element14 presents
element14 presents
e14 presents blogs How To Build An Arduino Joystick Mouse
  • Episodes
  • Author Author: airbornesurfer
  • Date Created: 22 Mar 2019 1:13 PM Date Created
  • Views 3042 views
  • arduino leonardo
  • project xyberpunk
  • adafruit feather
  • arduino_tutorials
  • xybernaut
  • atmega32u4
  • mouse
  • joystick mouse
airbornesurfer
airbornesurfer
22 Mar 2019
Xybernaut Wearable PC
element14 presents  |  AirborneSurfer's VCP Profile |  Project Videos
In this video, we'll use the Arduino Leonardo-compatible Adafruit ATmega32u4 Featherboard to build a joystick-style mouse that can be used with any USB-equipped computer. This will be built into Project Xyberpunk to replace the Trackpoint-style mouse module in the original design.
Here's the code, for those of you following along at home:
//Project Xyberpunk v1.0
//Joystick mouse module
//Feb 15, 2019
//CC-BY-SA
//Includes some public domain code by David A Mellis & Tom Igoe
//(I know I don't have to give credit, but I like to when I can)
//Matthew Eargle
//Element14 Presents
//element14.com/presents
//AirborneSurfer Productions
//airbornesurfer.com
#include <Mouse.h>
const int leftButton = 10;
const int rightButton = 11;
const int xPin = A0;
const int yPin = A1;
int xValue = 0;         // the sensor value
int xMin = 1023;        // minimum sensor value
int xMax = 0;           // maximum sensor value
int yValue = 0;
int yMin = 1023;
int yMax = 0;
//Refresh rate between polling intervals, lower is smoother movement
#define REFRESH_RATE 1
static unsigned long lastRefresh = 0;
void setup()
  Serial.begin(115200);
  pinMode(leftButton, INPUT);
  pinMode(rightButton, INPUT);
  // turn on LED to signal the start of the calibration period:
  pinMode(13, OUTPUT);
  digitalWrite(13, HIGH);
  // calibrate during the first five seconds
  while (millis() < 5000) {
    xValue = analogRead(xPin);
    yValue = analogRead(yPin);
    // record the maximum sensor value
    if (xValue > xMax) {
      xMax = xValue;
    if (yValue > yMax) {
      yMax = yValue;
    // record the minimum sensor value
    if (xValue < xMin) {
      xMin = xValue;
    if (yValue < yMin) {
      yMin = yValue;
  // signal the end of the calibration period
  digitalWrite(13, LOW);
  Mouse.begin();
void loop()
  digitalWrite(leftButton, HIGH);
  digitalWrite(rightButton, HIGH);
  int leftClick = digitalRead(leftButton);
  int rightClick = digitalRead(rightButton);
  // left click:
  if (leftClick == LOW) {
    // if the mouse is not pressed, press it:
    if (!Mouse.isPressed(MOUSE_LEFT)) {
      Mouse.press(MOUSE_LEFT);
  // else the mouse button is not pressed:
  else {
    // if the mouse is pressed, release it:
    if (Mouse.isPressed(MOUSE_LEFT)) {
      Mouse.release(MOUSE_LEFT);
  // right click:
  if (rightClick == LOW) {
    if (!Mouse.isPressed(MOUSE_RIGHT)) {
      Mouse.press(MOUSE_RIGHT);
  else {
    if (Mouse.isPressed(MOUSE_RIGHT)) {
      Mouse.release(MOUSE_RIGHT);
  if ((lastRefresh + REFRESH_RATE) < millis())
    moveMouse();
    lastRefresh = millis();
void moveMouse()
  int xValue = analogRead(A1);
  int yValue = analogRead(A0);
  int xMove = (((xValue) - 512) / 50);
  int yMove = ((-1*((yValue) - 512) / 50));
  Serial.print("X: ");
  Serial.print(xMove);
  Serial.print(", Y: ");
  Serial.print(yMove);
  Mouse.move(xMove, yMove, 0);
  Serial.println();
  • airbornesurfer
    airbornesurfer over 6 years ago in reply to flenger +1
    Change the divisor in line 122 or 123 to adjust the speed of the cursor movement. The larger the divisor, the slower the movement.
  • airbornesurfer
  • flenger
    flenger over 6 years ago
    Hi, can you tell me how to reduce the speed of movement by half?
