • beyond_the_phone
ForcisConnect
ForcisConnect
28 Apr 2014
Transmitter Design:
This week I want to write a little about the design of the transmitter.
There is a ton of information on the TI website on how to design the transmitter:
  • http://www.ti.com/lit/ug/sluuap8a/sluuap8a.pdf  (Reference Design)
  • http://www.ti.com/lit/an/slua698/slua698.pdf (bqTesla Transmitter  bq500212A Design)
  • http://www.ti.com/general/docs/lit/getliterature.tsp?genericPartNumber=bq500212a&fileType=pdf (bq500212A Datasheet)
  • http://www.ti.com/lit/ug/slvu928a/slvu928a.pdf (bq500212A EVM User’s Guide)
Again, I based my design on the reference design provided by TI (link above)
On the transmitter side we need a few additional ICs to make it work:
  • TLV70033: 200mA Low Dropout Regulator
  • CSD97376: Synchronous BuckNextFetPower Stage. This IC includes the MOSFETs and drivers in one package. It can be substituted with a discrete solution, but I opted for the IC to keep the footprint small.
  • INA199A1: Current Monitor: In order to achieve Qi-compliance, it is required to measure the current flowing through the emitter coil. Although I do not intend to certify my design, I included the I-Sense circuit. It doesn’t take too much space, and who knows what I will use this for in the future.
I did not find these (except for the TLV) on any of the libraries I have installed, so I had to learn how to make custom parts in eagle. Not difficult once you understand the process, but it took me more time than I thought it would. Specially the footprint for the CSD97376 is quite strange and caused some problems.
I also had to design the components for the BSS138 MOSFET, the BAT54 diode and the DTC114 transistor. These may be somewhere available, but I found it easier to do it myself. I still have not checked the footprints with a real component, so there may be errors. Once I do I will let you know if something is wrong.
One of my design goals with both the receiver and transmitter is to keep the board’s size smaller or equal to the size of the receiving/transmitting coils.
Some advice I found on the datasheets and I tried to follow with my layout:
  • Place the decoupling caps as close as possible to the IC and keep a low impedance return path to GND
  • Keep as much copper as possible
According to TI, a 2 layer board may show poor performance. Nevertheless I decided to give it a try and go that way, as it is cheaper to fabricate. If problems showed up, a 4 layer board would be used, “sandwiching” the bottom layer between two ground planes.
Schematic:
PCB layout:
BOM:
Qty
Value
Device
Package
Parts
2
CAP
0603
C23, C24
1
CAP
1206
C28
3
LED0603
0603
LED1, LED2, LED3
1
Vin Header
1X02_LOCK
JP1
1
  1. 0.020
RESISTOR
0805
R29
2
  1. 0.1uF
CAP
0603
C3, C4
2
1
RESISTOR
0603
R1, R2
1
  1. 1.0k
RESISTOR
0603
R32
3
  1. 1.0uF
CAP
0603
C15, C18, C30
4
10
RESISTOR
0603
R6, R7, R30, R31
1
  1. 10.0k
RESISTOR
0603
R5
1
100k
RESISTOR
0603
R3
4
100nF
CAP
1210
C7, C8, C9, C10
12
10k
RESISTOR
0603
R12, R13, R15, R16, R24, R25, R26, R27, R28, R37, R40, R41
1
10k NTC
RESISTOR
0603
R14
2
10uF
CAP
1210
C5, C6
1
  1. 12.1k
RESISTOR
0603
R4
5
1uF
CAP
0603
C1, C2, C19, C20, C22
1
22
RESISTOR
0805
R17
1
22uF
CAP
1210
C21
2
2M
RESISTOR
0603
R38, R39
2
  1. 3.6k
RESISTOR
0603
R22, R23
1
33pF
CAP
0603
C12
1
  1. 4.7nF
CAP
0603
C14
6
  1. 4.7uF
CAP
0603
C16, C17, C25, C26, C27, C31
1
  1. 4.7uF
CAP
0805
C29
1
  1. 42.2k
RESISTOR
0603
R18
2
4700pF
CAP
0603
C11, C13
6
475
RESISTOR
0603
R8, R9, R11, R33, R34, R35
1
  1. 48.7k
RESISTOR
0603
R19
1
523k
RESISTOR
0603
R36
1
  1. 53.6k
RESISTOR
0603
R21
1
  1. 56.2k
RESISTOR
0603
R20
1
  1. 76.8k
RESISTOR
0603
R10
1
AC COIL
PINS
  1. 2.54 pins
JP2
2
BAT54
BAT54
SOT23
D1, D2
1
BQ500212AA
BQ500212AA
RGZ_SPVQFN-N48
U1
2
BSS138
BSS138
SOT23
Q1, Q2
2
CSD97376
CSD97376
SON3.5X4.5
U2, U3
1
DTC114EUAT
DTC114EUAT
SOT23
Q3
1
GND-TIE
GND-TIE
SHORT
X1
1
INA199A1
INA199A1
SC70-6
U4
1
TLV700XX
TLV700XX
SC70-5
U5
Besides laying out the pcb there hasn’t been much engineering work this time. Most of my time went into copying the schematic into eagle and creating the necessary parts.
So I finally have also a transmitter board design.  It is significantly more complicated than the receiver and has a lot more components. Therefore I will first try my luck with the receiver board assembly, and, if everything works, build the transmitter.
One thing I’m still wondering is where or to what the net /TRST, labeled at pin 31 of bq500212A reference design schematic, should be connected. Maybe a remainder of a previous version?
As always, feedback and comments are welcome.
Wireless Transmitter.zip
  • ipv1
    ipv1 over 12 years ago
    Kudos for the above. It did not occur to me to (re)design the charging circuit. I guess even if I had tried, I would have hit a brick wall since getting the PCB manufactured in India takes either lots of money or lots of time(pay for shorter lead times).
    Good job.
    Cheers
  • ipv1
    Good job.
    Cheers
  • ForcisConnect
    ForcisConnect over 12 years ago in reply to ipv1
    I have ordered the PCBs for both the receiver and transmitter at oshpark, and paid for express shipping. Hope they reach me in a timely manner
