Ben Heck Featured Content
  • Ben Heck Featured Content
Forum Sound not working on Raspberry pi
  • Subscribers 43 subscribers
  • Views 671 views
  • raspberry
  • pi
Hi i have been having problems getting sound to work on my pi any ideas.
  • royston02
    royston02 over 11 years ago +1
    You may be better off posting it on the Raspberry Pi forum.
  • royston02
  • kidiccurus
    kidiccurus over 11 years ago in reply to royston02
    Agreed. Until then try working through these instructions to make sure your audio output is correct.Raspberry Pi Documentation
    e14 Contributor over 10 years ago in reply to kidiccurus
    1. you go to TERMINAL
    2. KEY IN sudo raspi-config
    3. CHOOSE advance options 9
    4. you see audio
    5. CHOOSE FORCE hdmi OR FORCE 3.5 [headphone jack] mm
    6. make sure your monitor has hdmi speaker attached.
    7. if not try 3.5 mm
    Which OS are you using?  Post it and your Pi model identifier with your question in the appropriate forum - unless your Pi is using Raspbian, Then, Samuel's suggestion is spot on.
