Blog Waterproofing marine equipment - Initial Thoughts
  • Author Author: ForcisConnect
  • Date Created: 14 Mar 2014 11:47 AM Date Created
  • Views 1134 views
  • Comments 6 comments
  • beyond_the_phone
ForcisConnect
ForcisConnect
14 Mar 2014
First, I want to thank Element14, Würth and TI for giving me the opportunity to test their devices. I’m really excited and look forward to get my evaluation kit and start experimenting!
As a sailor, I have always been interested in the application on new technologies to the marine boating industry and it has repeatedly surprised me how long it takes until a new feature gets implemented in a boating product. In my opinion, a main reason therefore is how aggressive the marine environment is. Salt, water and electronics have never been a good mix.
Therefore, Wireless Power offers a perfect solution in order to completely seal our products, reducing the risk of water damage.
My plan is to divide the work for the future months into several sub-projects or parts
  1. General Testing
I would like to start with testing a little bit the development kit and playing around with it. At first, I am thinking of testing efficiency while varying the distance between the coils, the materials between coils and maybe even taking a look at different coils. But it really all depends and I may come up with other parameters to measure. All this has probably been already done and I see it more as a nice way of getting started.
   2.   PCB Design
I would like to design a PCB with a small footprint with all necessary power management included. This means the wireless power and li-po charging solution, as well as a buck-boost converter to give a nice and stable 3.3V output regardless of battery state. Maybe I could also add even another version with a 5V output.
   3.   Assembly, Testing and Integration into existing “Product”
Once the board is designed I will get them produced by one of the common PCB fabrication services.  After they are home again, I expect to solder them with my latest acquisition/hack, a reflow oven. And then, I will have to test the boards to check that they work as they should. If I still have time I will try to incorporate this design as an add-on to a marine safety product project that I’m currently working on.
So, a lot of work coming in our direction.  I’m sure, whatever the result, it will prove as a very interesting experience.
More to come next week!
Ps: Excuse my English errors; I’m trying my best image
    mcb1 over 12 years ago in reply to ForcisConnect
    About 20-30 years ago they also said we would all be talking to our computers.
    Now I agree they are partly right, but cursing or swearing wasn't what they suggested.
    I think large power transfer is a waste of energy.
    If you obtained 85% efficiency, thats still a lot of lost power, especially for 1000w or more loads.
  • ForcisConnect
    ForcisConnect over 12 years ago in reply to janisalnis
    Yes, wireless power is still only a reasonable solution for low power systems. Nevertheless I think we will be seeing higher power transfer solutions appearing in the near future. In the webinar they even spoke of kitchen appliances working with wireless power in the future. And these are really high power.
  • janisalnis
    janisalnis over 12 years ago
    Inspired by your waterproof marine equipment may be you could think about such general product.
    Wirelessly charged backup battery pack for outdoors/camping, boat trips, construction sites
    - Incorporating both TX and RX functions. Easiest implementation would be that one side is RX and other is TX.
    - Hermetically sealed without any connectors or cables.
    - It's internal battery can be charged by placing it over a Qi compatible wireless power transmitter.
    - Including a LCD indicator with battery voltage/capacity.
  • janisalnis
    Two years ago I bought underwater scooter for diving and swimming fun in the lake.
    I it running on 24V 4 AHh lead battery, has a geared motor and two speeds.
    Enclosure is hermetic when in water. It is not allowed to be charged hermetically as gas may come out from lead battery during charging and the thing may explode.There is a rubber sealed screw that has to be unscrewed.
    I don't know how it is in case with LiPo batteries.
    I am thinking on converting my underwater scooter for 5s cell 5Ah LiPos because lead battery has died. Wireless power transmission unfortunately would not be powerful enough to charge in reasonable time.
  • sleuz
    sleuz over 12 years ago
    Hi Eduardo
    This sounds interesting. Looking forward following your progress.
    From my side I can say, that your English is very good. So don´t worry about that.
    Regards
    Simon
