element14 presents
element14 presents
e14 presents blogs Califone 1430K Record Player Teardown
  • Episodes
  • Author Author: airbornesurfer
  • Date Created: 10 Jan 2022 6:22 AM Date Created
  • Views 4646 views
  • project califone
airbornesurfer
airbornesurfer
10 Jan 2022
The Califone 1400 series record players were built like tanks: able to be thrown across a classroom, climbed upon by kindergartners, and still keep playing! Let's take a peak inside and see just how it was built!
This video is unavailable.
The big takeaway from this expedition is that the internals are extremely simple. Despite the relatively large size of the unit, most of the internal space is empty. A 12" speaker driver sits behind the steel grille on the front of the unit and a small 3x5-inch PCB contains all of the electronics. The grounded AC power cable is connected to a 4:1 transformer providing 30VAC to the dedicated turntable motor, tonearm light, and a small rectification circuit on the PCB that powers the amplifier circuitry.
I'll have to make a better copy of this schematic for posterity. Fortunately, Califone was good enough to glue one inside the case. I'll just have to copy it into Fritzing to make it a little more legible and update this article once it's available.
Some 1400 series phonographs had their AC motors replaced with DC models as they were cheaper to produce and didn't require 60Hz mains for timing. Califone issued a service bulletin in 1990 to illustrate the process for their field technicians. At least mine is still original. I'll attach my collection of service bulletins to this post.
Now that I've got a pretty solid idea how this thing goes together, it's time to start redesigning the electronics.
Also featured on AirborneSurfer.com
Califone 1400 Service Manuals.zip
    Jan Cumps over 4 years ago +1
    Motor seems to be 120 V on the schema.
  • airbornesurfer
    airbornesurfer over 4 years ago in reply to Jan Cumps
    By Jove, I believe you're correct!
