element14's The Ben Heck Show
Blog The Ben Heck Show Needs Your Help!- Episode Live!
  • Author Author: element14Dave
  • Date Created: 31 Jul 2014 4:44 PM Date Created
  • Views 4565 views
  • Comments 55 comments
  • crusher
  • ideas
  • ben_heck
  • heck
  • ben
  • can
element14Dave
element14Dave
31 Jul 2014
Ben Heck home page
Ben's Top 5 Lifehacks
Ben's build kit
The  Can Crusher Buildhttp://www.element14.com/community/docs/DOC-24800/l/episode-3-ben-builds-an-automatic-can-crusher-or-does-he never turned out the way Ben and team wanted it to and is in need of an update. In an upcoming episode of The Ben Heck Show,  Ben and team will be creating "Can Crusher 2.0" and they need your help! Let Ben know your idea for what he should do for "Can Crusher 2.0"  by following the directions below.
Thanks for all of the wonderful ideas around "Can Crusher 2.0" Ben and team will be going through and evaluating the comments...check out how Ben used your ideas for the build!
Episode 153: Ben Heck’s Crowdsourced Can Crusher Part 1 Episode
Directions:
Step 1:  Log in or register on element14, it's easy and free.
Step 2: Post your suggestion in the comments section below. Videos, pictures and  text are all welcomed forms of submission. Comments or instructions should be limited to 200 words or less and contain no more than 2 diagrams.
Step 3:  Sit back, relax, and enjoy the show!  We will accept ideas until 12:01am Central Time  on August 18, 2014.  If you need something to do between now and then make sure to check out what is happening on This week on element14 Community, or watch more Ben Heck at element14.com/TBHS.
Important Notice:
  • By submitting an entry you will automatically start receiving notifications of other responses to this post. If you do not wish to receive notifications, select "Unfollow" at the top right of the post. If you have any questions, please let us know in our Feedback & Support area.
  • michaelwylie
    michaelwylie over 12 years ago +4
    Ben; I have two ideas, and they're more for the cool factor rather than practicality. 1. Use a solenoid with a plunger to catastrophically crush the can. 2. Use a vacuum system to suck the air from the…
  • Workshopshed
    Workshopshed over 12 years ago +2
    Oversized gear wheels with the can fitting between the teeth.
  • Kilohercas
    Kilohercas over 12 years ago +1
    i would use large capacitor and large coil,>20kj Or more simple idea, 2kW induction heater, all you need to do is to place can inside ceramic holder with large coil around, and it will melt in few seconds…
    I'm kinda surprised this hasn't been suggested yet but why not crush in a different manner than the normal top to bottom? Top to bottom is the can's highest angle of compression strength, hence why they are shipped stacked in that fashion.
    I propose to use the can's weakest features to make a 'complete' crush with the least amount of effort. A side compression with a pressure angle of 45 degrees of the plane that the can is lying on should flatten the cylinder while rotating the top and bottom faces of the cylinder to be flat. See picture because it's kind of difficult to put into words. A variation could be to first dent the side of the can and then just apply downward force and you get a similar result with similar pressure but it would be an additional moving part. As for the specifics of force generation, you could get away with a pretty small motor combined with a long enough lever but I personally would go for dramatic effect of a motorized lift of a fairly heavy weight that is dropped guillotine style using gravity (or even mechanically assist the gravitational return for even more acceleration).
