element14's The Ben Heck Show
Blog Ben Heck's Home-Brew Solder Reflow Oven 2.0
  • Author Author: Stuartsjones
  • Date Created: 22 Jan 2014 1:04 PM Date Created
  • Views 1165 views
Stuartsjones
Stuartsjones
22 Jan 2014
Ben's fed-up with the difficulty of soldering surface-mount components by hand and builds a new reflow oven to keep in his shop. He transforms an inexpensive toaster over into a vital tool for electronics engineers and tinkerers. In this updated oven, he uses two thermal couples to ensure even heat distribution and effective reflow.
    Hi Ben,
    Another great project and something that we will all have to get used to, as surface mount components take over completely. The only thing I would point out is the diagram you used to show the operation of the thermistor, should have shown it being driven from either a constant current source or as a potential divider with a resistor in series with the Vcc supply . The circuit was driven directly from a voltage supply so the output point you indicated would not vary. I know I am teaching you to suck eggs, so just pointing out to clarify to beginners image
    Regards
    Hi Ben,
    Regards
  • Kilohercas
    Kilohercas over 12 years ago in reply to e14 Contributor
    hrr taking ideas from my project , anyway The specified item was not found.
