element14's The Ben Heck Show
Blog My name is Eliezer, and I want to build.
  • Date Created: 11 Oct 2015 2:36 PM Date Created
  • Views 652 views
e14 Contributor
e14 Contributor
11 Oct 2015
Hello Ben. I was wondering if you could help me put together a motherboard with Bluetooth or wifi, depending on what you recommend me, it would be possible to connect a touch screen, rechargeable battery, and it can play 3 to 4 motors, and household wants a motherboard was between 4 to 5 centimeter width of 7 to 10 Length
  • kouruu
    kouruu over 10 years ago
    Sounds like a job for the Raspberry Pi. it closely fits the dimensions you are after, runs linux off SD card, can run a touch screen and has plenty of GPIO (General Purpose Input/Output). And it runs off 5v thru it's Micro USB port. It also can support both wireless and bluetooth. My Retropi uses both wireless for remote maintenance and bluetooth to connect wireless PS3 controllers to play my favorite old systems. Mind you, you would need to add a voltage regulator to adjust the voltage from your battery.
