element14 presents
element14 presents
e14 presents blogs Project ColorTyme Code and Design Assets
  • Episodes
  • Author Author: airbornesurfer
  • Date Created: 16 Sep 2020 12:08 AM Date Created
  • Views 1394 views
  • hexadecimal
  • project colortyme
  • diy clock
airbornesurfer
airbornesurfer
16 Sep 2020
****EPISODE TITLE****
element14 presents  |  AirborneSurfer's VCP Profile |  Project Videos
Arduino sketch:
//Project ColorTyme
//Hexadecimal Color Code Clock
//CC-BY-SA Matthew Eargle
//element14 Presents http://element14.com/presents
//AirborneSurfer Productions http://airbornesurfer.com
//Included Libraries
#include <Wire.h>
#include <LedControl.h>
#include <SPI.h>
#include <Adafruit_RA8875.h>
#include <RealTimeClockDS1307.h>
Setup MAX7219
 pin 8 is connected to the DataIn
 pin 7 is connected to the CLK
 pin 6 is connected to LOAD
 We have only a single MAX7219.
LedControl lc=LedControl(8,7,6,1);
//Define array for LED hex digits
unsigned long delaytime=100;
byte numbers[16] = {
                    B11111100, B01100000, B11011010, B11110010,
                    B01100110, B10110110, B10111110, B11100000,
                    B11111110, B11110110, B11101110, B11110011,
                    B10011100, B11110001, B10011110, B10001110
//Define global variables
int bOnes = 0;
int bTwos = 0;
int gOnes = 0;
int gTwos = 0;
int rOnes = 0;
int rTwos = 0;
int gCycle = 0;
int rCycle = 0;
int hours = 0;
int minutes = 0;
int seconds = 0;
int seconds1 = 0;
int minutes1 = 0;
int hours1 = 0;
int r = 0;
int g = 0;
int b = 0;
float rCount = 0;
float gCount = 0;
float bCount = 0;
uint16_t color = 0;
int setPin = 17;
int hSet = 2;
int mSet = 4;
int switchState=1;
int mOnes = 0;
int mTwos = 0;
int hOnes = 0;
int hTwos = 0;
Adafruit RA8875 Library only supports hardware SPI at this time
Connect SCLK to UNO Digital #13 (Hardware SPI clock)
Connect MISO to UNO Digital #12 (Hardware SPI MISO)
Connect MOSI to UNO Digital #11 (Hardware SPI MOSI)
#define RA8875_INT 3
#define RA8875_CS 10
#define RA8875_RESET 9
//Define parameters and variables for TFT screen colors
Adafruit_RA8875 tft = Adafruit_RA8875(RA8875_CS, RA8875_RESET);
uint16_t tx, ty;
void setup() {
  //DS1307 Setup
  pinMode(A3, OUTPUT);
  digitalWrite(A3, HIGH);
  pinMode(A2, OUTPUT);
  digitalWrite(A2, LOW);
  RTC.set24h();
  RTC.start();
   MAX72XX wakeup call
  lc.shutdown(0,false);
  /* set the brightness */
  lc.setIntensity(0,1);
  /* clear the display */
  lc.clearDisplay(0);
  int counter = 0;
  // RA8875 Initialization
  Serial.begin(9600);
  Serial.println("RA8875 start");
  /* Initialize the display using 'RA8875_480x80', 'RA8875_480x128', 'RA8875_480x272' or 'RA8875_800x480' */
  if (!tft.begin(RA8875_800x480)) {
    Serial.println("RA8875 Not Found!");
    while (1);
  Serial.println("Found RA8875");
  tft.displayOn(true);
  tft.GPIOX(true);      // Enable TFT - display enable tied to GPIOX
  tft.PWM1config(true, RA8875_PWM_CLK_DIV1024); // PWM output for backlight
  tft.PWM1out(255);
  //Time set controls setup
  pinMode(setPin,INPUT_PULLUP);
  pinMode(hSet,INPUT_PULLUP);
  pinMode(mSet,INPUT_PULLUP);
void loop() {
  //Loops through each function in turn
  readTime();
  //Check for setting switch activate
  switchState=digitalRead(setPin);
  if (switchState==0) {
    settingTime();
  displayTime();
  delay(220);
  advanceTime();
  compareTime();
  //Set RGB values to current "count" values, rounding to nearest whole integer
  b = bCount;
  g = gCount;
  r = rCount;
  //Set current HMS to comparative values
  seconds1 = seconds;
  minutes1 = minutes;
  hours1 = hours;
void readTime() {
  //RTC.readClock();
    hours = RTC.getHours();
    minutes = RTC.getMinutes();
    seconds = RTC.getSeconds();
void displayTime() {
  lc.setColumn(0,2,numbers[bOnes]);
  lc.setColumn(0,1,numbers[bTwos]);
  lc.setColumn(0,4,numbers[gOnes]);
  lc.setColumn(0,3,numbers[gTwos]);
  lc.setColumn(0,6,numbers[rOnes]);
  lc.setColumn(0,5,numbers[rTwos]);
  color = ((r * 2048) + (g * 32) + (b));
  tft.fillScreen(color);
void advanceTime() {
  bOnes++;
  gCycle++;
  rCycle++;
  bCount = (bCount + 0.1255);
  gCount = (gCount + 0.004);
  rCount = (rCount + 0.00009);
  if (bOnes == 16) {
    bOnes = 0;
    bTwos++;
  if (bTwos == 16) {
    bTwos = 0;
    bCount = 0;
  if (b > 32) {
    bOnes = 0;
    bTwos = 0;
    bCount = 0;
  if (gCycle == 60) {
    gOnes++;
    gCycle = 0;
  if (gOnes >= 16) {
    gOnes = 0;
    gTwos++;
  if (gTwos >= 16) {
    gTwos = 0;
    gCount = 0;
  if (g > 64) {
    gOnes = 0;
    gTwos = 0;
    gCount = 0;
  if (rCycle == 1436) {
    rOnes++;
    rCycle = 0;
  if (rOnes >= 16) {
    rOnes = 0;
    rTwos++;
  if (rTwos >= 16) {
    rTwos = 0;
    rCount = 0;
  if (r > 32) {
    rOnes = 0;
    rTwos = 0;
    rCount = 0;
void compareTime() {
  if (seconds != seconds1) {
    if (seconds == 0) {
      bOnes = 0;
      bTwos = 0;
      bCount = 0;
  if (minutes != minutes1) {
    switch (minutes) {
      case 15:
        gOnes = 0;
        gTwos = 4;
        gCount = 16;
        break;
      case 30:
        gOnes = 0;
        gTwos = 8;
        gCount = 32;
        break;
      case 45:
        gOnes = 0;
        gTwos = 12;
        gCount = 48;
        break;
  if (hours != hours1) {
    switch (hours) {
    case 0:
      rOnes = 0;
      rTwos = 0;
      rCount = 0;
      break;
    case 1:
      rOnes = 11;
      rTwos = 0;
      rCount = 1.333;
      break;
    case 2:
      rOnes = 5;
      rTwos = 1;
      rCount = 2.667;
      break;
    case 3:
      rOnes = 0;
      rTwos = 2;
      rCount = 4;
      break;
    case 4:
      rOnes = 11;
      rTwos = 2;
      rCount = 5.333;
      break;
    case 5:
      rOnes = 5;
      rTwos = 3;
      rCount = 6.667;
      break;
    case 6:
      rOnes = 0;
      rTwos = 4;
      rCount = 8;
      break;
    case 7:
      rOnes = 11;
      rTwos = 4;
      rCount = 9.333;
      break;
    case 8:
      rOnes = 5;
      rTwos = 5;
      rCount = 10.667;
      break;
    case 9:
      rOnes = 0;
      rTwos = 6;
      rCount = 12;
      break;
    case 10:
      rOnes = 11;
      rTwos = 6;
      rCount = 13.333;
      break;
    case 11:
      rOnes = 5;
      rTwos = 7;
      rCount = 14.667;
      break;
    case 12:
      rOnes = 0;
      rTwos = 8;
      rCount = 16;
      break;
    case 13:
      rOnes = 11;
      rTwos = 8;
      rCount = 17.333;
      break;
    case 14:
      rOnes = 5;
      rTwos = 9;
      rCount = 18.667;
      break;
    case 15:
      rOnes = 0;
      rTwos = 10;
      rCount = 20;
      break;
    case 16:
      rOnes = 11;
      rTwos = 10;
      rCount = 21.333;
      break;
    case 17:
      rOnes = 5;
      rTwos = 11;
      rCount = 22.667;
      break;
    case 18:
      rOnes = 0;
      rTwos = 12;
      rCount = 24;
      break;
    case 19:
      rOnes = 11;
      rTwos = 12;
      rCount = 25.333;
      break;
    case 20:
      rOnes = 5;
      rTwos = 13;
      rCount = 26.667;
      break;
    case 21:
      rOnes = 0;
      rTwos = 14;
      rCount = 28;
      break;
    case 22:
      rOnes = 11;
      rTwos = 14;
      rCount = 29.333;
      break;
    case 23:
      rOnes = 5;
      rTwos = 15;
      rCount = 33.39;
      break;
void settingTime() {
  while (switchState == 0) {
    RTC.stop();
    seconds = 0;
    lc.setColumn(0,2,numbers[seconds]);
    lc.setColumn(0,1,numbers[seconds]);
    lc.setColumn(0,4,numbers[mOnes]);
    lc.setColumn(0,3,numbers[mTwos]);
    lc.setColumn(0,6,numbers[hOnes]);
    lc.setColumn(0,5,numbers[hTwos]);
    int hButton=digitalRead(hSet);
    int mButton=digitalRead(mSet);
    if (hButton == 0) {
      hours++;
      hOnes++;
      if (hOnes == 10) {
        hTwos++;
        hOnes = 0;
      if (hTwos == 2 && hOnes == 4) {
        hTwos = 0;
        hOnes = 0;
        hours = 0;
    if (mButton == 0) {
      minutes++;
      mOnes++;
      if (mOnes == 10) {
        mTwos++;
        mOnes = 0;
      if (mTwos == 6) {
        mTwos = 0;
        mOnes = 0;
        minutes = 0;
  delay(500);
  RTC.setHours(hours);
  RTC.setMinutes(minutes);
  RTC.setSeconds(0);
  RTC.start();
LedControl-Arduino-Library-Plus-Patch.zip
Project-ColorTyme-3D-Designs.zip
Project-ColorTyme-Fritzing.zip
5148.RealTimeClockDS1307-master.zip
Adafruit_RA8875-master.zip
