Sick of Smartphones? Build Your Own ESP32 Open-Source Phone
Clem is getting a little tired of modern smartphones. Not because they aren't powerful enough, quite the opposite. They can do almost anything these days, provided there is an app for it, a subscription to pay for it and a touchscreen that hasn't decided to stop responding. What bothers him is the lack of control, the increasing dependency on proprietary software and services, and the fact that many modern devices don't seem particularly interested in being repaired or lasting very long.
Clem believes there should be at least one basic, open-source version of everything society actually needs. Something that does the job, can be understood, modified and repaired, and doesn't depend on a manufacturer deciding whether it is still worth supporting. He has already explored that idea through other projects, but communication leaves a fairly obvious gap. A mobile phone seems like a good place to continue.
"I think there should be an open source version of everything... one simple open source variant of everything. We did calculators, I started with a washing machine, but one crucial thing is missing: communication. I just need a phone."
The idea isn't to build another smartphone. Clem wants something much simpler: a proper old-school mobile phone with a physical keypad, a small LCD and buttons that actually click. No endless scrolling, no unnecessary apps and certainly no subscription required just to use the thing. But there is a twist. His phone will be open source and use modern 4G connectivity, so it isn't immediately tied to the ageing 2G network on which his previous experiments depended.
Somebody Answer the Phone
Moving the DIY phone on from 2G
This isn't Clem's first attempt at building a retro communication device. In an earlier element14 presents project he created a working sci-fi communicator around an ESP32-S3 and SIM800L GSM module. That project could make real calls over the 2G network, but it also demonstrated one of the difficulties with building cellular hardware at maker scale: the communication module can demand substantial bursts of current when it talks to the network.
That earlier communicator needed a 0.1F supercapacitor to help deal with current spikes from the SIM800L, so going into the new design Clem already has good reason to pay close attention to power rather than treating the battery as something to add at the end.
There is also a more fundamental reason to move on. 2G service is gradually disappearing in different parts of the world. For a phone intended to be useful rather than simply an interesting demonstration, Clem wants the next design to operate on LTE.
"This time I want to make a phone, an actual phone that works in the LTE or 4G network. That's quite a complicated, involved project, so we have to take this step by step."
Finding the right cellular hardware turns out to be one of the first challenges. Smartphones use highly specialised components, many of which are difficult or impractical to buy individually. Even when a suitable modem can be sourced, integrating one is rather different from wiring another 3.3V peripheral onto a microcontroller board. Some of the hardware uses 1.8V logic, cellular RF brings antenna and layout considerations of its own, and the modem's audio path is not necessarily presented as the convenient analogue input and output a hobbyist might expect.
For a reproducible project, Clem wants parts that somebody else can actually obtain.
Putting the SIM7600G-H at the centre of the design
Clem's solution is the DFRobot TEL0124 SIM7600G-H CAT4 4G LTE Shield. Rather than attempting to source and integrate a bare cellular module immediately, he can start with a development board that has already solved several awkward parts of the job.
The board combines a SIMCom SIM7600G-H modem with SIM-card connectivity, the associated cellular and GNSS antenna connections and the surrounding interface electronics. It supports LTE as well as GNSS positioning and can be controlled using AT commands. The board itself normally expects a 5V supply, while its Arduino-style interface makes it useful as a development platform before Clem starts removing the parts he doesn't need.
That last point is important because he isn't planning to leave it looking like an Arduino shield. The development board is effectively an obtainable carrier for the difficult cellular hardware.
"The reason why I chose this specifically is this was basically the only way for me to get such a module in quantity of one, and because it already has some of the very important integration features done that would be extremely difficult to figure out."
One example is the antenna system. Designing the RF section of an LTE device properly isn't simply a case of connecting a convenient piece of wire. Antenna placement and matching become part of the design, and properly characterising that would require RF equipment such as a vector network analyser. By retaining the relevant parts of the DFRobot design and its antennas, Clem can concentrate on integrating a working cellular system without turning this first version of the phone into an RF-development project as well.
The same thinking applies to the module's 1.8V logic. Rather than adding another level-shifting problem to the design, Clem can make use of conversion already included on the carrier board.
Longer term, however, the modem remains deliberately modular.
"If I ever get the means to design my own LTE connection thingy, or maybe use a completely different communication standard, I basically can just exchange these boards and the rest of the project can stay as it is. Hopefully."
That gives the open-source phone a useful route forward. The first version doesn't have to solve every cellular engineering problem before the rest of the handset can be developed, and a later modem board doesn't necessarily mean throwing away the keypad, display, processor and audio design with it.
An ESP32-S3, a proper LCD and plenty of buttons
The main system is based around an ESP32-S3. Clem has room for the phone software, native USB support and Wi-Fi, which opens up possibilities beyond cellular calls. With no SIM installed, the handset could still make use of WLAN; with its cellular module installed, GNSS also turns the hardware into a potentially useful positioning or beacon platform.
For the display, Clem returns to a component he already knows: the Midas MCCOG128064B12W-FPTLW graphic LCD used in his electronic Community Badge. It is a 128 x 64 pixel, 3.3V chip-on-glass FSTN display supporting parallel and SPI interfaces. For a device deliberately avoiding the smartphone formula, the compact monochrome display is a much better fit than a large touchscreen.
Reusing a known part doesn't mean reusing its PCB layout unchanged. On the badge, its integrated flex cable runs directly into a ZIF/FPC connector. On the phone there simply isn't enough spare frontage for the same arrangement, particularly once the keypad is added. Clem therefore redesigns the footprint so that the flex passes through the PCB and folds round to a connector on the back.
"If you print out your design and just lay over the real components you will have a much easier time figuring out the exact right positions. Turns out that the bend through the PCB takes a lot more out of this cable than I initially expected. Avoid any sharp bends, tight turns, because this is quite fragile."
It is a simple but useful fabrication tip. A dimensionally correct footprint in KiCad does not automatically tell you how a real flexible cable will behave when it has to turn through a board. Printing the PCB layout at full scale and physically checking the components gives Clem a chance to find those mechanical problems before committing to manufactured boards.
Below the display is a traditional numerical keypad, complete with the familiar star and hash keys, plus three context-sensitive navigation buttons. Clem wants one-handed operation, and he wants controls that can change function depending on what is shown on the LCD rather than filling the PCB with dedicated keys.
Fifteen or more physical controls could consume a significant number of GPIOs, so the keys are arranged as a matrix rather than each receiving an independent ESP32-S3 input. Each button also gets its own diode.
"We're building a matrix out of these buttons and each button gets its own diode to prevent ghost presses and to make simultaneous button pushes possible."
Allowing combinations is potentially useful in software later. Two function buttons might, for example, become a deliberate shutdown or deep-sleep command rather than requiring another dedicated switch. The firmware for the complete user interface is being left for Part Two, but the hardware has to accommodate those possibilities now.
Audio has to fit somewhere too
A phone rather obviously needs audio, but once the display and keypad have claimed the front of the PCB there isn't much room left for a useful speaker. Clem's answer is to mount it on the back and make the enclosure part of the acoustic design, shaping the case so that the sound is directed towards the user's ear.
The BOM includes a Diodes Incorporated PAM8302AADCR, a mono Class-D audio amplifier capable of 2.5W into 4Ω at a 5V supply. Its 2V to 5.5V operating range and Class-D architecture make it a sensible fit for a compact battery-powered audio stage, while the filterless output architecture helps keep the external component count and occupied board area under control.
Clem also retains something increasingly unusual on commercial smartphones: a headphone socket. It carries the same audio output as the main speaker and provides a microphone input as well.
The modem development board already has a microphone, though, and Clem doesn't see much reason to reproduce circuitry unnecessarily. A small opening in his custom PCB allows the existing microphone to poke through from the mounted LTE board.
"I just integrated it by cutting out a little circle on my custom PCB so the microphone that is already on the development board... can just poke through. Simple solutions."
The real challenge is power
Getting all of this physically onto a PCB is difficult, but the harder electrical problem is supplying the cellular modem. Clem is working around possible transient demands of up to approximately 2.5A while the LTE hardware attempts to communicate with a cell tower. Those peaks may be short, but the battery, its protection circuit, the PCB tracks, connectors and decoupling all have to survive them without allowing the modem's supply to collapse.
"If that surge happens and the battery can't supply that power, it could either be damaged, it could catch fire, the thing maybe isn't just able to connect, so we'd have a brownout. Bad things can happen."
The rest of the phone can run from a switching regulator fed from the battery, supplying the ESP32-S3, display logic, keypad circuitry and other supporting electronics. The SIM7600 hardware presents a more interesting problem. Although the cellular module itself is intended for the type of voltage provided by a single LiPo cell, the DFRobot development board around it is designed to receive 5V through USB or its external input.
Clem initially checks whether simply lowering that supply will work. It doesn't.
Instead, he identifies an electrical entry point around the development board's own regulation section, at the terminals of its bulk capacitor, allowing the modem side of the assembly to be powered much more directly from the battery. Removing the original upright 470µF, 10V capacitor and other unnecessary hardware also helps reduce the height of the development board; the capacitance can then be replaced by a component which lies flatter inside the handset.
On the bench, Clem finds that the modified arrangement continues operating down to around 3.6V. That makes direct operation from a single-cell LiPo a realistic proposition, although it doesn't remove the need to characterise the current peaks properly.
The intended battery is a 2000mAh LiPo, chosen partly because it is approximately the largest capacity he believes he can package behind the PCB while keeping the handset close to normal smartphone dimensions. Clem's aim is to keep the effective discharge around 1C, with suitable capacitance helping to supply the short transient peaks rather than demanding all of the instantaneous current directly from the cell.
This is also an area where Clem intends to go beyond a quick multimeter check. His workbench includes programmable Multicomp Pro instruments which can be scripted for automated testing, something he has previously demonstrated in an element14 presents project. That gives him the option of emulating battery behaviour while logging voltage at the modem and watching for the conditions that produce a brownout or trigger the battery's protection circuitry.
"We can know when things will brown out, we will know when the thing will shut down for safety, we also will know if any over-discharge protection devices will interfere with our device and also if they may draw too much current from the battery."
For the initial tests he doesn't even need a SIM card. GNSS provides a useful way to put some load on the cellular module while confirming that communication with it works.
Testing GPS with a little Python
The SIM7600G-H isn't only a cellular modem. The DFRobot TEL0124 also exposes its GNSS functionality, supporting satellite positioning as well as its LTE communications. Clem takes advantage of that capability early rather than waiting for the complete phone firmware.
He writes a small Python utility which opens the module's serial port at 115200 baud, enables GPS using AT+CGPS=1, requests a fix with AT+CGPSINFO, parses the returned latitude and longitude and opens the result in Google Maps.
There is one detail worth watching if the test is recreated. The raw latitude and longitude returned by the modem cannot simply be pasted into a mapping URL. Clem's parse_gps() function separates the degrees from the minutes, converts the minutes to a fraction of a degree and makes southern and western coordinates negative:
val_float = float(raw_val)
degrees = int(val_float / 100)
minutes = val_float - (degrees * 100)
decimal_degrees = degrees + (minutes / 60)
if direction == "S" or direction == "W":
    decimal_degrees = -decimal_degrees
The script also checks that a sufficiently complete +CGPSINFO: result has been returned before unpacking it. Once a valid fix is available, the calculated coordinates are inserted directly into a Google Maps query:
final_url = f"https://www.google.com/maps/search/?api=1&query={lat},{lon}"
webbrowser.open(final_url)
It is a deliberately small test program, but it verifies several parts of the design independently: serial communication with the modem, the AT-command interface, GNSS reception and the coordinate conversion.
"What it actually outputs, the string of numbers, that's not the coordinates. That is something that you then have to transfer or to convert into actual GPS coordinates. Be aware of that because if you don't do the conversion right, you may end up in a completely different place."
There is also a decidedly practical part of GNSS debugging: getting a reliable fix indoors isn't guaranteed. Clem ends up dangling the development kit outside his window to test it.
Making the PCB fit the phone rather than the other way around
With the basic electrical decisions made, the custom board becomes a fairly dense piece of hardware. Clem has high-speed lines associated with the display, signals between the ESP32-S3 and LTE hardware, audio circuitry, display backlight control and the keypad competing for space. The antennas add another constraint because their positioning and clearance cannot simply be ignored once the remaining gaps on the PCB start looking inviting.
The upper section of the board is consequently crowded with electronics while the lower section is dominated by the physical keypad. Connectors on the rear accept the modified LTE assembly.
This leaves one particularly important question unanswered: where exactly does the battery go?
"We have to make sure that we don't get in the way of the antennas. We have to leave out some space for antennas and plan where the antennas of the LTE module will go. I just hope that the battery will still fit somewhere here."
Clem already has an enclosure in mind, so the PCB isn't being designed in isolation. His chosen Hammond case is approximately the size and thickness of his everyday smartphone once its protective cover is taken into account. More importantly for a device containing a relatively large LiPo cell, the aluminium housing provides a sturdy mechanical shell around the completed assembly.
The enclosure affects several earlier decisions, from relocating the speaker and folding the LCD cable to removing unnecessary connectors and standoffs from the LTE development board. It is less a case of drawing a PCB and finding a box afterwards and more a process of developing the electronics and mechanics together.
A phone in progress
At the end of Part One there still isn't a finished open-source mobile phone, and Clem is quite deliberate about that. The board has been designed, the main component choices are in place and enough testing has been done to establish a plausible route through the difficult areas, but the PCB still has to be populated and proved.
The supplied project resources reflect that stage of development. Alongside the GPS utility are the work-in-progress KiCad project, PCB and schematic files, separate schematic sheets for audio, communications, keypad, power, screen and vibration, PCB footprints and a STEP model. They are useful for anyone wanting to follow the design at board level, but they shouldn't yet be treated as a finished, production-ready reference design.
"Be aware these are a work in progress. In the next episode I may have to do some bodges and some solutions to things. We'll find out."
That is particularly relevant for anybody tempted to send the PCB straight to manufacturing. Part Two is where assumptions made on screen meet a physical assembly. Power integrity, antenna positioning, audio behaviour, LCD fit, battery clearance and all those carefully positioned components still have an opportunity to cause trouble.
There is also rather a lot of software still to write. Apart from the standalone GPS experiment, Clem deliberately hasn't tried to complete the phone firmware during this first stage. The keypad matrix, navigation controls, modem communications and user interface will all need to come together once the hardware is assembled.
Still, the direction is now much clearer. Instead of trying to miniaturise an entire smartphone architecture, Clem has started with the functions he actually wants: a physical keypad, a compact LCD, proper audio, Wi-Fi, GNSS and LTE communications, wrapped around hardware that can be understood and modified.
And because the cellular section is modular, even that doesn't have to be the final version. A later LTE solution, or potentially another communication technology altogether, could eventually replace the current board while leaving much of the handset intact.
Part Two will put all of that to the test. Clem will assemble the PCB, start bringing the phone software to life and find out whether the 2000mAh battery, modified SIM7600G-H board, ESP32-S3, display, audio circuitry and rather large collection of physical buttons really can occupy the same Hammond enclosure.
If they can, he will be considerably closer to the thing he wanted at the beginning: not another smartphone, but a useful phone that happens to be open, repairable and his own.
Supporting Links and Files
-  Episode 742 Resources - Sick of Smartphones? Build Your Own ESP32 Open-Source Phone
Bill of Materials and Parts Used
MCCOG128064B12W-FPTLW Midas 1 Buy Now
F32R-1A7H1-11030 amphenol 1 Buy Now
PAM8302AADCR diodes 1 Buy Now
MC0603B221K500CT multicom pro 2 Buy Now
BLM18KG221WH1D murata 2 Buy Now
TEL0124 dfrobot 1 Buy Now
PTS810SJM250SMTR LFS ck components 12 Buy Now
MAL216050471E3 Vishay 1 Buy Now
NSR20F30NXT5G onsemi 12 Buy Now
DMG3414U diodes 2 Buy Now
