Ben Heck Featured Content
  • Ben Heck Featured Content
Forum Suggestion for a tutorial
  • Subscribers 42 subscribers
  • Views 424 views
     I am a begginer in designing 3D printer .STL files,and I ask you if you can make a tutorial in which you feature how to design a Raspberry Pi PiTFT 2.8" separate case.By separate case I mean a case in which you put ONLY the screen and
there is a cut in which you plug your cable to connect it to the Pi's GPIO pins.I really need this case,so can you please give me the .STL file after?
Thank you,
     Mihnea
  • kidiccurus
    kidiccurus over 11 years ago +1
    Ben has already made a tutorial for a pi case using autodesk 123d design. Why not try and design your own with the techniques from this tutorial? Just measure your screen and design around it like he does…
  • kidiccurus
    Ben has already made a tutorial for a pi case using autodesk 123d design. Why not try and design your own with the techniques from this tutorial? Just measure your screen and design around it like he does for the pi.
    e14 Contributor over 11 years ago in reply to kidiccurus
    I didn't see that episode.I will watch it.Thanks!
