Ben Heck Featured Content
  • Ben Heck Featured Content
Forum Less build idea and more a "Tips and Tricks"
  • Subscribers 41 subscribers
  • Views 378 views
I am a long time viewer and have been looking for information on how to polarize a ribbon cable socket.
This seems to be a key way to make sure that sockets are not plugged in incorrectly, but I can find little on a DIY way to do this necessary task.
    shabaz over 11 years ago
    Hi Joe,
    The PCB header for ribbon cable sockets usually do have a key, see here:
    Otherwise, I believe for some applications (e.g. in PCs) they plug up a hole on the socket (there are small plastic inserts for that) if one of the pins is snipped off on the board.
    e14 Contributor over 11 years ago in reply to shabaz
    Shabaz,
    For the life of me I can not find any of the inserts that you are talking about.
    Not all headers are the shrouded kind and not all cable connectors have tabs. This question could apply to other types of wire to pcb connectors as well.
    shabaz over 11 years ago in reply to e14 Contributor
    They are called polarizing keys, you can see a photo of them here:
    http://www.tkp.com.tw/en/product/2.54mm-2510-KEYLF/TKP-0392.html
    To see what they look like inserted into the ribbon cable connector, see the following link, third photo down:
    http://www.mikeshardware.com/howtos/howto_connect_ide_hd.html
    A DIY way would be to use a wood splint I guess. Generally boards intended for a ribbon cable do have the header with the cutout as shown in the earlier post photo though.
