Ben Heck Featured Content
  • Ben Heck Featured Content
Forum The Ben Heck Show Power Glove Code
  • Subscribers 43 subscribers
  • Views 875 views
olddos
olddos over 9 years ago
Hello.
Does anyone have the code that Ben wrote in the episode where he tore down the Nintendo Power Glove. This code puts all the analog data coming from the power glove into the serial monitor.
Thanks.
P.S. The code is going to be used on an Arduino Uno but the code was written for a Teensy 2.0. Is there any modifications that I would have to make to the code or the circuit to accommodate for this.
  • olddos
    olddos over 9 years ago in reply to RParkerE +2 verified
    After look through each line of code posted on Github by Ben, I finally got the data I needed. With this data, I'm one step further to completing the project I'm working on. Thanks for all your help.
  • makerkaren
    0 makerkaren over 9 years ago
    Here is a link to the GitHub that contains all the files from the Power Glove episode. https://github.com/thebenheckshow/239-tbhs-Power-Glove-Teardown
    In the future, you can look for design files from The Ben Heck Show builds here, Ben Heck's Build Kits.
    Good luck with your project!
  • olddos
    0 olddos over 9 years ago in reply to makerkaren
    That is not the code I'm looking for.  The code you are referring to, from what I'm able to understand by reading the code, this code moves the mouse around.  I need the code that puts the values for the X position, Y position, distance, and the flex sensors onto the serial monitor.
  • RParkerE
    0 RParkerE over 9 years ago in reply to olddos
    I am pretty sure if you look at the test code provided that the X and Y positions are being dumped to the serial monitor. Lines 113-115 in test_code.ino do this. This does move the mouse around, but also gives you some of the information you are looking for.
    Serial.print(xpos);
    Serial.print("\t");
    Serial.print(ypos);
  • olddos
    0 olddos over 9 years ago in reply to RParkerE
