element14 presents
element14 presents
e14 presents blogs Project Eros Arduino Sketch
  • Episodes
  • Author Author: airbornesurfer
  • Date Created: 14 Feb 2020 3:44 PM Date Created
  • Views 1027 views
  • love meter
  • love tester
  • arduino_tutorials
  • project eros
airbornesurfer
airbornesurfer
14 Feb 2020
I am, by no means, a software engineer. My code is crude at best, but it works image
 * Project Eros
 * CC-BY-SA Matthew Eargle
 * AirborneSurfer Productions
 * for element14 Presents
 * airbornesurfer.com
 * element14.com/presents
#include <Servo.h>
Servo needle;   // create servo object "needle" to move the needle
// declare global variables
const int numReadings = 10;
int readings[numReadings];      // the readings from the analog input
int readIndex = 0;              // the index of the current reading
int total = 0;                  // the running total
int average = 0;                // the average
int meterPosition = 0;
int needlePosition = 0;
int readingMin = 1023;
int readingMax = 0;
int loveMatic = 1;
int heart2 = 2;
int hotStuff = 3;
int fullHearts = 4;
int meter9 = 5;
int meter8 = 6;
int meter7 = 7;
int meter6 = 8;
int meter5 = 9;
int meter4 = 10;
int meter3 = 11;
int meter2 = 12;
int meter1 = 13;
int needlePin = 14;
int brokenHeart = 16;
int coldFish = 17;
int heart1 = 18;
int heart3 = 19;
//int handlePin = 1;
void setup() {
  // initialize serial communication at 9600 bits per second:
  Serial.begin(9600);
  // initialize all the readings to 0:
  for (int thisReading = 0; thisReading < numReadings; thisReading++) {
    readings[thisReading] = 0;
  needle.write(70);
  // set pinmodes for input and output
  pinMode(needlePin, OUTPUT);
  pinMode(hotStuff, OUTPUT);
  pinMode(loveMatic, OUTPUT);
  pinMode(heart3, OUTPUT);
  pinMode(brokenHeart, OUTPUT);
  pinMode(meter1, OUTPUT);
  pinMode(meter2, OUTPUT);
  pinMode(meter3, OUTPUT);
  pinMode(meter4, OUTPUT);
  pinMode(meter5, OUTPUT);
  pinMode(meter6, OUTPUT);
  pinMode(meter7, OUTPUT);
  pinMode(meter8, OUTPUT);
  pinMode(meter9, OUTPUT);
  pinMode(fullHearts, OUTPUT);
  pinMode(coldFish, OUTPUT);
  pinMode(heart1, OUTPUT);
  pinMode(heart2, OUTPUT);
  // attach servo to Arduino
  needle.attach(needlePin);
void loop() {
// read the sensor and show timer
while (millis() < 10000) {
  if (millis() >= 9000 && millis() < 10000) {
    digitalWrite(meter9, LOW);
    digitalWrite(meter8, LOW);
    digitalWrite(meter7, LOW);
    digitalWrite(meter6, LOW);
    digitalWrite(meter5, LOW);
    digitalWrite(meter4, LOW);
    digitalWrite(meter3, LOW);
    digitalWrite(meter2, LOW);
    digitalWrite(meter1, LOW);
    digitalWrite(heart1, LOW);
    digitalWrite(heart2, LOW);
    digitalWrite(heart3, LOW);
  else if (millis() >= 8000 && millis() < 9000) {
    digitalWrite(meter9, HIGH);
    digitalWrite(heart3, HIGH);
    delay(111);
    digitalWrite(heart2, HIGH);
    delay(111);
    digitalWrite(heart1, HIGH);
    delay(111);
    delay(111);
    delay(111);
    delay(111);
    delay(111);
    delay(111);
    delay(111);
  else if (millis() >= 7000 && millis() < 8000) {
    digitalWrite(meter8, HIGH);
    delay(111);
    delay(111);
    delay(111);
    delay(111);
    delay(111);
    delay(111);
    delay(111);
    delay(111);
    delay(111);
  else if (millis() >= 6000 && millis() < 7000) {
    digitalWrite(meter7, HIGH);
    delay(333);
    delay(333);
    delay(333);
  else if (millis() >= 5000 && millis() < 6000) {
    digitalWrite(meter6, HIGH);
    delay(333);
    delay(333);
    delay(333);
  else if (millis() >= 4000 && millis() < 5000) {
    digitalWrite(meter5, HIGH);
    delay(333);
    delay(333);
    delay(333);
  else if (millis() >= 3000 && millis() < 4000) {
    digitalWrite(meter4, HIGH);
    delay(333);
    delay(333);
    delay(333);
  else if (millis() >= 2000 && millis() < 3000) {
    digitalWrite(meter3, HIGH);
    delay(333);
    delay(333);
    delay(333);
  else if (millis() >= 1000 && millis() < 2000) {
    digitalWrite(meter2, HIGH);
    delay(333);
    delay(333);
    delay(333);
  else if (millis() >= 0 && millis() < 1000) {
    digitalWrite(meter1, HIGH);
    delay(333);
    delay(333);
    delay(333);
// take readings from the handles and find the average (adapted from "smoothing" example code)
// subtract the last reading:
  total = total - readings[readIndex];
  // read from the sensor:
  readings[readIndex] = analogRead(A1);
  // add the reading to the total:
  total = total + readings[readIndex];
  // advance to the next position in the array:
  readIndex = readIndex + 1;
  // if we're at the end of the array...
  if (readIndex >= numReadings) {
    // ...wrap around to the beginning:
    readIndex = 0;
  // calculate the average:
  average = total / numReadings;
  // send it to the computer as ASCII digits
  Serial.println(average);
  delay(1);        // delay in between reads for stability
  Serial.println("done!");
  int reading = average;
  needlePosition = map(reading, 400, 1023, 120, 0);     // scale meter value to use it with the servo (value between 0 and 180)
  meterPosition = map(reading, 400, 1023, 0, 10);   // scale meter value for light meter (value between 0 and 10)
  meterPosition = constrain(meterPosition, 0, 10);
  Serial.println(meterPosition);
  needle.write(120);
  delay(200);
  finish();
void finish() {
  switch (meterPosition) {
    case 0:
      while(true) {
        digitalWrite(brokenHeart, HIGH);
        digitalWrite(coldFish, LOW);
        delay(200);
        digitalWrite(brokenHeart, LOW);
        digitalWrite(coldFish, HIGH);
        needle.write(140);                  // sets the servo position according to the scaled value
        delay(200);
    case 1:
      while(true) {
        delay(200);
        needle.write(needlePosition);                  // sets the servo position according to the scaled value
        delay(200);
    case 2:
      needle.write((needlePosition+120)/2);
      delay(200);
      while(true) {
        delay(200);
        delay(200);
    case 3:
      delay(200);
      needle.write((needlePosition+120)/3);
      delay(200);
      while(true) {
        delay(200);
        delay(200);
  case 4:
      delay(200);
      delay(200);
      needle.write((needlePosition+120)/4);
      delay(200);
      while(true) {
        delay(200);
        delay(200);
  case 5:
      delay(200);
      delay(200);
      delay(200);
      needle.write((needlePosition+120)/5);
      delay(200);
      while(true) {
  case 6:
      delay(200);
      delay(200);
      delay(200);
      delay(200);
      needle.write((needlePosition+120)/6);
      delay(200);
      while(true) {
        digitalWrite(hotStuff, HIGH);
        delay(200);
        digitalWrite(hotStuff, LOW);
        delay(200);
  case 7:
      delay(200);
      delay(200);
      delay(200);
      delay(200);
      delay(200);
      needle.write((needlePosition+120)/7);
      delay(200);
      while(true) {
        delay(200);
        delay(200);
  case 8:
      delay(200);
      delay(200);
      delay(200);
      delay(200);
      delay(200);
      delay(200);
      needle.write((needlePosition+120)/8);
      delay(200);
      while(true) {
        delay(200);
        delay(200);
  case 9:
      delay(200);
      delay(200);
      delay(200);
      delay(200);
      delay(200);
      delay(200);
      delay(200);
      needle.write((needlePosition+120)/9);
      delay(200);
      while(true) {
        delay(200);
        delay(200);
  case 10:
      delay(200);
      delay(200);
      delay(200);
      delay(200);
      delay(200);
      delay(200);
      delay(200);
      delay(200);
      while(true) {
        digitalWrite(4, LOW);
        delay(200);
        digitalWrite(4, HIGH);
        delay(200);
