element14 presents
element14 presents
e14 presents blogs Arduino, Raspberry Pi, or ??? I'm Hacking Philips Hue Lights and I need your help!
  • Author Author: TechnoChic
  • Date Created: 1 Mar 2023 5:03 PM Date Created
  • Views 3797 views
  • Likes 10 likes
  • Comments 19 comments
  • Philips Hue
  • led
  • raspberry pi
  • led lighting
TechnoChic
TechnoChic
1 Mar 2023
Hi! It's Natasha.
I'm working on my next project for Element14 Presents which involves hacking the Philips Hue Lighting System. I need your help to determine which path I should take - please watch the video for the details of the project:
I will need to spend a lot of time learning to work with the Philips Hue API (and there's even a new one that just came out!) So, I want to make a well-informed decision:
  1. Should I use Arduino, Raspberry Pi, or another system?
  2. I will need 5 sensors (one under each cabinet) to detect my presence within a few feet of the sensor. What sensor system is best? Will it connect easily to the microcontroller system?
  3. What other ideas do you have for controlling the Hue Lights?
Please let me know your thoughts in the comments below. Thanks in advance for your help!
    dougw over 3 years ago +1
    If you are more comfortable with Python, go with the Pi Pico W, if you prefer C, go with the MKR WiFi, although they can both be used with either language. Availability may also dictate which one to use…
    If you are more comfortable with Python, go with the Pi Pico W, if you prefer C, go with the MKR WiFi, although they can both be used with either language. Availability may also dictate which one to use. Another alternative would be an ESP32. which are also available from Newark.
    Those IR sensors work well.
  • TechnoChic
    TechnoChic over 3 years ago in reply to dougw
    Thanks! What IR sensor specifically do you like?
  • charlieo21
    charlieo21 over 3 years ago in reply to TechnoChic
    I suggest you these sensors:
    VCNL4040-SB - Vishay - Proximity & Ambient Light Sensor/Infrared Emitter I2C For SensorXplorer Demonstration Board (newark.com)
    VL6180-SATEL - Stmicroelectronics - TOF PROXIMITY SENSOR BREAKOUT BOARD ROHS COMPLIANT: YES (newark.com)
    dougw over 3 years ago in reply to TechnoChic
    Buy Now
    These are low cost enough to put everywhere. They have an adjustable sensitivity and adjustable hold time after being triggered. No software needed, unless you want more complex behavior. For example you could have one set for high sensitivity that activates an "approaching" color and level, and another sensor setup for lower sensitivity that detects when you are close and turns LEDs on full.
  • TechnoChic
    Ah great! It looks similar to what came in the Arduino kit, I could just get some more! Thanks
  • TechnoChic
