Ben Heck Featured Content
  • Ben Heck Featured Content
Forum Raspberry Pi Multi Room Music server, including A2DP
  • Subscribers 42 subscribers
  • Views 811 views
  • Single Board Computer
benutti
benutti over 10 years ago
Hi, I wonder if it is possible to create a raspberry pi audio system that can handle spotify, radio streams , etc (like lms , volumio, etc... does).BUT also handles A2DP bluetooth input...
  • clem57
    clem57 over 10 years ago
    Yes Pi MusicBox - A Spotify, SoundCloud, Google Music player for the Raspberry Pi, with remote control
    Clem
  • benutti
    benutti over 10 years ago in reply to clem57
    No a2dp
  • clem57
    clem57 over 10 years ago in reply to benutti
    Turn your Raspberry Pi into a Wireless Portable Bluetooth Audio System A2DP - All
  • benutti
    Not combineable... that instruction takes full control of alsa... as in no more other input possible
    shabaz over 10 years ago in reply to benutti
    I'm sure it is possible with some research and programming, after all there doesn't seem to be a technical limitation here - it is resolvable in software, so if you're going to do this then please share the results so others can benefit from it too. Not all instructables will have exactly the project you want unfortunately, but can provide ideas for further research.
    Otherwise, if you're unable to do this, then until someone else researches and creates such a project and publishes the details, you could always fallback to buying a separate A2DP to analog (or digital) audio output converter box, and switch or mix it into the audio. Not as elegant, but the alternative is to spend time developing the precise project you require.
