Ben Heck Featured Content
  • Ben Heck Featured Content
Forum SNES won't power on... chance for recovery?
  • Replies 14 replies
  • Answers 2 answers
  • Subscribers 43 subscribers
  • Views 2723 views
  • Console Builds
  • help
  • video game
  • help!!
  • snes
  • help!!!!
  • help!
  • commfeedback
Hi everyone,
I posted this in /r/SNES and got no useful help, so I figured I'd come here because I'm assuming people in this forum know at least a little more about electronics...
Anyways, I bought two SNES units for the low low price of $20. One of them worked mostly fine while the other wouldn't read carts at all (fixed later with some good ol' isopropyl alcohol). I was cleaning them both up just to get them in as best condition as I could, and in my process I decided to clean the cart slot of the mostly working unit. I had the board out of the case at this point, and after I cleaned it I wanted to test that it still worked. So I went over to my TV, plopped the SNES down on my carpeted floor (I think this was my mistake), plugged in the power and POP! I saw a spark form the board towards the back where the power is. I attempted switching the unit on and nothing happened; no power LED, no video out, nothing. The fuse isn't blown (I think - I did a rudimentary continuity test my using the power button leads on my computer motherboard and the PC turned on when I contacted either side of the fuse with some cables), so I'm assuming something in the power delivery mechanism got fried.
How can I diagnose exactly what's wrong with my SNES, and would I be able to fix it? Thanks in advance for any responses!
Edit: Just to clarify, I did use the official power supply, so I don't think it was that. I'm guessing there was a short somewhere else on the board besides the fuse. Also, I attached pictures of the board.
  • feranix
    feranix over 8 years ago in reply to e14 Contributor +1
    Any luck?
  • jdlui
    0 jdlui over 9 years ago
    Do you see any obvious signs of burning on any board components?
    Can you remove the fuse and do continuity test on it?
    0 e14 Contributor over 9 years ago in reply to jdlui
    I did a cursory look at it after the incident, but couldn't see anything obvious. There was that "burnt electronics" smell, but there were no visible signs (to me) that anything happened. I don't have the board with me at the moment but I can check later to be sure, or maybe send pictures.
    I might be able to remove the fuse and test it, is what I did initially (with the PC mobo) a solid way to test continuity, or do I need a multimeter? (I'm a real electronics noob and don't have one. Might be worth the investment...)
  • gam3t3ch
    0 gam3t3ch over 9 years ago
    I would check the cap under the shield and the pico fuse (F1) if the pico fuse is replace with a 1.5 amp Glass Fuse and holder (cheaper method)
    make sure no damage to the ac input on the board side. give it a good cleaning make sure no corrosion kicking around on the board either if so clean it up best you can.
    Just a note I have seen this happen with blackouts causing damage to the system as well as using incorrect voltage AC Adapeters / 3rd party ones not rated correctly.
    I attached pictures of the board, let me know if you see burns anywhere! It doesn't look like there are any...
    0 e14 Contributor over 9 years ago in reply to gam3t3ch
    I attached pictures to my original post, and it doesn't look like the cap is blown, nor the fuse. I also can't see any visible damage to the area of the board near the AC input, so this is very weird. I'm quite the electronics noob so maybe I missed something obvious, so if you could look over the pics I posted I'd greatly appreciate it. Also, just to answer to those last two points you brought up, there was no blackout while I was testing (also the PSU is plugged into a surge strip), and also I did use an official SNS-002 power supply, so I don't think either of those things would be the culprit. I'm assuming it was just me putting it on the carpet and bridging something that shouldn't have been
  • gam3t3ch
    0 gam3t3ch over 9 years ago in reply to e14 Contributor
    I would 100% test that pico fuse and if you need hit up most auto motive stores or electronics shops and get a inline or glass fuse holder, are you able to pull off the top of the ac input there without any difficulty?
  • gam3t3ch
    Basically anything further one would need it on their bench to test components.  visuals look fine.  If you have a soldering iron around and a multimeter you should be good to go to pull and test the fuse and should be able to test the other caps on the board but I would always discharge first.   But I am leaning towards that fuse.
    I'm borrowing a soldering iron this weekend from a friend (for an unrelated reason, just to replace some save batteries in cartridges with battery holders) and I can easily get myself a multimeter, so I'll check the fuse. I did try to test for continuity at least as follows:
    1. Shut my custom gaming PC off
    2. Attach some GPIO male to female cables to the power button header on the motherboard
    3. Touch the male ends of the cables to either side of the fuse
    The PC powered on after I touched the cables to the solder points, so I assumed this means it's not blown. Is that not a correct assumption? Is there anything else I should test the fuse for?
    Edit: also, for desoldering things, is solder wick necessary if I don't have proper desoldering equipment? Just curious if I can desolder with only a soldering iron.
  • gam3t3ch
    I would pull it to test it and I would start at the ac input and work my way down the board testing.  From what it sounds like its OK, if that is the case checking the capacitors would be the next step.  All the stuff is pretty cheap so wouldn't cost much to get a cap kit for it and I bet you can find kits for sale for your board model as well.
  • gam3t3ch
    solder wick not needed in my opinion.
