element14's The Ben Heck Show
Blog The Ben Heck Show Needs Your Help!- Episode Live!
  • Author Author: element14Dave
  • Date Created: 31 Jul 2014 4:44 PM Date Created
  • Views 4633 views
  • Comments 55 comments
  • crusher
  • ideas
  • ben_heck
  • heck
  • ben
  • can
element14Dave
element14Dave
31 Jul 2014
Ben Heck home page
Ben's Top 5 Lifehacks
Ben's build kit
The  Can Crusher Buildhttp://www.element14.com/community/docs/DOC-24800/l/episode-3-ben-builds-an-automatic-can-crusher-or-does-he never turned out the way Ben and team wanted it to and is in need of an update. In an upcoming episode of The Ben Heck Show,  Ben and team will be creating "Can Crusher 2.0" and they need your help! Let Ben know your idea for what he should do for "Can Crusher 2.0"  by following the directions below.
Thanks for all of the wonderful ideas around "Can Crusher 2.0" Ben and team will be going through and evaluating the comments...check out how Ben used your ideas for the build!
Episode 153: Ben Heck’s Crowdsourced Can Crusher Part 1 Episode
Directions:
Step 1:  Log in or register on element14, it's easy and free.
Step 2: Post your suggestion in the comments section below. Videos, pictures and  text are all welcomed forms of submission. Comments or instructions should be limited to 200 words or less and contain no more than 2 diagrams.
Step 3:  Sit back, relax, and enjoy the show!  We will accept ideas until 12:01am Central Time  on August 18, 2014.  If you need something to do between now and then make sure to check out what is happening on This week on element14 Community, or watch more Ben Heck at element14.com/TBHS.
Important Notice:
  • By submitting an entry you will automatically start receiving notifications of other responses to this post. If you do not wish to receive notifications, select "Unfollow" at the top right of the post. If you have any questions, please let us know in our Feedback & Support area.
  • michaelwylie
    michaelwylie over 12 years ago +4
    Ben; I have two ideas, and they're more for the cool factor rather than practicality. 1. Use a solenoid with a plunger to catastrophically crush the can. 2. Use a vacuum system to suck the air from the…
  • Workshopshed
    Workshopshed over 12 years ago +2
    Oversized gear wheels with the can fitting between the teeth.
  • Kilohercas
    Kilohercas over 12 years ago +1
    i would use large capacitor and large coil,>20kj Or more simple idea, 2kW induction heater, all you need to do is to place can inside ceramic holder with large coil around, and it will melt in few seconds…
  • Workshopshed
    Looking at the Mk1 version perhaps rather than using the winch to move the handle perhaps it could raise a large weight, that could then be released by a solenoid or cam and the weight would  pull down the handle resetting the machine to start again.
    As Lee says some kind of eject mechanism is really needed.
    Prior art:
  • Workshopshed
    Prior art:
