element14's The Ben Heck Show
Blog Raspberry Pi tablet
  • Author Author: asdf2345
  • Date Created: 4 Dec 2016 2:39 AM Date Created
  • Views 1060 views
Raspberry Pi tablet
asdf2345
asdf2345
4 Dec 2016
I picked out a part list to make it a real tablet (if you could find similar parts for cheaper reply with links to them (no ebay))
Battery https://www.adafruit.com/product/353
Battery charger https://www.adafruit.com/product/2465
Speakers https://www.amazon.com/dp/B01JS6QHWQ
Display https://www.amazon.com/dp/B01IH6ZWWO
Raspberry Pi https://www.amazon.com/dp/B01C6FFNY4
And Cellular NeeCoo Bluetooth V4.0 Dual SIM Card Adapter-29.99 Online Shopping| GearBest.com
  • wavesofintelligence
    wavesofintelligence over 9 years ago
    I suggest you to get the official raspberry pi touchscreen: http://www.adafruit.com/products/2718
    You are probably going to have a hard time setting up that sim card adapter. You could try a sixfab 4g hat:http://http://sixfab.com/product/3g-4glte-base-shield/
    Otherwise, you're probably good to go!!
  • gupperino
    gupperino over 9 years ago
    A few issues here. For one, the battery probably won't be able to last long enough at all for practical use, especially with a display and Pi plugged in at the same time, not to mention a sim card slot! Also, the Powerboost 1000c is an issue because it can only supply up to 1A, meaning it can't supply nearly enough current for the Raspberry Pi 3 (2.5A) as well as the display, which probably has an even higher draw. It might also need more than 5v but I'm not sure. So this build probably wouldn't work too well, so I would recommend putting more effort into this list. Good job on the Speakers though, and I like that screen!
