element14 presents
element14 presents
e14 presents blogs Replacement Transit Card for Commodore 64/VIC-1540/1541/1571
  • Episodes
  • Author Author: airbornesurfer
  • Date Created: 31 Aug 2019 2:42 AM Date Created
  • Views 1776 views
  • commodore 1541 repair
  • sx-64
  • sx-64 disk drive repair
  • commodore 64
  • project essex
  • project sx
  • sx-64 repair
  • sx-64 restoration
  • commodore 64 repair
  • commodore disk drive repair
airbornesurfer
airbornesurfer
31 Aug 2019
Commodore SX-64 Restoration
element14 presents  |  Matt Eargle's VCP Profile |  Project Videos
One of the finishing touches that got cut from the Project Essex Commodore SX-64 restoration video on element14 presents was replacing the "transit card" (officially known as the "Head Vibration Protector") from the 1541 floppy diskette drive. The transit card is a specially-shaped piece of heavy card stock that slides into the disk drive and holds the head assembly in place to prevent damage during transit and is essential to taking proper care of the SX-64 due to its "portable" nature. This card will replace Commodore part number 251171-03 and fits all Commodore 5.25" floppy disk drives.
To build it, I printed the attached PDF at 100% (no scaling) on 110lb card stock paper, then glued a second sheet (doubling the weight) before cutting out the design. You'll need to cut out the center hole for the spindle to fit through as well.
Slide the card into the drive like any diskette and close the latch any time you're going to be moving the assembly (or just keep it in there for storage)!
imagetransitcard.pdf
  • clem57
    clem57 over 7 years ago
    Floppies? Guess that fits this machine.
