Ben Heck Featured Content
  • Ben Heck Featured Content
Forum Temperature measurement
  • Subscribers 43 subscribers
  • Views 556 views
  • Portables
chiversj
chiversj over 10 years ago
A super smart thermometer that measures temperature and logs with time stamp, and other information. Creates a log over a period of time. Then downloads information into computer or other devices. Having it talk would be a neat plus feature.
  • clem57
    clem57 over 10 years ago
    Sounds like a project using parts like https://www.sparkfun.com/wish_lists/34664 . add bluetooth to indoor pc an the sky's the limit.
    Clem
  • uscdadnyc
    uscdadnyc over 10 years ago in reply to clem57
    Why not use a RaspPi and a Temp/Humidity Sensor DHT22 (available from element14)?
    Get a full-blown RaspPi and once the H/W and S/W is finalized, put same onto RaspPi
    Zero Board.
    Below is my Canned Answer to people possibly considering RaspPi
    ________________________
    WRT (With Respect To) S/W for the RaspPi there are Two
    Flavors
    1.
    Raspbian (Debian) O/S gotten at:
    www.raspberrypi.org
    2.
    Minibian O/S gotten at:
    https://minibianpi.wordpress.com/
    I personally have Two separate uSD/SD memory Cards
    I boot-up w/ the card that will dictate what I want to do.
    Minibian for using the RaspPi to control/obtain Outside
    World Parameters.
    Raspian (Debian)  to use RaspPi as a general-Purpose Computer.
    __________
    WRT H/W for the RaspPi, there are also many options,
    but one is unique:
    This being the RaspPi Zero. RaspPi Zero is a stripped-down RaspPi
    Board that one would use AFTER you have developed your H/W &
    S/W on the Full-Function RaspPi Boards
    BTW the RaspPi Zero does NOT have connector for RaspPi Camera
    Module
    __________
    WRT to Learning/Receive-Mentoring about the RaspPi, there are MOOC
    (Massively Open Online Courses) courses on the web.
    edx.org
    coursera.org
    udemy.com [A PAID Site: Tuition $$ required]
  • makerkaren
    makerkaren over 10 years ago
    Would this be used more for indoor, outdoor, both, or something else entirely?
  • uscdadnyc
    uscdadnyc over 10 years ago in reply to makerkaren
    I went to the URL suggested by CM. It too, suggests an Arduino Variant to be the Basis for any Weather Station. The Arduino Fio (the variant) appears to use/have : 1) Polymer Ion Batterry to run RTC (Real Time Clock), 2) micro-USB B female connector  for charging said battery (NOT used for programming/interfacing w/ this Arduino Fios), Programming, I believe is done thru a Pololu (manuf) USB AVR Programmer such as manuf. p/n 1030, MCM distributor # 83-15690, BUT I think you have to Solder onto pins on the bottom of the Arduino Fio. I just recv'd (physically) a USB AVR Programmer today but my Gertduino does Not get it's Programming thru this device. (I bought it for Insurance, in case I needed it) My Gertduino gets it's programming via the GPIO Header Pins on the RaspPi.
    Full Disclosure: I am NOT planning/building with any particular Project in Mind (like a weather station) .I am playing around w/ the various options in both H/W and S/W
    USCDADNYC (NY NY USA)
    BTW here is a joke dedicated to : theheckwithkaren.
    Q: How would you describe a person who re-Marries?
    A. A Triumph of HOPE over Experience
